Hi Expert,
Customer finds that the Index Event Latch function is disabled when configure "GpioCtrlRegs.QDECCTL.bit.SPSEL = 0;", however if set this bit, latch function works.
The explanation in TRM is "0h (R/W) = Index pin is used for sync output".
Could you explain the reason or you need more configure information, and what kind information to locate this issue?
Thanks!
Best Regards
Rayna
