Part Number: TMDSEMU110-U
Can key pin be connected to GND?
Also, can VTREF be connected to 3.3V supply?
Thank you!
Thank you!
Elisa,
Elisha Tarroza71 said:Can key pin be connected to GND?
I wouldn't if you don't plan to physically remove the key pin (thus it wouldn't really be connected to anything).
The reason is that, if a connector is accidentally placed inverted, the SWDCLK/TCK pin (output from the Debug Probe side) will be grounded, with the potential to cause damage.
Elisha Tarroza71 said:Also, can VTREF be connected to 3.3V supply?
Yes, via a current limiting resistor. Check the section TVRef of the XDS Target Connection Guide page at:
https://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_xds_target_connection_guide.html
Hope this helps,
Rafael
