TMS320F2812: TMS320F2812PGFA check sum NG after programming
Part Number: TMS320F2812
We found IC EMR180038P1 tested fail when produced EMR417501G1, the defect rate is 40%. The initial analysis result as below.
    • The D/C of defect EMR180038P1 is concentrate on CG-88C5XQW (100%), another D/C CG-94CON3W is good.
    • Verify the checksum of 3pcs IC which had been internal programed and found 2pcs failed, our programing TE suspect that the raw material is nonblank part.
