Hi
I recently designed custom board for the F28075 with the intention to use INTOSC2 as the main oscillator. the board connects to JTAG fine with no issues however when I deploy the code and run the MCU nothing comes out, No PWM signals. I use the examples provided in the resource explorer and checked SysCtrl file to check that INTOSC2 is used to feed the PLL.
Can anyone know what might be the problem?
Thank you
Ahmed
Hi Ahmed,
Can you check if your code is getting stuck through debugger? Also, how are you supplying power on your board, are they rated for max currents as specified in the data sheet?
Nirav
