I am using this DSP for a PWM motor control application. I am trying to set an appropriate dead time for my systems but can’t seem to figure out what is the propagation delay through the DSP and the channel to channel skew. Then another component is the PWM resolution delay. My questions are listed below. Please point me to the right person who can help.
I found table 5-60 that mentions delay time of 25ns. Is this the DSP delay from input to output for any given GPIO pin or channel?
Am I correct to assume the propagation delay is due to any gates the signal has to go through and line length?
Does the DSP resolution play a role in the overall propagation delay in the DSP?
If so, how does DSP delay differ from DSP resolution delay?
Am I correct to assume resolution is based on how high the clock frequency is to determine where the signal is set based on logic.
