We have a small project using the Delfino floating point MCU, and we have it working somewhat, but we are stuck and need some help on an hourly consulting basis. Austin area.
Thanks!
Thanks!
I am offering Delfino / Piccolo consulting contracts here in Europe, a little bit far away from Austin...
Arefeen,
No, I have not tried TI 3P. What is that?
I can try to find a professor here or grad student. That is a good idea.
If you have any references in my area (Austin, or Houston), please send.
Short description:
The device reads a transducer, performs a calculation loop, and actuates two external controls to change the motion. Any movement is then detected by the transducer, calculations again, actuation, movement.... in a loop. This part works ok. However, we need to capture and store the transducer data and some of the calculated numbers, and retrieve those data to a laptop after the device has finished its run. Secondly, we need to have the code remain resident. Also, we need to make sure we have configured everything robustly.
