HV_SOLAR_DC_DC_Rev1,in the DPL_ISR function in the file Solar_DC_DC-DPL-ISR.asm,the following code:
.if(INCR_BUILD = 2)
ADCDRV_1ch 1 ; Ipfc
ADCDRV_1ch 2 ; Vpfc
ADCDRV_1ch 3 ; VL_fb
ADCDRV_1ch 4 ; VN_fb
CNTL_2P2Z 1
PWMDRV_1ch_UpDwnCnt 1 ; PWM1A
PWMDRV_1ch_UpDwnCnt 2 ; PWM2A
;PWMDRV_LLC_ComplPairDB 3 ;
MATH_EMAVG 1 ;
MATH_EMAVG 2
PWMDRV_1ch_UpDwnCnt 4 ; PWM4A
.endif
In build2 mode,first read the AD value of voltage and current,Next, control functions such as PID and data filtering are implemented by calling the CNTL_2P2Z function.The output of CNTL_2P2Z is stored in CNTL_2P2Z_Out(Q24) and CNTL_2P2Z_DBUFF(Q30).
_PWMDRV_1ch_UpDwnCnt_Duty and _PWMDRV_1ch_UpDwnCnt_Duty are input variables to the function PWMDRV_1ch_UpDwnCnt.
No relationship was found between the functions PWMDRV_1ch_UpDwnCnt and CNTL_2P2Z.
I don't know how the function PWMDRV_1ch_UpDwnCnt passes the output of CNTL_2P2Z is used to set the duty cycle.How is the current closed loop realized, from ad sampling to PID control, to the calculation and setting of the duty cycle?
Ren
