Part Number: TMS320F28335
I am working on TMS320F28335 (Epwm module) and i am generating the 1KHz frequency at the pwm channel(1A,1B,2A,2B,3A,3B,4A,4B).. i am going to run the motors with this channels and i want control the each pwm channels ON/OFF individually like ,if my variable is receive_data.
the configuration is 0-th bit is high means channel 1A should be be generate the pwm and epwm1B should not generate the pwm frequency..
through datasheet my understanding is we can run the channel 1A and 1B separately
will anyone please explain.....
Thank you ,
D.sangeetha
