TMS320F28035 Watchdog
Other Parts Discussed in Thread: TMS320F28035
I make Watchdog procedures,always has some error,example,I use the TMS320F28035,
"C:/tidcs/c28/DSP2803x/v124/DSP2803x_common/source/DSP2803x_CodeStartBranch.asm", ERROR!   at line 69:
 [E0002]
         Invalid instruction for specified processor version
1 Assembly Error, No Assembly Warnings
     MOVZ DP, #7029h>>6  ;Set data page for WDCR register
How can i did?
     [E0002]
    How can i did?
    Yang,
    It sounds like perhaps the compiler options are not set to compile for the 28x.  Can you check that -v28 is being used in the compiler options?  It should be set by default in all of the TI example projects.
    -Lori
