Part Number: TIDM-1000
How is the value of 1.32 in (VIENNA_vBUSRef_pu) configure in the code? In what line of the code composer studio?
Thank you,
Neguse G.
Thank you,
Neguse G.
Hi Negus,
Which device are you using? if it is f2837x or f28004x, it is preset by the code below in Vienna.c
VIENNA_vBusRef_pu = ((float32_t)VIENNA_VBUS_REF_SET_VOLTS /
(float32_t)VIENNA_V_MAX_SENSE_VOLTS );
If it is f2838x, it is also possible to be set through ethernet GUI.
VIENNA_vBusRef_pu = ETHERNET_vBusRef_pu;
Chen
