Part Number: TMS320F28379D
I was trying to learn zero crossing detection using ADC PPB . i have used the code of ADC_PPB_LIMITS for reference. By doing some changes in the code, i was trying to observe whether my ISR is getting called after zero crossing or not . So in my code i have configured respective register to set adc zero crossing detection flag . however despite of correct adc conversion (as i could see in expression window) after giving sinusoidal signal from function generator with value 0 to 1 volt, zero crossing is not happening. In my code, i have set an variable named as toggle_count in adc_ppb_isr which is suppose to count on every zero crossing but it is not happening . please suggest. I am attaching modified code for your reference.
// FILE: adc_ppb_limits_cpu01.c
// TITLE: ADC limits check using post-processing block for F2837xD.
//! \addtogroup cpu01_example_list
//! <h1> ADC PPB Limits (adc_ppb_limits)</h1>
//! This example sets up the ePWM to periodically trigger the ADC. If the
//! results are outside of the defined range, the post-processing block
//! will generate an interrupt.
//! The default limits are 1000LSBs and 3000LSBs. With VREFHI set to 3.3V, the
//! PPB will generate an interrupt if the input voltage goes above about
//! 2.4V or below about 0.8V.
// $TI Release: F2837xD Support Library v3.08.00.00 $
// $Release Date: Mon Dec 23 17:32:30 IST 2019 $
// $Copyright:
// Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "F28x_Project.h"
// Functional Prototypes
void ConfigureADC(void);
void ConfigureEPWM(void);
void ConfigurePPB1Zcd(Uint16 soc);
void SetupADCEpwm(Uint16 channel);
interrupt void adca_ppb_isr(void);
Uint16 Toggle_count = 0;
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the F2837xD_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initialize GPIO:
// This example function is found in the F2837xD_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
InitGpio(); // Skipped for this example
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the F2837xD_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in F2837xD_DefaultIsr.c.
// This function is found in F2837xD_PieVect.c.
InitPieVectTable();
// Map ISR functions
EALLOW;
PieVectTable.ADCA_EVT_INT = &adca_ppb_isr; //function for ADCA PPB
EDIS;
// Configure the ADC and power it up
ConfigureADC();
// Configure the ePWM
ConfigureEPWM();
// Setup the ADC for ePWM triggered conversions on channel 0
SetupADCEpwm(0);
// Configure ADC post-processing limits
// SOC0 will generate an interrupt if conversion is above or below limits
ConfigurePPB1Zcd(0);
// Enable global Interrupts and higher priority real-time debug events:
IER |= M_INT10; //Enable group 10 interrupts
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
// enable PIE interrupt
PieCtrlRegs.PIEIER10.bit.INTx1 = 1;
// Start ePWM
EALLOW;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
EPwm1Regs.ETSEL.bit.SOCAEN = 1; //enable SOCA
EPwm1Regs.TBCTL.bit.CTRMODE = 0; //unfreeze, and enter up count mode
//take conversions indefinitely in loop
do
//wait while ePWM causes ADC conversions
//if the ADC conversions exceed the PPB limits, then an interrupt
//will be generated
}while(1);
// ConfigureADC - Write ADC configurations and power up the ADC for both
// ADC A and ADC B
EALLOW;
//write configurations
AdcaRegs.ADCCTL2.bit.PRESCALE = 6; //set ADCCLK divider to /4
AdcSetMode(ADC_ADCA, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
//Set pulse positions to late
AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1;
//power up the ADC
AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1;
//delay for 1ms to allow ADC time to power up
DELAY_US(1000);
EDIS;
// ConfigureEPWM - Setup SOC and compare values for EPWM
EALLOW;
// Assumes ePWM clock is already enabled
EPwm1Regs.ETSEL.bit.SOCAEN = 0; // Disable SOC on A group
EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC on up-count
EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event
EPwm1Regs.CMPA.bit.CMPA = 0x0800; // Set compare A value to 2048 counts
EPwm1Regs.TBPRD = 0x1000; // Set period to 4096 counts
EPwm1Regs.TBCTL.bit.CTRMODE = 3; // freeze counter
EDIS;
// ConfigurePPB1Limits - Configure high and low limits for ADCPPB
EALLOW;
AdcaRegs.ADCPPB1CONFIG.bit.CONFIG = soc; //PPB1 is associated with soc
//set high and low limits
//enable high and low limit events to generate interrupt
AdcaRegs.ADCEVTINTSEL.bit.PPB1ZERO = 1;
EDIS;
// SetupADCEpwm - Setup ADC EPWM channel and trigger settings
Uint16 acqps;
// Determine minimum acquisition window (in SYSCLKS) based on resolution
if(ADC_RESOLUTION_12BIT == AdcaRegs.ADCCTL2.bit.RESOLUTION)
acqps = 14; //75ns
else //resolution is 16-bit
acqps = 63; //320ns
//Select the channels to convert and setup end of conversion flag
//ADCA
EALLOW;
AdcaRegs.ADCSOC0CTL.bit.CHSEL = channel; //SOC0 will convert pin A0
AdcaRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is 100 SYSCLK cycles
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 5; //trigger on ePWM1 SOCA/C
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 0; //end of SOC0 will set INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1; //enable INT1 flag
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //make sure INT1 flag is cleared
EDIS;
// adca_ppb_isr - ISR for ADCA PPB
//warning, you are outside of PPB limits
if(AdcaRegs.ADCEVTSTAT.bit.PPB1ZERO)
//voltage exceeded high limit
asm(" ESTOP0");
Toggle_count++;
//clear the trip flag and continue
AdcaRegs.ADCEVTCLR.bit.PPB1ZERO = 1;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP10;
// End of file
