CCS/TMS320F28388D: How do I observe the process of and/or results of the Flash API examples using the debugger?
Part Number: TMS320F28388D
For the Flash programming examples in driverlib/f2838x/examples/c28x/flash or driverlib/f2838x/examples/cm/flash, how does one observe the effects of the Flash programming process in CCS?
I know it involves the debugger, but my usage of the debugger mostly involves stepping through the lines of code and observing the changes in the variable values. I am also aware of the Registers tab, but I haven't used that beyond checking to see if my program has faulted.
  • Hi Howard,
    You can open a memory window in CCS and enter the address that you would like to watch being programmed.  However, please note that flash reads are not allowed during flash erase/program operations.  Hence, it is not suggested to open a memory window to flash/OTP address when you erase or program.  You can open the address before and after the flash operation.
    Did you already use breakpoints?
    Thanks and regards,
    Vamsi
