CCS/TMS320F280049: Process list for compiler to compile CLA
Part Number: TMS320F280049
Hi team,
I am supporting my customer developing F280049. And we find whenever they compile a CLA project on their company computer, strange error would happens.
One thing come to our mind is that their computer has security S/W, and they need to give corresponding process used for compiling CLA the authority to access to local files.
Customer's IT tracked the active process when compiling, and the get a quite long list which they cannot give right to all of them. Thus customer is turning to TI whether we could tell which process is related to CCS compiling?
|ETHERCAT_SLAVE_SSC_AND_DEMO_SETUP.EXE|MAKEFSFILE.EXE|C2000WARE_3_01_00_00_UNINSTALLER.EXE|A.EXE|A.EXE|SERIAL_FLASH_PROGRAMMER.EXE|SERIAL_FLASH_PROGRAMMER_APPLN.EXE|USB_FLASH_PROGRAMMER.EXE|DFUPROG.EXE|USB_BULK_EXAMPLE.EXE|USB_BULK_EXAMPLE.EXE|USB_BULK_EXAMPLE_THROUGHPUT.EXE|USB_BULK_EXAMPLE.EXE|USB_BULK_EXAMPLE_THROUGHPUT.EXE|USB_BULK_EXAMPLE.EXE|USB_BULK_EXAMPLE_THROUGHPUT.EXE|USB_BULK_EXAMPLE.EXE|USB_BULK_EXAMPLE_THROUGHPUT.EXE|C2000WAREUPDATER.EXE|LSPROXY.EXE|NODE.EXE|FS.EXE|MSPAUTODETECTOR.EXE|XDS110RESET.EXE|XDSDFU.EXE|XDS2XX_CONF.EXE|XDS2XX_CURRENTMEASURE.EXE|XDS2XX_PORTCHK.EXE|DBGAUTH.EXE|DBGJTAG.EXE|DTC_CONF.EXE|GDB_AGENT_CONSOLE.EXE|PAT.EXE|SD560V2CONFIG.EXE|SD560V2U_KILLSERVER.EXE|SD560V2U_SERVER.EXE|XDS100SERIAL.EXE|BATCHDRIVERINSTALLER.EXE|CVRLH32.EXE|DRIVE_OFS.EXE|DSLITE.EXE|FLASHPYTHONSUBPROCESS.EXE|GTIREMOTEPROXYSERVER.EXE|OFS_DUMP.EXE|TICRASHMONITOR.EXE|STUNE.EXE|BIN2TDF.EXE|SMSETCONVERTER.EXE|TD.EXE|XDS_ECOM_SERVER.EXE|DASM_VCOP.EXE|DPINST32.EXE|DPINST64.EXE|BROWSERCORE64.EXE|JABSWITCH.EXE|JAVA-RMI.EXE|JAVA.EXE|JAVACPL.EXE|JAVAW.EXE|JAVAWS.EXE|JJS.EXE|JP2LAUNCHER.EXE|KEYTOOL.EXE|KINIT.EXE|KLIST.EXE|KTAB.EXE|ORBD.EXE|PACK200.EXE|POLICYTOOL.EXE|RMID.EXE|RMIREGISTRY.EXE|SERVERTOOL.EXE|SSVAGENT.EXE|TNAMESERV.EXE|UNPACK200.EXE|LISTTASKS.EXE|STARTER.EXE|WINPTY-AGENT.EXE|CCS_UPDATE_10.0.0.00010.EXE|CCSTUDIO.EXE|ECLIPSE.EXE|ECLIPSEC.EXE|NODE.EXE|UNZIP.EXE|ZIP.EXE|NODE.EXE|UNZIP.EXE|ZIP.EXE|ARMABS.EXE|ARMACPIA.EXE|ARMADV.EXE|ARMAR.EXE|ARMASM.EXE|ARMCG.EXE|ARMCL.EXE|ARMCLIST.EXE|ARMDEM.EXE|ARMDIS.EXE|ARMEMBED.EXE|ARMHEX.EXE|ARMILK.EXE|ARMLIBINFO.EXE|ARMLNK.EXE|ARMNM.EXE|ARMOBJCOPY.EXE|ARMOBJDUMP.EXE|ARMOFD.EXE|ARMOPT.EXE|ARMPDD.EXE|ARMPPROF.EXE|ARMREADELF.EXE|ARMSIZE.EXE|ARMSTRIP.EXE|ARMXREF.EXE|MKLIB.EXE|ABS2000.EXE|AC2000.EXE|ACCLA.EXE|ACIA2000.EXE|ACIACLA.EXE|ADV2000.EXE|AR2000.EXE|ASM2000.EXE|CG2000.EXE|CGCLA.EXE|CL2000.EXE|CLIST2000.EXE|DEM2000.EXE|DIS2000.EXE|EMBED2000.EXE|HEX2000.EXE|ILK2000.EXE|LIBINFO2000.EXE|LNK2000.EXE|NM2000.EXE|OFD2000.EXE|OPT2000.EXE|OPTCLA.EXE|PDD2000.EXE|PPROF2000.EXE|STRIP2000.EXE|XREF2000.EXE|MKLIB.EXE|NODE.EXE|TI_CGT_C2000_20.2.0.LTS_UNINSTALLER.EXE|TI_CGT_DMED_UNINSTALLER.EXE|TI_CGT_TMS470_20.2.0.LTS_UNINSTALLER.EXE|UNINSTALL_TIREX3.EXE|UNINSTALL_TIREX4.EXE|UNINSTALL_TI_DSPACK.EXE|UNINSTALL_TI_EMUPACK_9.1.0.00001.BIN.EXE|GMAKE.EXE|UNZIP.EXE|ZIP.EXE|CAT.EXE|CMP.EXE|CMV.EXE|CP.EXE|DATE.EXE|ECHO.EXE|FIXDEP.EXE|FIXLIST.EXE|GUNZIP.EXE|GZIP.EXE|MKDEP.EXE|MKDIR.EXE|MV.EXE|PRINTARGS.EXE|PWD.EXE|RM.EXE|RXGEN.EXE|SED.EXE|SETDATE.EXE|SH.EXE|STDERR.EXE|TAR.EXE|TEE.EXE|TOUCH.EXE|UNZIP.EXE|VERS.EXE|ZIP.EXE|JABSWITCH.EXE|JAVA-RMI.EXE|JAVA.EXE|JAVACPL.EXE|JAVAW.EXE|JAVAWS.EXE|JJS.EXE|JP2LAUNCHER.EXE|KEYTOOL.EXE|KINIT.EXE|KLIST.EXE|KTAB.EXE|ORBD.EXE|PACK200.EXE|POLICYTOOL.EXE|RMID.EXE|RMIREGISTRY.EXE|SERVERTOOL.EXE|SSVAGENT.EXE|TNAMESERV.EXE|UNPACK200.EXE|MKHEX4BIN.EXE|UNINSTALL_CCS.EXE|CAT.EXE|CMP.EXE|CMV.EXE|CP.EXE|DATE.EXE|ECHO.EXE|FIXDEP.EXE|FIXLIST.EXE|GUNZIP.EXE|GZIP.EXE|MKDEP.EXE|MKDIR.EXE|MV.EXE|PRINTARGS.EXE|PWD.EXE|RM.EXE|RXGEN.EXE|SED.EXE|SETDATE.EXE|SH.EXE|STDERR.EXE|TAR.EXE|TEE.EXE|TOUCH.EXE|UNZIP.EXE|VERS.EXE|XDCCPP.EXE|XDCDIR.EXE|XDCENV.EXE|XDCLPF.EXE|XDCPATH.EXE|XDCPKG.EXE|XDCRMP.EXE|ZIP.EXE|PATH2DOS.EXE|GMAKE.EXE|XDC.EXE|XS.EXE
|ETHERCAT_SLAVE_SSC_AND_DEMO_SETUP|MAKEFSFILE|C2000WARE_3_01_00_00_UNINSTALLER|A|A|SERIAL_FLASH_PROGRAMMER|SERIAL_FLASH_PROGRAMMER_APPLN|USB_FLASH_PROGRAMMER|DFUPROG|USB_BULK_EXAMPLE|USB_BULK_EXAMPLE|USB_BULK_EXAMPLE_THROUGHPUT|USB_BULK_EXAMPLE|USB_BULK_EXAMPLE_THROUGHPUT|USB_BULK_EXAMPLE|USB_BULK_EXAMPLE_THROUGHPUT|USB_BULK_EXAMPLE|USB_BULK_EXAMPLE_THROUGHPUT|C2000WAREUPDATER|LSPROXY|NODE|FS|MSPAUTODETECTOR|XDS110RESET|XDSDFU|XDS2XX_CONF|XDS2XX_CURRENTMEASURE|XDS2XX_PORTCHK|DBGAUTH|DBGJTAG|DTC_CONF|GDB_AGENT_CONSOLE|PAT|SD560V2CONFIG|SD560V2U_KILLSERVER|SD560V2U_SERVER|XDS100SERIAL|BATCHDRIVERINSTALLER|CVRLH32|DRIVE_OFS|DSLITE|FLASHPYTHONSUBPROCESS|GTIREMOTEPROXYSERVER|OFS_DUMP|TICRASHMONITOR|STUNE|BIN2TDF|SMSETCONVERTER|TD|XDS_ECOM_SERVER|DASM_VCOP|DPINST32|DPINST64|BROWSERCORE64|JABSWITCH|JAVA-RMI|JAVA|JAVACPL|JAVAW|JAVAWS|JJS|JP2LAUNCHER|KEYTOOL|KINIT|KLIST|KTAB|ORBD|PACK200|POLICYTOOL|RMID|RMIREGISTRY|SERVERTOOL|SSVAGENT|TNAMESERV|UNPACK200|LISTTASKS|STARTER|WINPTY-AGENT|CCS_UPDATE_10.0.0.00010|CCSTUDIO|ECLIPSE|ECLIPSEC|NODE|UNZIP|ZIP|NODE|UNZIP|ZIP|ARMABS|ARMACPIA|ARMADV|ARMAR|ARMASM|ARMCG|ARMCL|ARMCLIST|ARMDEM|ARMDIS|ARMEMBED|ARMHEX|ARMILK|ARMLIBINFO|ARMLNK|ARMNM|ARMOBJCOPY|ARMOBJDUMP|ARMOFD|ARMOPT|ARMPDD|ARMPPROF|ARMREADELF|ARMSIZE|ARMSTRIP|ARMXREF|MKLIB|ABS2000|AC2000|ACCLA|ACIA2000|ACIACLA|ADV2000|AR2000|ASM2000|CG2000|CGCLA|CL2000|CLIST2000|DEM2000|DIS2000|EMBED2000|HEX2000|ILK2000|LIBINFO2000|LNK2000|NM2000|OFD2000|OPT2000|OPTCLA|PDD2000|PPROF2000|STRIP2000|XREF2000|MKLIB|NODE|TI_CGT_C2000_20.2.0.LTS_UNINSTALLER|TI_CGT_DMED_UNINSTALLER|TI_CGT_TMS470_20.2.0.LTS_UNINSTALLER|UNINSTALL_TIREX3|UNINSTALL_TIREX4|UNINSTALL_TI_DSPACK|UNINSTALL_TI_EMUPACK_9.1.0.00001.BIN|GMAKE|UNZIP|ZIP|CAT|CMP|CMV|CP|DATE|ECHO|FIXDEP|FIXLIST|GUNZIP|GZIP|MKDEP|MKDIR|MV|PRINTARGS|PWD|RM|RXGEN|SED|SETDATE|SH|STDERR|TAR|TEE|TOUCH|UNZIP|VERS|ZIP|JABSWITCH|JAVA-RMI|JAVA|JAVACPL|JAVAW|JAVAWS|JJS|JP2LAUNCHER|KEYTOOL|KINIT|KLIST|KTAB|ORBD|PACK200|POLICYTOOL|RMID|RMIREGISTRY|SERVERTOOL|SSVAGENT|TNAMESERV|UNPACK200|MKHEX4BIN|UNINSTALL_CCS|CAT|CMP|CMV|CP|DATE|ECHO|FIXDEP|FIXLIST|GUNZIP|GZIP|MKDEP|MKDIR|MV|PRINTARGS|PWD|RM|RXGEN|SED|SETDATE|SH|STDERR|TAR|TEE|TOUCH|UNZIP|VERS|XDCCPP|XDCDIR|XDCENV|XDCLPF|XDCPATH|XDCPKG|XDCRMP|ZIP|PATH2DOS|GMAKE|XDC|XS
Brian
