We have a project with a TMS320f28388x using en ethernet/UDP interface.
Is there a documentation or an example for this.
Thanks a lot
Alain
Thanks a lot
Alain
HI Alain,
Thanks for reaching out to C2000 E2E forum. Your query has been forwarded to the module expert.
Meanwhile, there are example CCS projects listed in the C2000Ware. Once installed, you can find the projects in the following directory.
<C2000WARE_INSTALL_PATH>\driverlib\f2838x\examples\cm\ethernet\
<C2000WARE_INSTALL_PATH>\driverlib\f2838x\examples\c28x_cm\ethernet\
You can find more details in the product technical reference manual.
http://www.ti.com/lit/ug/spruii0a/spruii0a.pdf
Hope this helps.
Thanks & Regards
Pramod
Hi Alain,
To add to what is told by Pramod, there are few stack based examples at
<C2000WARE_INSTALL_PATH>\libraries\communications\Ethernet.
Sudharsanan
