CCS/TMS320F28379D: Encoder Module
Part Number: TMS320F28379D
I have an quadrature encoder with DC motor used with Delfino F28379d EQEP module, using the libraries from (TI) i can get signals from encoder at (1x) resolution that mean i only count 1 edge form signal A and only used signal B for indicating the direction this in [Direction Count Mode], the question here what can i do to increase the resolution to (4x) using the EQEP Modules of the controller cause i search in the data sheet and found that we can not use signal B for counting and i want to check if this true or not also if there is away to solve this problem !!
