Part Number: TMS320F28335
I need to write a custom bootloader. How can I write the program memory? PWRITE command writes into the programm address space but does not program the flash.
Hi Sergey,
If you're meaning how to program the flash within your boot routine code then please look at the Flash API within C2000ware, directory location below:
C:\ti\c2000\C2000Ware_2_01_00_00\libraries\flash_api\f2806x
There's also a example program you can reference for custom SCI boot:
C:\ti\c2000\C2000Ware_2_01_00_00\device_support\f2806x\examples\c28\f28069_sci_flash_kernel
Or are you meaning how to load your actual bootloader in flash memory (linker command file and such)?
Kevin
