If i am not disabling watchdog timer in code what will happen?It is mandatory to disable watchdog timer? please clarify my doubt.
with regards,
P M Manoj Kumar
with regards,
P M Manoj Kumar
Hi Manoj,
In that case you need to handle the WD and clear the WD counter with in specific time else WD counter will expire is issue a reset. WD reset on CPU1 will reset full device. CPU2 WD will reset CPU2 subsystem.
Vivek Singh
Hi vivek,
After disabled watchdog timmer also my controller is resetting is their any reason for resetting? Custom board only getting problem development board working fine. I was probed xrs pin It is toggling.
With regards,
P M M kumar.
Please monitor the power supply on your custom board. If may be dropping below min value hence getting reset.
Vivek Singh
Hi Manoj,
Were you able to monitor the power supply on board?
Vivek Singh
