Other Parts Discussed in Thread: DRV8353, , DRV8353RS-EVM
I have a weird problem. I did my own hardware, based on an evaluation board. I'm using F28069F and DRV8353S.
It is based on the DRV8353-EVM board.
But I can't get it working with lab02a, every time it tries to identify the motor, it fails.
What is happening?
RoverL - motor not spinning, but a noisy tone. Then it switches to EST_State_RS, motor start spinning for half a second or so and then a loud 'KLONK', debugging session aborts, voltage drops on supply power shortly...
I really do not know what I'm missing here...
I did change in the user.h the following:
USER_ADC_FULL_SCALE_VOLTAGE_V according to my Voltage divider (see attached schematic): (129.69) (slightly different to the EVM board, because I'm using 10k resistor instead of 9.76.
USER_ADC_FULL_SCALE_CURRENT_A (according to my Gain setting 10V/V) : 47.14 A (like DRV8353 EVM)
USER_VOLTAGE_FILTER_POLE_Hz according to my HW --> 347.49
Although I was so desperate, that I tried the modified project 05b from the evaluation board (which TI is providing) and motor does spin, but only when I disable Motor identification and I had to double the USER_ADC_FULL_SCALE_CURRENT_A to 94.28A value, but it is not correct then, but this would be not correct for my hardware. I disabled the PWMDataWrite and put 1A over the shunt resistor and I was able to see, that then the corresponding value in A was 2A instead of 1A. When I put it back to the correct value of 47.14A, then I see 1A when I apply 1A, motor does spin, but horribly. Motor makes a lot of noise. And as I said Motor Identification does not work regardless which current setting value.
this is my calculation for getting it back from the pu values:
gMotorVars.I_1_A = _IQmpy(gAdcData.I.value[0], _IQ(USER_IQ_FULL_SCALE_CURRENT_A)); gMotorVars.I_2_A = _IQmpy(gAdcData.I.value[1], _IQ(USER_IQ_FULL_SCALE_CURRENT_A)); gMotorVars.I_3_A = _IQmpy(gAdcData.I.value[2], _IQ(USER_IQ_FULL_SCALE_CURRENT_A)); gMotorVars.V_1_A = _IQmpy(gAdcData.V.value[0], _IQ(USER_IQ_FULL_SCALE_VOLTAGE_V)); gMotorVars.V_2_A = _IQmpy(gAdcData.V.value[1], _IQ(USER_IQ_FULL_SCALE_VOLTAGE_V)); gMotorVars.V_3_A = _IQmpy(gAdcData.V.value[2], _IQ(USER_IQ_FULL_SCALE_VOLTAGE_V));
I checked and these values are really correct. So the measurement is ok from my point of view... What kind of other information does instaspin need ?
So, I do something miss here in the lab02b, but I do not know what...
Attached is my user.h, my project file, my hal.c,, hal.h, my drv8353.c and drv8353.h
/* --COPYRIGHT--,BSD * Copyright (c) 2012, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ //! \file solutions/instaspin_foc/src/proj_lab02a.c //! \brief Using InstaSPIN�FOC for the first time, Motor ID, full control system from ROM //! //! (C) Copyright 2011, Texas Instruments, Inc. //! \defgroup PROJ_LAB02a PROJ_LAB02a //@{ //! \defgroup PROJ_LAB02a_OVERVIEW Project Overview //! //! Using InstaSPIN�FOC for the first time, Motor ID, full control system from ROM //! // ************************************************************************** // the includes // system includes #include <math.h> #include "main.h" #ifdef FLASH #pragma CODE_SECTION(mainISR,"ramfuncs"); #endif // Include header files used in the main function // ************************************************************************** // the defines #define LED_BLINK_FREQ_Hz 5 // ************************************************************************** // the globals uint_least16_t gCounter_updateGlobals = 0; bool Flag_Latch_softwareUpdate = true; CTRL_Handle ctrlHandle; #ifdef CSM_ENABLE #pragma DATA_SECTION(halHandle,"rom_accessed_data"); #endif HAL_Handle halHandle; #ifdef CSM_ENABLE #pragma DATA_SECTION(gUserParams,"rom_accessed_data"); #endif USER_Params gUserParams; HAL_PwmData_t gPwmData = {_IQ(0.0), _IQ(0.0), _IQ(0.0)}; HAL_AdcData_t gAdcData; _iq gMaxCurrentSlope = _IQ(0.0); #ifdef FAST_ROM_V1p6 CTRL_Obj *controller_obj; #else #ifdef CSM_ENABLE #pragma DATA_SECTION(ctrl,"rom_accessed_data"); #endif CTRL_Obj ctrl; //v1p7 format #endif uint16_t gLEDcnt = 0; volatile MOTOR_Vars_t gMotorVars = MOTOR_Vars_INIT; #ifdef FLASH // Used for running BackGround in flash, and ISR in RAM extern uint16_t *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart; #ifdef CSM_ENABLE extern uint16_t *econst_start, *econst_end, *econst_ram_load; extern uint16_t *switch_start, *switch_end, *switch_ram_load; #endif #endif #ifdef DRV8301_SPI // Watch window interface to the 8301 SPI DRV_SPI_8301_Vars_t gDrvSpi8301Vars; #endif #ifdef DRV8305_SPI // Watch window interface to the 8305 SPI DRV_SPI_8305_Vars_t gDrvSpi8305Vars; #endif #ifdef DRV8353_SPI // Watch window interface to the 8305 SPI DRV_SPI_8353_Vars_t gDrvSpi8353Vars; #endif // ************************************************************************** // the functions void main(void) { uint_least8_t estNumber = 0; #ifdef FAST_ROM_V1p6 uint_least8_t ctrlNumber = 0; #endif // Only used if running from FLASH // Note that the variable FLASH is defined by the project #ifdef FLASH // Copy time critical code and Flash setup code to RAM // The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart // symbols are created by the linker. Refer to the linker files. memCopy((uint16_t *)&RamfuncsLoadStart,(uint16_t *)&RamfuncsLoadEnd,(uint16_t *)&RamfuncsRunStart); #ifdef CSM_ENABLE //copy .econst to unsecure RAM if(*econst_end - *econst_start) { memCopy((uint16_t *)&econst_start,(uint16_t *)&econst_end,(uint16_t *)&econst_ram_load); } //copy .switch ot unsecure RAM if(*switch_end - *switch_start) { memCopy((uint16_t *)&switch_start,(uint16_t *)&switch_end,(uint16_t *)&switch_ram_load); } #endif #endif // initialize the hardware abstraction layer halHandle = HAL_init(&hal,sizeof(hal)); // check for errors in user parameters USER_checkForErrors(&gUserParams); // store user parameter error in global variable gMotorVars.UserErrorCode = USER_getErrorCode(&gUserParams); // do not allow code execution if there is a user parameter error if(gMotorVars.UserErrorCode != USER_ErrorCode_NoError) { for(;;) { gMotorVars.Flag_enableSys = false; } } // initialize the user parameters USER_setParams(&gUserParams); // set the hardware abstraction layer parameters HAL_setParams(halHandle,&gUserParams); // initialize the controller #ifdef FAST_ROM_V1p6 ctrlHandle = CTRL_initCtrl(ctrlNumber, estNumber); //v1p6 format (06xF and 06xM devices) controller_obj = (CTRL_Obj *)ctrlHandle; #else ctrlHandle = CTRL_initCtrl(estNumber,&ctrl,sizeof(ctrl)); //v1p7 format default #endif { CTRL_Version version; // get the version number CTRL_getVersion(ctrlHandle,&version); gMotorVars.CtrlVersion = version; } // set the default controller parameters CTRL_setParams(ctrlHandle,&gUserParams); // setup faults HAL_setupFaults(halHandle); // initialize the interrupt vector table HAL_initIntVectorTable(halHandle); // enable the ADC interrupts HAL_enableAdcInts(halHandle); // enable global interrupts HAL_enableGlobalInts(halHandle); // enable debug interrupts HAL_enableDebugInt(halHandle); // disable the PWM HAL_disablePwm(halHandle); #ifdef DRV8301_SPI // turn on the DRV8301 if present HAL_enableDrv(halHandle); // initialize the DRV8301 interface HAL_setupDrvSpi(halHandle,&gDrvSpi8301Vars); #endif #ifdef DRV8305_SPI // turn on the DRV8305 if present HAL_enableDrv(halHandle); // initialize the DRV8305 interface HAL_setupDrvSpi(halHandle,&gDrvSpi8305Vars); #endif #ifdef DRV8353 HAL_enableDrv(halHandle); #endif #ifdef DRV8353_SPI // initialize the DRV8353 interface HAL_setupDrvSpi(halHandle,&gDrvSpi8353Vars); #endif // enable DC bus compensation CTRL_setFlag_enableDcBusComp(ctrlHandle, true); for(;;) { // Waiting for enable system flag to be set while(!(gMotorVars.Flag_enableSys)); // loop while the enable system flag is true while(gMotorVars.Flag_enableSys) { CTRL_Obj *obj = (CTRL_Obj *)ctrlHandle; // increment counters gCounter_updateGlobals++; if(CTRL_isError(ctrlHandle)) { // set the enable controller flag to false CTRL_setFlag_enableCtrl(ctrlHandle,false); // set the enable system flag to false gMotorVars.Flag_enableSys = false; // disable the PWM HAL_disablePwm(halHandle); } else { // update the controller state bool flag_ctrlStateChanged = CTRL_updateState(ctrlHandle); // enable or disable the control CTRL_setFlag_enableCtrl(ctrlHandle, gMotorVars.Flag_Run_Identify); if(flag_ctrlStateChanged) { CTRL_State_e ctrlState = CTRL_getState(ctrlHandle); EST_State_e estState = EST_getState(obj->estHandle); if(ctrlState == CTRL_State_OffLine) { // enable the PWM HAL_enablePwm(halHandle); } else if(ctrlState == CTRL_State_OnLine) { if((estState < EST_State_LockRotor) || (estState > EST_State_MotorIdentified)) { // update the ADC bias values HAL_updateAdcBias(halHandle); } // Return the bias value for currents gMotorVars.I_bias.value[0] = HAL_getBias(halHandle,HAL_SensorType_Current,0); gMotorVars.I_bias.value[1] = HAL_getBias(halHandle,HAL_SensorType_Current,1); gMotorVars.I_bias.value[2] = HAL_getBias(halHandle,HAL_SensorType_Current,2); // Return the bias value for voltages gMotorVars.V_bias.value[0] = HAL_getBias(halHandle,HAL_SensorType_Voltage,0); gMotorVars.V_bias.value[1] = HAL_getBias(halHandle,HAL_SensorType_Voltage,1); gMotorVars.V_bias.value[2] = HAL_getBias(halHandle,HAL_SensorType_Voltage,2); // enable the PWM HAL_enablePwm(halHandle); } else if(ctrlState == CTRL_State_Idle) { // disable the PWM HAL_disablePwm(halHandle); gMotorVars.Flag_Run_Identify = false; } if((CTRL_getFlag_enableUserMotorParams(ctrlHandle) == true) && (ctrlState > CTRL_State_Idle) && (gMotorVars.CtrlVersion.minor == 6)) { // call this function to fix 1p6 USER_softwareUpdate1p6(ctrlHandle); } } } if(EST_isMotorIdentified(obj->estHandle)) { // set the current ramp EST_setMaxCurrentSlope_pu(obj->estHandle,gMaxCurrentSlope); gMotorVars.Flag_MotorIdentified = true; // set the speed reference CTRL_setSpd_ref_krpm(ctrlHandle,gMotorVars.SpeedRef_krpm); // set the speed acceleration CTRL_setMaxAccel_pu(ctrlHandle,_IQmpy(MAX_ACCEL_KRPMPS_SF,gMotorVars.MaxAccel_krpmps)); if(Flag_Latch_softwareUpdate) { Flag_Latch_softwareUpdate = false; USER_calcPIgains(ctrlHandle); } } else { Flag_Latch_softwareUpdate = true; // the estimator sets the maximum current slope during identification gMaxCurrentSlope = EST_getMaxCurrentSlope_pu(obj->estHandle); } // when appropriate, update the global variables if(gCounter_updateGlobals >= NUM_MAIN_TICKS_FOR_GLOBAL_VARIABLE_UPDATE) { // reset the counter gCounter_updateGlobals = 0; updateGlobalVariables_motor(ctrlHandle); } // recalculate Kp and Ki gains to fix the R/L limitation of 2000.0, and Kp limit to 0.11 recalcKpKi(ctrlHandle); if(CTRL_getMotorType(ctrlHandle) == MOTOR_Type_Induction) { // set electrical frequency limit to zero while identifying an induction motor setFeLimitZero(ctrlHandle); // calculate Dir_qFmt for acim motors acim_Dir_qFmtCalc(ctrlHandle); } // enable/disable the forced angle EST_setFlag_enableForceAngle(obj->estHandle,gMotorVars.Flag_enableForceAngle); // enable or disable power warp CTRL_setFlag_enablePowerWarp(ctrlHandle,gMotorVars.Flag_enablePowerWarp); #ifdef DRV8301_SPI HAL_writeDrvData(halHandle,&gDrvSpi8301Vars); HAL_readDrvData(halHandle,&gDrvSpi8301Vars); #endif #ifdef DRV8305_SPI HAL_writeDrvData(halHandle,&gDrvSpi8305Vars); HAL_readDrvData(halHandle,&gDrvSpi8305Vars); #endif #ifdef DRV8353_SPI HAL_writeDrvData(halHandle,&gDrvSpi8353Vars); HAL_readDrvData(halHandle,&gDrvSpi8353Vars); #endif } // end of while(gFlag_enableSys) loop // disable the PWM HAL_disablePwm(halHandle); // set the default controller parameters (Reset the control to re-identify the motor) CTRL_setParams(ctrlHandle,&gUserParams); gMotorVars.Flag_Run_Identify = false; } // end of for(;;) loop } // end of main() function interrupt void mainISR(void) { HAL_PwmData_t negPwmData = {_IQ(0.0), _IQ(0.0), _IQ(0.0)}; // acknowledge the ADC interrupt HAL_acqAdcInt(halHandle,ADC_IntNumber_1); // convert the ADC data HAL_readAdcData(halHandle,&gAdcData); // run the controller CTRL_run(ctrlHandle,halHandle,&gAdcData,&negPwmData); // negate PwmData generated by SVGEN module in ROM gPwmData.Tabc.value[0] = _IQmpy(negPwmData.Tabc.value[0], _IQ(-1.0)); gPwmData.Tabc.value[1] = _IQmpy(negPwmData.Tabc.value[1], _IQ(-1.0)); gPwmData.Tabc.value[2] = _IQmpy(negPwmData.Tabc.value[2], _IQ(-1.0)); // write the PWM compare values HAL_writePwmData(halHandle,&gPwmData); // setup the controller CTRL_setup(ctrlHandle); return; } // end of mainISR() function void updateGlobalVariables_motor(CTRL_Handle handle) { CTRL_Obj *obj = (CTRL_Obj *)handle; // get the speed estimate gMotorVars.Speed_krpm = EST_getSpeed_krpm(obj->estHandle); // get the real time speed reference coming out of the speed trajectory generator gMotorVars.SpeedTraj_krpm = _IQmpy(CTRL_getSpd_int_ref_pu(handle),EST_get_pu_to_krpm_sf(obj->estHandle)); // get the magnetizing current gMotorVars.MagnCurr_A = EST_getIdRated(obj->estHandle); // get the rotor resistance gMotorVars.Rr_Ohm = EST_getRr_Ohm(obj->estHandle); // get the stator resistance gMotorVars.Rs_Ohm = EST_getRs_Ohm(obj->estHandle); // get the stator inductance in the direct coordinate direction gMotorVars.Lsd_H = EST_getLs_d_H(obj->estHandle); // get the stator inductance in the quadrature coordinate direction gMotorVars.Lsq_H = EST_getLs_q_H(obj->estHandle); // get the flux gMotorVars.Flux_VpHz = EST_getFlux_VpHz(obj->estHandle); // get the controller state gMotorVars.CtrlState = CTRL_getState(handle); // get the estimator state gMotorVars.EstState = EST_getState(obj->estHandle); // Get the DC buss voltage gMotorVars.VdcBus_kV = _IQmpy(gAdcData.dcBus,_IQ(USER_IQ_FULL_SCALE_VOLTAGE_V/1000.0)); return; } // end of updateGlobalVariables_motor() function void recalcKpKi(CTRL_Handle handle) { CTRL_Obj *obj = (CTRL_Obj *)handle; EST_State_e EstState = EST_getState(obj->estHandle); if((EST_isMotorIdentified(obj->estHandle) == false) && (EstState == EST_State_Rs)) { float_t Lhf = CTRL_getLhf(handle); float_t Rhf = CTRL_getRhf(handle); float_t RhfoverLhf = Rhf/Lhf; _iq Kp = _IQ(0.25*Lhf*USER_IQ_FULL_SCALE_CURRENT_A/(USER_CTRL_PERIOD_sec*USER_IQ_FULL_SCALE_VOLTAGE_V)); _iq Ki = _IQ(RhfoverLhf*USER_CTRL_PERIOD_sec); // set Rhf/Lhf CTRL_setRoverL(handle,RhfoverLhf); // set the controller proportional gains CTRL_setKp(handle,CTRL_Type_PID_Id,Kp); CTRL_setKp(handle,CTRL_Type_PID_Iq,Kp); // set the Id controller gains CTRL_setKi(handle,CTRL_Type_PID_Id,Ki); PID_setKi(obj->pidHandle_Id,Ki); // set the Iq controller gains CTRL_setKi(handle,CTRL_Type_PID_Iq,Ki); PID_setKi(obj->pidHandle_Iq,Ki); } return; } // end of recalcKpKi() function void setFeLimitZero(CTRL_Handle handle) { CTRL_Obj *obj = (CTRL_Obj *)handle; EST_State_e EstState = EST_getState(obj->estHandle); _iq fe_neg_max_pu; _iq fe_pos_min_pu; if((EST_isMotorIdentified(obj->estHandle) == false) && (CTRL_getMotorType(handle) == MOTOR_Type_Induction)) { fe_neg_max_pu = _IQ30(0.0); fe_pos_min_pu = _IQ30(0.0); } else { fe_neg_max_pu = _IQ30(-USER_ZEROSPEEDLIMIT); fe_pos_min_pu = _IQ30(USER_ZEROSPEEDLIMIT); } EST_setFe_neg_max_pu(obj->estHandle, fe_neg_max_pu); EST_setFe_pos_min_pu(obj->estHandle, fe_pos_min_pu); return; } // end of setFeLimitZero() function void acim_Dir_qFmtCalc(CTRL_Handle handle) { CTRL_Obj *obj = (CTRL_Obj *)handle; EST_State_e EstState = EST_getState(obj->estHandle); if(EstState == EST_State_IdRated) { EST_setDir_qFmt(obj->estHandle, EST_computeDirection_qFmt(obj->estHandle, 0.7)); } return; } // end of acim_Dir_qFmtCalc() function //@} //defgroup // end of file
/* --COPYRIGHT--,BSD * Copyright (c) 2012, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ //! \file solutions/instaspin_foc/boards/drv8301kit_revD/f28x/f2806xF/src/hal.c //! \brief Contains the various functions related to the HAL object (everything outside the CTRL system) //! //! (C) Copyright 2011, Texas Instruments, Inc. // ************************************************************************** // the includes // drivers // modules // platforms #include "hal.h" #include "user.h" #include "hal_obj.h" #ifdef FLASH #pragma CODE_SECTION(HAL_setupFlash,"ramfuncs"); #endif // ************************************************************************** // the defines #define US_TO_CNT(A) ((((long double) A * (long double)USER_SYSTEM_FREQ_MHz) - 9.0L) / 5.0L) // ************************************************************************** // the globals HAL_Obj hal; // ************************************************************************** // the functions void HAL_cal(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; // enable the ADC clock CLK_enableAdcClock(obj->clkHandle); // Run the Device_cal() function // This function copies the ADC and oscillator calibration values from TI reserved // OTP into the appropriate trim registers // This boot ROM automatically calls this function to calibrate the interal // oscillators and ADC with device specific calibration data. // If the boot ROM is bypassed by Code Composer Studio during the development process, // then the calibration must be initialized by the application ENABLE_PROTECTED_REGISTER_WRITE_MODE; (*Device_cal)(); DISABLE_PROTECTED_REGISTER_WRITE_MODE; // run offsets calibration in user's memory HAL_AdcOffsetSelfCal(handle); // run oscillator compensation HAL_OscTempComp(handle); // disable the ADC clock CLK_disableAdcClock(obj->clkHandle); return; } // end of HAL_cal() function void HAL_OscTempComp(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; uint16_t Temperature; // disable the ADCs ADC_disable(obj->adcHandle); // power up the bandgap circuit ADC_enableBandGap(obj->adcHandle); // set the ADC voltage reference source to internal ADC_setVoltRefSrc(obj->adcHandle,ADC_VoltageRefSrc_Int); // enable the ADC reference buffers ADC_enableRefBuffers(obj->adcHandle); // Set main clock scaling factor (max45MHz clock for the ADC module) ADC_setDivideSelect(obj->adcHandle,ADC_DivideSelect_ClkIn_by_2); // power up the ADCs ADC_powerUp(obj->adcHandle); // enable the ADCs ADC_enable(obj->adcHandle); // enable non-overlap mode ADC_enableNoOverlapMode(obj->adcHandle); // connect channel A5 internally to the temperature sensor ADC_setTempSensorSrc(obj->adcHandle, ADC_TempSensorSrc_Int); // set SOC0 channel select to ADCINA5 ADC_setSocChanNumber(obj->adcHandle, ADC_SocNumber_0, ADC_SocChanNumber_A5); // set SOC0 acquisition period to 26 ADCCLK ADC_setSocSampleDelay(obj->adcHandle, ADC_SocNumber_0, ADC_SocSampleDelay_64_cycles); // connect ADCINT1 to EOC0 ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_1, ADC_IntSrc_EOC0); // clear ADCINT1 flag ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_1); // enable ADCINT1 ADC_enableInt(obj->adcHandle, ADC_IntNumber_1); // force start of conversion on SOC0 ADC_setSocFrc(obj->adcHandle, ADC_SocFrc_0); // wait for end of conversion while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_1) == 0){} // clear ADCINT1 flag ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_1); Temperature = ADC_readResult(obj->adcHandle, ADC_ResultNumber_0); HAL_osc1Comp(handle, Temperature); HAL_osc2Comp(handle, Temperature); return; } // end of HAL_OscTempComp() function void HAL_osc1Comp(HAL_Handle handle, const int16_t sensorSample) { int16_t compOscFineTrim; HAL_Obj *obj = (HAL_Obj *)handle; ENABLE_PROTECTED_REGISTER_WRITE_MODE; compOscFineTrim = ((sensorSample - getRefTempOffset())*(int32_t)getOsc1FineTrimSlope() + OSC_POSTRIM_OFF + FP_ROUND )/FP_SCALE + getOsc1FineTrimOffset() - OSC_POSTRIM; if(compOscFineTrim > 31) { compOscFineTrim = 31; } else if(compOscFineTrim < -31) { compOscFineTrim = -31; } OSC_setTrim(obj->oscHandle, OSC_Number_1, HAL_getOscTrimValue(getOsc1CoarseTrim(), compOscFineTrim)); DISABLE_PROTECTED_REGISTER_WRITE_MODE; return; } // end of HAL_osc1Comp() function void HAL_osc2Comp(HAL_Handle handle, const int16_t sensorSample) { int16_t compOscFineTrim; HAL_Obj *obj = (HAL_Obj *)handle; ENABLE_PROTECTED_REGISTER_WRITE_MODE; compOscFineTrim = ((sensorSample - getRefTempOffset())*(int32_t)getOsc2FineTrimSlope() + OSC_POSTRIM_OFF + FP_ROUND )/FP_SCALE + getOsc2FineTrimOffset() - OSC_POSTRIM; if(compOscFineTrim > 31) { compOscFineTrim = 31; } else if(compOscFineTrim < -31) { compOscFineTrim = -31; } OSC_setTrim(obj->oscHandle, OSC_Number_2, HAL_getOscTrimValue(getOsc2CoarseTrim(), compOscFineTrim)); DISABLE_PROTECTED_REGISTER_WRITE_MODE; return; } // end of HAL_osc2Comp() function uint16_t HAL_getOscTrimValue(int16_t coarse, int16_t fine) { uint16_t regValue = 0; if(fine < 0) { regValue = ((-fine) | 0x20) << 9; } else { regValue = fine << 9; } if(coarse < 0) { regValue |= ((-coarse) | 0x80); } else { regValue |= coarse; } return regValue; } // end of HAL_getOscTrimValue() function void HAL_AdcOffsetSelfCal(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; uint16_t AdcConvMean; // disable the ADCs ADC_disable(obj->adcHandle); // power up the bandgap circuit ADC_enableBandGap(obj->adcHandle); // set the ADC voltage reference source to internal ADC_setVoltRefSrc(obj->adcHandle,ADC_VoltageRefSrc_Int); // enable the ADC reference buffers ADC_enableRefBuffers(obj->adcHandle); // Set main clock scaling factor (max45MHz clock for the ADC module) ADC_setDivideSelect(obj->adcHandle,ADC_DivideSelect_ClkIn_by_2); // power up the ADCs ADC_powerUp(obj->adcHandle); // enable the ADCs ADC_enable(obj->adcHandle); //Select VREFLO internal connection on B5 ADC_enableVoltRefLoConv(obj->adcHandle); //Select channel B5 for all SOC HAL_AdcCalChanSelect(handle, ADC_SocChanNumber_B5); //Apply artificial offset (+80) to account for a negative offset that may reside in the ADC core ADC_setOffTrim(obj->adcHandle, 80); //Capture ADC conversion on VREFLO AdcConvMean = HAL_AdcCalConversion(handle); //Set offtrim register with new value (i.e remove artical offset (+80) and create a two's compliment of the offset error) ADC_setOffTrim(obj->adcHandle, 80 - AdcConvMean); //Select external ADCIN5 input pin on B5 ADC_disableVoltRefLoConv(obj->adcHandle); return; } // end of HAL_AdcOffsetSelfCal() function void HAL_AdcCalChanSelect(HAL_Handle handle, const ADC_SocChanNumber_e chanNumber) { HAL_Obj *obj = (HAL_Obj *)handle; ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_8,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_9,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_10,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_11,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_12,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_13,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_14,chanNumber); ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_15,chanNumber); return; } // end of HAL_AdcCalChanSelect() function uint16_t HAL_AdcCalConversion(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; uint16_t index, SampleSize, Mean; uint32_t Sum; ADC_SocSampleDelay_e ACQPS_Value; index = 0; //initialize index to 0 SampleSize = 256; //set sample size to 256 (**NOTE: Sample size must be multiples of 2^x where is an integer >= 4) Sum = 0; //set sum to 0 Mean = 999; //initialize mean to known value //Set the ADC sample window to the desired value (Sample window = ACQPS + 1) ACQPS_Value = ADC_SocSampleDelay_7_cycles; ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_8,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_9,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_10,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_11,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_12,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_13,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_14,ACQPS_Value); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_15,ACQPS_Value); // Enabled ADCINT1 and ADCINT2 ADC_enableInt(obj->adcHandle, ADC_IntNumber_1); ADC_enableInt(obj->adcHandle, ADC_IntNumber_2); // Disable continuous sampling for ADCINT1 and ADCINT2 ADC_setIntMode(obj->adcHandle, ADC_IntNumber_1, ADC_IntMode_EOC); ADC_setIntMode(obj->adcHandle, ADC_IntNumber_2, ADC_IntMode_EOC); //ADCINTs trigger at end of conversion ADC_setIntPulseGenMode(obj->adcHandle, ADC_IntPulseGenMode_Prior); // Setup ADCINT1 and ADCINT2 trigger source ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_1, ADC_IntSrc_EOC6); ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_2, ADC_IntSrc_EOC14); // Setup each SOC's ADCINT trigger source ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_0, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_1, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_2, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_3, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_4, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_5, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_6, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_7, ADC_Int2TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_10, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_11, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_12, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_13, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_14, ADC_Int1TriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_15, ADC_Int1TriggersSOC); // Delay before converting ADC channels usDelay(US_TO_CNT(ADC_DELAY_usec)); ADC_setSocFrcWord(obj->adcHandle, 0x00FF); while( index < SampleSize ) { //Wait for ADCINT1 to trigger, then add ADCRESULT0-7 registers to sum while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_1) == 0){} //Must clear ADCINT1 flag since INT1CONT = 0 ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_1); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_0); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_1); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_2); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_3); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_4); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_5); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_6); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_7); //Wait for ADCINT2 to trigger, then add ADCRESULT8-15 registers to sum while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_2) == 0){} //Must clear ADCINT2 flag since INT2CONT = 0 ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_2); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_8); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_9); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_10); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_11); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_12); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_13); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_14); Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_15); index+=16; } // end data collection //Disable ADCINT1 and ADCINT2 to STOP the ping-pong sampling ADC_disableInt(obj->adcHandle, ADC_IntNumber_1); ADC_disableInt(obj->adcHandle, ADC_IntNumber_2); //Calculate average ADC sample value Mean = Sum / SampleSize; // Clear start of conversion trigger ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_0, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_1, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_2, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_3, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_4, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_5, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_6, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_7, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_10, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_11, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_12, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_13, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_14, ADC_NoIntTriggersSOC); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_15, ADC_NoIntTriggersSOC); //return the average return(Mean); } // end of HAL_AdcCalConversion() function void HAL_disableWdog(HAL_Handle halHandle) { HAL_Obj *hal = (HAL_Obj *)halHandle; WDOG_disable(hal->wdogHandle); return; } // end of HAL_disableWdog() function void HAL_disableGlobalInts(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; CPU_disableGlobalInts(obj->cpuHandle); return; } // end of HAL_disableGlobalInts() function void HAL_enableAdcInts(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; // enable the PIE interrupts associated with the ADC interrupts PIE_enableAdcInt(obj->pieHandle,ADC_IntNumber_1); // enable the ADC interrupts ADC_enableInt(obj->adcHandle,ADC_IntNumber_1); // enable the cpu interrupt for ADC interrupts CPU_enableInt(obj->cpuHandle,CPU_IntNumber_10); return; } // end of HAL_enableAdcInts() function void HAL_enableDebugInt(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; CPU_enableDebugInt(obj->cpuHandle); return; } // end of HAL_enableDebugInt() function void HAL_enableDrv(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; #ifdef DRV8301_SPI DRV8301_enable(obj->drv8301Handle); #endif #ifdef DRV8353 DRV8353_enable(obj->drv8353Handle); #endif return; } // end of HAL_enableDrv() function void HAL_enableGlobalInts(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; CPU_enableGlobalInts(obj->cpuHandle); return; } // end of HAL_enableGlobalInts() function void HAL_enablePwmInt(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; PIE_enablePwmInt(obj->pieHandle,PWM_Number_1); // enable the interrupt PWM_enableInt(obj->pwmHandle[PWM_Number_1]); // enable the cpu interrupt for EPWM1_INT CPU_enableInt(obj->cpuHandle,CPU_IntNumber_3); return; } // end of HAL_enablePwmInt() function void HAL_enableTimer0Int(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; PIE_enableTimer0Int(obj->pieHandle); // enable the interrupt TIMER_enableInt(obj->timerHandle[0]); // enable the cpu interrupt for TINT0 CPU_enableInt(obj->cpuHandle,CPU_IntNumber_1); return; } // end of HAL_enablePwmInt() function void HAL_setupFaults(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; uint_least8_t cnt; // Configure Trip Mechanism for the Motor control software // -Cycle by cycle trip on CPU halt // -One shot fault trip zone // These trips need to be repeated for EPWM1 ,2 & 3 for(cnt=0;cnt<3;cnt++) { PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ6_NOT); PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ3_NOT); PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ2_NOT); // What do we want the OST/CBC events to do? // TZA events can force EPWMxA // TZB events can force EPWMxB PWM_setTripZoneState_TZA(obj->pwmHandle[cnt],PWM_TripZoneState_EPWM_Low); PWM_setTripZoneState_TZB(obj->pwmHandle[cnt],PWM_TripZoneState_EPWM_Low); } return; } // end of HAL_setupFaults() function HAL_Handle HAL_init(void *pMemory,const size_t numBytes) { uint_least8_t cnt; HAL_Handle handle; HAL_Obj *obj; if(numBytes < sizeof(HAL_Obj)) return((HAL_Handle)NULL); // assign the handle handle = (HAL_Handle)pMemory; // assign the object obj = (HAL_Obj *)handle; // initialize the watchdog driver obj->wdogHandle = WDOG_init((void *)WDOG_BASE_ADDR,sizeof(WDOG_Obj)); // disable watchdog HAL_disableWdog(handle); // initialize the ADC obj->adcHandle = ADC_init((void *)ADC_BASE_ADDR,sizeof(ADC_Obj)); // initialize the clock handle obj->clkHandle = CLK_init((void *)CLK_BASE_ADDR,sizeof(CLK_Obj)); // initialize the CPU handle obj->cpuHandle = CPU_init(&cpu,sizeof(cpu)); // initialize the FLASH handle obj->flashHandle = FLASH_init((void *)FLASH_BASE_ADDR,sizeof(FLASH_Obj)); // initialize the GPIO handle obj->gpioHandle = GPIO_init((void *)GPIO_BASE_ADDR,sizeof(GPIO_Obj)); // initialize the current offset estimator handles for(cnt=0;cnt<USER_NUM_CURRENT_SENSORS;cnt++) { obj->offsetHandle_I[cnt] = OFFSET_init(&obj->offset_I[cnt],sizeof(obj->offset_I[cnt])); } // initialize the voltage offset estimator handles for(cnt=0;cnt<USER_NUM_VOLTAGE_SENSORS;cnt++) { obj->offsetHandle_V[cnt] = OFFSET_init(&obj->offset_V[cnt],sizeof(obj->offset_V[cnt])); } // initialize the oscillator handle obj->oscHandle = OSC_init((void *)OSC_BASE_ADDR,sizeof(OSC_Obj)); // initialize the PIE handle obj->pieHandle = PIE_init((void *)PIE_BASE_ADDR,sizeof(PIE_Obj)); // initialize the PLL handle obj->pllHandle = PLL_init((void *)PLL_BASE_ADDR,sizeof(PLL_Obj)); // initialize the SPI handles obj->spiAHandle = SPI_init((void *)SPIA_BASE_ADDR,sizeof(SPI_Obj)); //obj->spiBHandle = SPI_init((void *)SPIB_BASE_ADDR,sizeof(SPI_Obj)); // initialize PWM handles obj->pwmHandle[0] = PWM_init((void *)PWM_ePWM1_BASE_ADDR,sizeof(PWM_Obj)); obj->pwmHandle[1] = PWM_init((void *)PWM_ePWM2_BASE_ADDR,sizeof(PWM_Obj)); obj->pwmHandle[2] = PWM_init((void *)PWM_ePWM3_BASE_ADDR,sizeof(PWM_Obj)); // initialize PWM DAC handles obj->pwmDacHandle[0] = PWMDAC_init((void *)PWM_ePWM6_BASE_ADDR,sizeof(PWM_Obj)); obj->pwmDacHandle[1] = PWMDAC_init((void *)PWM_ePWM5_BASE_ADDR,sizeof(PWM_Obj)); obj->pwmDacHandle[2] = PWMDAC_init((void *)PWM_ePWM4_BASE_ADDR,sizeof(PWM_Obj)); // initialize power handle obj->pwrHandle = PWR_init((void *)PWR_BASE_ADDR,sizeof(PWR_Obj)); // initialize timer handles obj->timerHandle[0] = TIMER_init((void *)TIMER0_BASE_ADDR,sizeof(TIMER_Obj)); obj->timerHandle[1] = TIMER_init((void *)TIMER1_BASE_ADDR,sizeof(TIMER_Obj)); obj->timerHandle[2] = TIMER_init((void *)TIMER2_BASE_ADDR,sizeof(TIMER_Obj)); #ifdef DRV8301_SPI // initialize drv8301 interface obj->drv8301Handle = DRV8301_init(&obj->drv8301,sizeof(obj->drv8301)); #endif #ifdef DRV8353 // initialize drv8353 interface obj->drv8353Handle = DRV8353_init(&obj->drv8353,sizeof(obj->drv8353)); #endif #ifdef QEP // initialize QEP driver obj->qepHandle[0] = QEP_init((void*)QEP1_BASE_ADDR,sizeof(QEP_Obj)); #endif return(handle); } // end of HAL_init() function // void HAL_setParams(HAL_Handle handle,const USER_Params *pUserParams) { uint_least8_t cnt; HAL_Obj *obj = (HAL_Obj *)handle; _iq beta_lp_pu = _IQ(pUserParams->offsetPole_rps/(float_t)pUserParams->ctrlFreq_Hz); HAL_setNumCurrentSensors(handle,pUserParams->numCurrentSensors); HAL_setNumVoltageSensors(handle,pUserParams->numVoltageSensors); for(cnt=0;cnt<HAL_getNumCurrentSensors(handle);cnt++) { HAL_setOffsetBeta_lp_pu(handle,HAL_SensorType_Current,cnt,beta_lp_pu); HAL_setOffsetInitCond(handle,HAL_SensorType_Current,cnt,_IQ(0.0)); HAL_setOffsetValue(handle,HAL_SensorType_Current,cnt,_IQ(0.0)); } for(cnt=0;cnt<HAL_getNumVoltageSensors(handle);cnt++) { HAL_setOffsetBeta_lp_pu(handle,HAL_SensorType_Voltage,cnt,beta_lp_pu); HAL_setOffsetInitCond(handle,HAL_SensorType_Voltage,cnt,_IQ(0.0)); HAL_setOffsetValue(handle,HAL_SensorType_Voltage,cnt,_IQ(0.0)); } // disable global interrupts CPU_disableGlobalInts(obj->cpuHandle); // disable cpu interrupts CPU_disableInts(obj->cpuHandle); // clear cpu interrupt flags CPU_clearIntFlags(obj->cpuHandle); // setup the clocks HAL_setupClks(handle); // Setup the PLL HAL_setupPll(handle,PLL_ClkFreq_90_MHz); // setup the PIE HAL_setupPie(handle); // run the device calibration HAL_cal(handle); // setup the peripheral clocks HAL_setupPeripheralClks(handle); // setup the GPIOs HAL_setupGpios(handle); // setup the flash HAL_setupFlash(handle); // setup the ADCs HAL_setupAdcs(handle); // setup the PWMs HAL_setupPwms(handle, (float_t)pUserParams->systemFreq_MHz, pUserParams->pwmPeriod_usec, USER_NUM_PWM_TICKS_PER_ISR_TICK); #ifdef QEP // setup the QEP HAL_setupQEP(handle,HAL_Qep_QEP1); #endif // setup the spiA HAL_setupSpiA(handle); // setup the spiB //HAL_setupSpiB(handle); // setup the PWM DACs HAL_setupPwmDacs(handle); // setup the timers HAL_setupTimers(handle, (float_t)pUserParams->systemFreq_MHz); // setup the drv8301 interface HAL_setupGate(handle); // set the default current bias { uint_least8_t cnt; _iq bias = _IQ12mpy(ADC_dataBias,_IQ(pUserParams->current_sf)); for(cnt=0;cnt<HAL_getNumCurrentSensors(handle);cnt++) { HAL_setBias(handle,HAL_SensorType_Current,cnt,bias); } } // set the current scale factor { _iq current_sf = _IQ(pUserParams->current_sf); HAL_setCurrentScaleFactor(handle,current_sf); } // set the default voltage bias { uint_least8_t cnt; _iq bias = _IQ(0.0); for(cnt=0;cnt<HAL_getNumVoltageSensors(handle);cnt++) { HAL_setBias(handle,HAL_SensorType_Voltage,cnt,bias); } } // set the voltage scale factor { _iq voltage_sf = _IQ(pUserParams->voltage_sf); HAL_setVoltageScaleFactor(handle,voltage_sf); } return; } // end of HAL_setParams() function void HAL_setupAdcs(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; // disable the ADCs ADC_disable(obj->adcHandle); // power up the bandgap circuit ADC_enableBandGap(obj->adcHandle); // set the ADC voltage reference source to internal ADC_setVoltRefSrc(obj->adcHandle,ADC_VoltageRefSrc_Int); // enable the ADC reference buffers ADC_enableRefBuffers(obj->adcHandle); // Set main clock scaling factor (max45MHz clock for the ADC module) ADC_setDivideSelect(obj->adcHandle,ADC_DivideSelect_ClkIn_by_2); // power up the ADCs ADC_powerUp(obj->adcHandle); // enable the ADCs ADC_enable(obj->adcHandle); // set the ADC interrupt pulse generation to prior ADC_setIntPulseGenMode(obj->adcHandle,ADC_IntPulseGenMode_Prior); // set the temperature sensor source to external ADC_setTempSensorSrc(obj->adcHandle,ADC_TempSensorSrc_Ext); // configure the interrupt sources ADC_disableInt(obj->adcHandle,ADC_IntNumber_1); ADC_setIntMode(obj->adcHandle,ADC_IntNumber_1,ADC_IntMode_ClearFlag); ADC_setIntSrc(obj->adcHandle,ADC_IntNumber_1,ADC_IntSrc_EOC7); #ifdef DRV8301_SPI //configure the SOCs for drv8301kit_revD // EXT IA-FB ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,ADC_SocChanNumber_A6); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_0,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ADC_SocSampleDelay_9_cycles); // EXT IA-FB // Duplicate conversion due to ADC Initial Conversion bug (SPRZ342) ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,ADC_SocChanNumber_A6); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_1,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ADC_SocSampleDelay_9_cycles); // EXT IB-FB ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,ADC_SocChanNumber_B6); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_2,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ADC_SocSampleDelay_9_cycles); // EXT IC-FB ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,ADC_SocChanNumber_A0); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_3,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ADC_SocSampleDelay_9_cycles); // ADC-Vhb1 ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,ADC_SocChanNumber_B7); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_4,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ADC_SocSampleDelay_9_cycles); // ADC-Vhb2 ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,ADC_SocChanNumber_A7); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_5,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ADC_SocSampleDelay_9_cycles); // ADC-Vhb3 ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,ADC_SocChanNumber_B4); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_6,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ADC_SocSampleDelay_9_cycles); // VDCBUS ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,ADC_SocChanNumber_B2); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_7,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ADC_SocSampleDelay_9_cycles); // Potentiometer // Configure it so that ADCINT1 will trigger a potentiometer conversion ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_8,ADC_SocChanNumber_B0); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_Int1TriggersSOC); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_8,ADC_SocSampleDelay_9_cycles); #endif #ifdef DRV8353 //configure the SOCs for drv8353 custom board RT // EXT IA-FB ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,ADC_SocChanNumber_A6); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_0,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ADC_SocSampleDelay_9_cycles); // EXT IA-FB // Duplicate conversion due to ADC Initial Conversion bug (SPRZ342) ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,ADC_SocChanNumber_A6); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_1,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ADC_SocSampleDelay_9_cycles); // EXT IB-FB ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,ADC_SocChanNumber_A5); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_2,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ADC_SocSampleDelay_9_cycles); // EXT IC-FB ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,ADC_SocChanNumber_A4); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_3,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ADC_SocSampleDelay_9_cycles); // ADC-Vhb1 ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,ADC_SocChanNumber_A0); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_4,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ADC_SocSampleDelay_9_cycles); // ADC-Vhb2 ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,ADC_SocChanNumber_A1); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_5,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ADC_SocSampleDelay_9_cycles); // ADC-Vhb3 ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,ADC_SocChanNumber_A2); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_6,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ADC_SocSampleDelay_9_cycles); // VDCBUS ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,ADC_SocChanNumber_B0); ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_7,ADC_SocTrigSrc_EPWM1_ADCSOCA); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ADC_SocSampleDelay_9_cycles); // Torque // Configure it so that ADCINT1 will trigger a potentiometer conversion ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_8,ADC_SocChanNumber_B5); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_Int1TriggersSOC); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_8,ADC_SocSampleDelay_9_cycles); // Temperature // Configure it so that ADCINT1 will trigger a potentiometer conversion ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_9,ADC_SocChanNumber_B4); ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_Int1TriggersSOC); ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_9,ADC_SocSampleDelay_9_cycles); #endif return; } // end of HAL_setupAdcs() function void HAL_setupClks(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; // enable internal oscillator 1 CLK_enableOsc1(obj->clkHandle); // set the oscillator source CLK_setOscSrc(obj->clkHandle,CLK_OscSrc_Internal); // disable the external clock in CLK_disableClkIn(obj->clkHandle); // disable the crystal oscillator CLK_disableCrystalOsc(obj->clkHandle); // disable oscillator 2 CLK_disableOsc2(obj->clkHandle); // set the low speed clock prescaler CLK_setLowSpdPreScaler(obj->clkHandle,CLK_LowSpdPreScaler_SysClkOut_by_1); // set the clock out prescaler CLK_setClkOutPreScaler(obj->clkHandle,CLK_ClkOutPreScaler_SysClkOut_by_1); return; } // end of HAL_setupClks() function void HAL_setupFlash(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; FLASH_enablePipelineMode(obj->flashHandle); FLASH_setNumPagedReadWaitStates(obj->flashHandle,FLASH_NumPagedWaitStates_3); FLASH_setNumRandomReadWaitStates(obj->flashHandle,FLASH_NumRandomWaitStates_3); FLASH_setOtpWaitStates(obj->flashHandle,FLASH_NumOtpWaitStates_5); FLASH_setStandbyWaitCount(obj->flashHandle,FLASH_STANDBY_WAIT_COUNT_DEFAULT); FLASH_setActiveWaitCount(obj->flashHandle,FLASH_ACTIVE_WAIT_COUNT_DEFAULT); return; } // HAL_setupFlash() function void HAL_setupGate(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; #ifdef DRV8301_SPI DRV8301_setSpiHandle(obj->drv8301Handle,obj->spiBHandle); DRV8301_setGpioHandle(obj->drv8301Handle,obj->gpioHandle); DRV8301_setGpioNumber(obj->drv8301Handle,GPIO_Number_22); #endif #ifdef DRV8353 #ifdef DRV8353_SPI // if(gDeviceVariant) DRV8353_setSpiHandle(obj->drv8353Handle,obj->spiAHandle); #endif DRV8353_setGpioHandle(obj->drv8353Handle,obj->gpioHandle); DRV8353_setGpioNumber(obj->drv8353Handle,GPIO_Number_22); #endif return; } // HAL_setupGate() function void HAL_setupGpios(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; //PWM pinout definitions // PWM1 GPIO_setMode(obj->gpioHandle,GPIO_Number_0,GPIO_0_Mode_EPWM1A); // PWM2 GPIO_setMode(obj->gpioHandle,GPIO_Number_1,GPIO_1_Mode_EPWM1B); // PWM3 GPIO_setMode(obj->gpioHandle,GPIO_Number_2,GPIO_2_Mode_EPWM2A); // PWM4 GPIO_setMode(obj->gpioHandle,GPIO_Number_3,GPIO_3_Mode_EPWM2B); // PWM5 GPIO_setMode(obj->gpioHandle,GPIO_Number_4,GPIO_4_Mode_EPWM3A); // PWM6 GPIO_setMode(obj->gpioHandle,GPIO_Number_5,GPIO_5_Mode_EPWM3B); // Set Qualification Period for GPIO16-23, 5*2*(1/90MHz) = 0.11us GPIO_setQualificationPeriod(obj->gpioHandle,GPIO_Number_16,5); /*GPIO_setMode(obj->gpioHandle,GPIO_Number_16,GPIO_16_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_16); GPIO_setDirection(obj->gpioHandle,GPIO_Number_16,GPIO_Direction_Output); GPIO_setMode(obj->gpioHandle,GPIO_Number_17,GPIO_17_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_17); GPIO_setDirection(obj->gpioHandle,GPIO_Number_17,GPIO_Direction_Output); GPIO_setMode(obj->gpioHandle,GPIO_Number_18,GPIO_18_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_18); GPIO_setDirection(obj->gpioHandle,GPIO_Number_18,GPIO_Direction_Output); GPIO_setMode(obj->gpioHandle,GPIO_Number_19,GPIO_19_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_19); GPIO_setDirection(obj->gpioHandle,GPIO_Number_19,GPIO_Direction_Output);*/ // SPI-SIMO GPIO_setMode(obj->gpioHandle,GPIO_Number_16,GPIO_16_Mode_SPISIMOA); // GPIO_setPullup(obj->gpioHandle,GPIO_Number_16, GPIO_Pullup_Enable); // SPI-SOMI GPIO_setMode(obj->gpioHandle,GPIO_Number_17,GPIO_17_Mode_SPISOMIA); // GPIO_setPullup(obj->gpioHandle,GPIO_Number_17, GPIO_Pullup_Enable); // SPI-CLK GPIO_setMode(obj->gpioHandle,GPIO_Number_18,GPIO_18_Mode_SPICLKA); // GPIO_setPullup(obj->gpioHandle,GPIO_Number_18, GPIO_Pullup_Enable); // SPI-STE GPIO_setMode(obj->gpioHandle,GPIO_Number_19,GPIO_19_Mode_SPISTEA_NOT); // GPIO_setPullup(obj->gpioHandle,GPIO_Number_19, GPIO_Pullup_Enable); //GPIO 19 - Enable CS //GPIO_setMode(obj->gpioHandle,GPIO_Number_19,GPIO_19_Mode_GeneralPurpose); //GPIO_setHigh(obj->gpioHandle,GPIO_Number_19); //GPIO_setDirection(obj->gpioHandle,GPIO_Number_19,GPIO_Direction_Output); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_32,GPIO_32_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_33,GPIO_33_Mode_GeneralPurpose); // JTAG GPIO_setMode(obj->gpioHandle,GPIO_Number_35,GPIO_35_Mode_JTAG_TDI); GPIO_setMode(obj->gpioHandle,GPIO_Number_36,GPIO_36_Mode_JTAG_TMS); GPIO_setMode(obj->gpioHandle,GPIO_Number_37,GPIO_37_Mode_JTAG_TDO); GPIO_setMode(obj->gpioHandle,GPIO_Number_38,GPIO_38_Mode_JTAG_TCK); //evaluation board drv8301 #ifdef DRV8301_SPI // PWM-DAC1 GPIO_setMode(obj->gpioHandle,GPIO_Number_10,GPIO_10_Mode_EPWM6A); // PWM-DAC4 GPIO_setMode(obj->gpioHandle,GPIO_Number_6,GPIO_6_Mode_EPWM4A); // Push Button SW2 GPIO_setMode(obj->gpioHandle,GPIO_Number_7,GPIO_7_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_7,GPIO_Direction_Input); // ADCSOCAO_NOT or PWM-DAC3 GPIO_setMode(obj->gpioHandle,GPIO_Number_8,GPIO_8_Mode_EPWM5A); // Push Button SW1 GPIO_setMode(obj->gpioHandle,GPIO_Number_9,GPIO_9_Mode_GeneralPurpose); // PWM-DAC2 GPIO_setMode(obj->gpioHandle,GPIO_Number_11,GPIO_11_Mode_EPWM6B); // DRV8301-LED1 GPIO_setMode(obj->gpioHandle,GPIO_Number_12,GPIO_12_Mode_GeneralPurpose); // OCTWn GPIO_setMode(obj->gpioHandle,GPIO_Number_13,GPIO_13_Mode_TZ2_NOT); // FAULTn GPIO_setMode(obj->gpioHandle,GPIO_Number_14,GPIO_14_Mode_TZ3_NOT); // LED2 GPIO_setMode(obj->gpioHandle,GPIO_Number_15,GPIO_15_Mode_GeneralPurpose); #ifdef QEP // EQEPA GPIO_setMode(obj->gpioHandle,GPIO_Number_20,GPIO_20_Mode_EQEP1A); GPIO_setQualification(obj->gpioHandle,GPIO_Number_20,GPIO_Qual_Sample_3); // EQEPB GPIO_setMode(obj->gpioHandle,GPIO_Number_21,GPIO_21_Mode_EQEP1B); GPIO_setQualification(obj->gpioHandle,GPIO_Number_21,GPIO_Qual_Sample_3); // STATUS GPIO_setMode(obj->gpioHandle,GPIO_Number_22,GPIO_22_Mode_GeneralPurpose); // EQEP1I GPIO_setMode(obj->gpioHandle,GPIO_Number_23,GPIO_23_Mode_EQEP1I); GPIO_setQualification(obj->gpioHandle,GPIO_Number_23,GPIO_Qual_Sample_3); #else // EQEPA GPIO_setMode(obj->gpioHandle,GPIO_Number_20,GPIO_20_Mode_GeneralPurpose); // EQEPB GPIO_setMode(obj->gpioHandle,GPIO_Number_21,GPIO_21_Mode_GeneralPurpose); // STATUS // GPIO_setMode(obj->gpioHandle,GPIO_Number_22,GPIO_22_Mode_GeneralPurpose); //GPIO 22 DRV Enable GPIO_setMode(obj->gpioHandle,GPIO_Number_22,GPIO_22_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_22); GPIO_setDirection(obj->gpioHandle,GPIO_Number_22,GPIO_Direction_Output); // EQEP1I GPIO_setMode(obj->gpioHandle,GPIO_Number_23,GPIO_23_Mode_GeneralPurpose); #endif // SPI SIMO B GPIO_setMode(obj->gpioHandle,GPIO_Number_24,GPIO_24_Mode_SPISIMOB); // SPI SOMI B GPIO_setMode(obj->gpioHandle,GPIO_Number_25,GPIO_25_Mode_SPISOMIB); // SPI CLK B GPIO_setMode(obj->gpioHandle,GPIO_Number_26,GPIO_26_Mode_SPICLKB); // SPI CSn B GPIO_setMode(obj->gpioHandle,GPIO_Number_27,GPIO_27_Mode_SPISTEB_NOT); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_28,GPIO_28_Mode_GeneralPurpose); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_28, GPIO_Pullup_Enable); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_29,GPIO_29_Mode_GeneralPurpose); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_29, GPIO_Pullup_Enable); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_30,GPIO_30_Mode_GeneralPurpose); // ControlCARD LED2 GPIO_setMode(obj->gpioHandle,GPIO_Number_31,GPIO_31_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_31); GPIO_setDirection(obj->gpioHandle,GPIO_Number_31,GPIO_Direction_Output); // ControlCARD LED3 GPIO_setMode(obj->gpioHandle,GPIO_Number_34,GPIO_34_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_34); GPIO_setDirection(obj->gpioHandle,GPIO_Number_34,GPIO_Direction_Output); // DRV8301 Enable GPIO_setMode(obj->gpioHandle,GPIO_Number_39,GPIO_39_Mode_GeneralPurpose); // CAP1 GPIO_setMode(obj->gpioHandle,GPIO_Number_40,GPIO_40_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_40,GPIO_Direction_Input); // CAP2 GPIO_setMode(obj->gpioHandle,GPIO_Number_41,GPIO_41_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_41,GPIO_Direction_Input); // CAP3 GPIO_setMode(obj->gpioHandle,GPIO_Number_42,GPIO_42_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_42,GPIO_Direction_Input); // DC_CAL GPIO_setMode(obj->gpioHandle,GPIO_Number_43,GPIO_43_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_44,GPIO_44_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_50,GPIO_50_Mode_GeneralPurpose); // DRV8301 Enable GPIO_setMode(obj->gpioHandle,GPIO_Number_51,GPIO_51_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_51); GPIO_setDirection(obj->gpioHandle,GPIO_Number_51,GPIO_Direction_Output); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_52,GPIO_52_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_53,GPIO_53_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_54,GPIO_54_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_55,GPIO_55_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_56,GPIO_56_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_57,GPIO_57_Mode_GeneralPurpose); // No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_58,GPIO_58_Mode_GeneralPurpose); #endif //my custom board pinout definition #ifdef DRV8353 //Hall C - GPIO 6 GPIO_setMode(obj->gpioHandle,GPIO_Number_6,GPIO_6_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_6,GPIO_Direction_Input); //Speed Motor - GPIO 7 GPIO_setMode(obj->gpioHandle,GPIO_Number_7,GPIO_7_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_7,GPIO_Direction_Input); //GPIO 8 not connected GPIO_setMode(obj->gpioHandle,GPIO_Number_8,GPIO_8_Mode_GeneralPurpose); //Cadence - GPIO 9 GPIO_setMode(obj->gpioHandle,GPIO_Number_9,GPIO_9_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_9,GPIO_Direction_Input); //GPIO 10 - Enable LightOut GPIO_setMode(obj->gpioHandle,GPIO_Number_10,GPIO_10_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_10); GPIO_setDirection(obj->gpioHandle,GPIO_Number_10,GPIO_Direction_Output); //GPIO 11 not connected GPIO_setMode(obj->gpioHandle,GPIO_Number_11,GPIO_11_Mode_EPWM6B); //GPIO 12 - Enable UART GPIO_setMode(obj->gpioHandle,GPIO_Number_12,GPIO_12_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_12); GPIO_setDirection(obj->gpioHandle,GPIO_Number_12,GPIO_Direction_Output); //GPIO 20 not connected GPIO_setMode(obj->gpioHandle,GPIO_Number_20,GPIO_20_Mode_GeneralPurpose); //GPIO 21 not connected GPIO_setMode(obj->gpioHandle,GPIO_Number_21,GPIO_21_Mode_GeneralPurpose); //GPIO 22 DRV Enable GPIO_setMode(obj->gpioHandle,GPIO_Number_22,GPIO_22_Mode_GeneralPurpose); GPIO_setLow(obj->gpioHandle,GPIO_Number_22); GPIO_setDirection(obj->gpioHandle,GPIO_Number_22,GPIO_Direction_Output); //GPIO 23 - nFAULT DRV8353 GPIO_setMode(obj->gpioHandle,GPIO_Number_23,GPIO_23_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_23,GPIO_Direction_Input); //GPIO 24 No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_24,GPIO_24_Mode_GeneralPurpose); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_24, GPIO_Pullup_Enable); //GPIO 25 No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_25,GPIO_25_Mode_GeneralPurpose); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_25, GPIO_Pullup_Enable); //GPIO 26 No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_26,GPIO_26_Mode_GeneralPurpose); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_26, GPIO_Pullup_Enable); //GPIO 27 No Connection GPIO_setMode(obj->gpioHandle,GPIO_Number_27,GPIO_27_Mode_GeneralPurpose); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_27, GPIO_Pullup_Enable); // GPIO 28 - UART RX A GPIO_setMode(obj->gpioHandle,GPIO_Number_28,GPIO_28_Mode_SCIRXDA); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_28, GPIO_Pullup_Enable); // GPIO 29 - UART TX A GPIO_setMode(obj->gpioHandle,GPIO_Number_29,GPIO_29_Mode_SCITXDA); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_29, GPIO_Pullup_Enable); // GPIO 30 - CAN RX A GPIO_setMode(obj->gpioHandle,GPIO_Number_30,GPIO_30_Mode_CANRXA); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_30, GPIO_Pullup_Enable); // GPIO 31 - CAN TX A GPIO_setMode(obj->gpioHandle,GPIO_Number_31,GPIO_31_Mode_CANTXA); //GPIO_setPullup(obj->gpioHandle,GPIO_Number_30, GPIO_Pullup_Enable); //Hall A - GPIO 34 GPIO_setMode(obj->gpioHandle,GPIO_Number_34,GPIO_34_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_34,GPIO_Direction_Input); //Hall B - GPIO 39 GPIO_setMode(obj->gpioHandle,GPIO_Number_39,GPIO_39_Mode_GeneralPurpose); GPIO_setDirection(obj->gpioHandle,GPIO_Number_39,GPIO_Direction_Input); #endif return; } // end of HAL_setupGpios() function void HAL_setupPie(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; PIE_disable(obj->pieHandle); PIE_disableAllInts(obj->pieHandle); PIE_clearAllInts(obj->pieHandle); PIE_clearAllFlags(obj->pieHandle); PIE_setDefaultIntVectorTable(obj->pieHandle); PIE_enable(obj->pieHandle); return; } // end of HAL_setupPie() function void HAL_setupPeripheralClks(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; CLK_enableAdcClock(obj->clkHandle); CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_1); CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_2); CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_3); CLK_enableEcap1Clock(obj->clkHandle); CLK_disableEcanaClock(obj->clkHandle); #ifdef QEP CLK_enableEqep1Clock(obj->clkHandle); CLK_enableEqep2Clock(obj->clkHandle); #endif CLK_enablePwmClock(obj->clkHandle,PWM_Number_1); CLK_enablePwmClock(obj->clkHandle,PWM_Number_2); CLK_enablePwmClock(obj->clkHandle,PWM_Number_3); CLK_enablePwmClock(obj->clkHandle,PWM_Number_4); CLK_enablePwmClock(obj->clkHandle,PWM_Number_5); CLK_enablePwmClock(obj->clkHandle,PWM_Number_6); CLK_enablePwmClock(obj->clkHandle,PWM_Number_7); CLK_disableHrPwmClock(obj->clkHandle); CLK_disableI2cClock(obj->clkHandle); CLK_disableLinAClock(obj->clkHandle); CLK_disableClaClock(obj->clkHandle); CLK_enableSciaClock(obj->clkHandle); CLK_enableSpiaClock(obj->clkHandle); //CLK_enableSpibClock(obj->clkHandle); CLK_enableTbClockSync(obj->clkHandle); return; } // end of HAL_setupPeripheralClks() function void HAL_setupPll(HAL_Handle handle,const PLL_ClkFreq_e clkFreq) { HAL_Obj *obj = (HAL_Obj *)handle; // make sure PLL is not running in limp mode if(PLL_getClkStatus(obj->pllHandle) != PLL_ClkStatus_Normal) { // reset the clock detect PLL_resetClkDetect(obj->pllHandle); // ??????? asm(" ESTOP0"); } // Divide Select must be ClkIn/4 before the clock rate can be changed if(PLL_getDivideSelect(obj->pllHandle) != PLL_DivideSelect_ClkIn_by_4) { PLL_setDivideSelect(obj->pllHandle,PLL_DivideSelect_ClkIn_by_4); } if(PLL_getClkFreq(obj->pllHandle) != clkFreq) { // disable the clock detect PLL_disableClkDetect(obj->pllHandle); // set the clock rate PLL_setClkFreq(obj->pllHandle,clkFreq); } // wait until locked while(PLL_getLockStatus(obj->pllHandle) != PLL_LockStatus_Done) {} // enable the clock detect PLL_enableClkDetect(obj->pllHandle); // set divide select to ClkIn/2 to get desired clock rate // NOTE: clock must be locked before setting this register PLL_setDivideSelect(obj->pllHandle,PLL_DivideSelect_ClkIn_by_2); return; } // end of HAL_setupPll() function void HAL_setupPwms(HAL_Handle handle, const float_t systemFreq_MHz, const float_t pwmPeriod_usec, const uint_least16_t numPwmTicksPerIsrTick) { HAL_Obj *obj = (HAL_Obj *)handle; uint16_t halfPeriod_cycles = (uint16_t)(systemFreq_MHz*pwmPeriod_usec) >> 1; uint_least8_t cnt; // turns off the outputs of the EPWM peripherals which will put the power switches // into a high impedance state. PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_1]); PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_2]); PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_3]); // first step to synchronize the pwms CLK_disableTbClockSync(obj->clkHandle); for(cnt=0;cnt<3;cnt++) { // setup the Time-Base Control Register (TBCTL) PWM_setCounterMode(obj->pwmHandle[cnt],PWM_CounterMode_UpDown); PWM_disableCounterLoad(obj->pwmHandle[cnt]); PWM_setPeriodLoad(obj->pwmHandle[cnt],PWM_PeriodLoad_Immediate); PWM_setSyncMode(obj->pwmHandle[cnt],PWM_SyncMode_EPWMxSYNC); PWM_setHighSpeedClkDiv(obj->pwmHandle[cnt],PWM_HspClkDiv_by_1); PWM_setClkDiv(obj->pwmHandle[cnt],PWM_ClkDiv_by_1); PWM_setPhaseDir(obj->pwmHandle[cnt],PWM_PhaseDir_CountUp); PWM_setRunMode(obj->pwmHandle[cnt],PWM_RunMode_FreeRun); // setup the Timer-Based Phase Register (TBPHS) PWM_setPhase(obj->pwmHandle[cnt],0); // setup the Time-Base Counter Register (TBCTR) PWM_setCount(obj->pwmHandle[cnt],0); // setup the Time-Base Period Register (TBPRD) // set to zero initially PWM_setPeriod(obj->pwmHandle[cnt],0); // setup the Counter-Compare Control Register (CMPCTL) PWM_setLoadMode_CmpA(obj->pwmHandle[cnt],PWM_LoadMode_Zero); PWM_setLoadMode_CmpB(obj->pwmHandle[cnt],PWM_LoadMode_Zero); PWM_setShadowMode_CmpA(obj->pwmHandle[cnt],PWM_ShadowMode_Shadow); PWM_setShadowMode_CmpB(obj->pwmHandle[cnt],PWM_ShadowMode_Immediate); // setup the Action-Qualifier Output A Register (AQCTLA) PWM_setActionQual_CntUp_CmpA_PwmA(obj->pwmHandle[cnt],PWM_ActionQual_Set); PWM_setActionQual_CntDown_CmpA_PwmA(obj->pwmHandle[cnt],PWM_ActionQual_Clear); // setup the Dead-Band Generator Control Register (DBCTL) PWM_setDeadBandOutputMode(obj->pwmHandle[cnt],PWM_DeadBandOutputMode_EPWMxA_Rising_EPWMxB_Falling); PWM_setDeadBandPolarity(obj->pwmHandle[cnt],PWM_DeadBandPolarity_EPWMxB_Inverted); // setup the Dead-Band Rising Edge Delay Register (DBRED) PWM_setDeadBandRisingEdgeDelay(obj->pwmHandle[cnt],HAL_PWM_DBRED_CNT); // setup the Dead-Band Falling Edge Delay Register (DBFED) PWM_setDeadBandFallingEdgeDelay(obj->pwmHandle[cnt],HAL_PWM_DBFED_CNT); // setup the PWM-Chopper Control Register (PCCTL) PWM_disableChopping(obj->pwmHandle[cnt]); // setup the Trip Zone Select Register (TZSEL) PWM_disableTripZones(obj->pwmHandle[cnt]); } // setup the Event Trigger Selection Register (ETSEL) PWM_disableInt(obj->pwmHandle[PWM_Number_1]); PWM_setSocAPulseSrc(obj->pwmHandle[PWM_Number_1],PWM_SocPulseSrc_CounterEqualZero); PWM_enableSocAPulse(obj->pwmHandle[PWM_Number_1]); // setup the Event Trigger Prescale Register (ETPS) if(numPwmTicksPerIsrTick == 3) { PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_ThirdEvent); PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_ThirdEvent); } else if(numPwmTicksPerIsrTick == 2) { PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_SecondEvent); PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_SecondEvent); } else { PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_FirstEvent); PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_FirstEvent); } // setup the Event Trigger Clear Register (ETCLR) PWM_clearIntFlag(obj->pwmHandle[PWM_Number_1]); PWM_clearSocAFlag(obj->pwmHandle[PWM_Number_1]); // since the PWM is configured as an up/down counter, the period register is set to one-half // of the desired PWM period PWM_setPeriod(obj->pwmHandle[PWM_Number_1],halfPeriod_cycles); PWM_setPeriod(obj->pwmHandle[PWM_Number_2],halfPeriod_cycles); PWM_setPeriod(obj->pwmHandle[PWM_Number_3],halfPeriod_cycles); // last step to synchronize the pwms CLK_enableTbClockSync(obj->clkHandle); return; } // end of HAL_setupPwms() function #ifdef QEP void HAL_setupQEP(HAL_Handle handle,HAL_QepSelect_e qep) { HAL_Obj *obj = (HAL_Obj *)handle; // hold the counter in reset QEP_reset_counter(obj->qepHandle[qep]); // set the QPOSINIT register QEP_set_posn_init_count(obj->qepHandle[qep], 0); // disable all interrupts QEP_disable_all_interrupts(obj->qepHandle[qep]); // clear the interrupt flags QEP_clear_all_interrupt_flags(obj->qepHandle[qep]); // clear the position counter QEP_clear_posn_counter(obj->qepHandle[qep]); // setup the max position QEP_set_max_posn_count(obj->qepHandle[qep], (4*USER_MOTOR_ENCODER_LINES)-1); // setup the QDECCTL register QEP_set_QEP_source(obj->qepHandle[qep], QEP_Qsrc_Quad_Count_Mode); QEP_disable_sync_out(obj->qepHandle[qep]); QEP_set_swap_quad_inputs(obj->qepHandle[qep], QEP_Swap_Not_Swapped); QEP_disable_gate_index(obj->qepHandle[qep]); QEP_set_ext_clock_rate(obj->qepHandle[qep], QEP_Xcr_2x_Res); QEP_set_A_polarity(obj->qepHandle[qep], QEP_Qap_No_Effect); QEP_set_B_polarity(obj->qepHandle[qep], QEP_Qbp_No_Effect); QEP_set_index_polarity(obj->qepHandle[qep], QEP_Qip_No_Effect); // setup the QEPCTL register QEP_set_emu_control(obj->qepHandle[qep], QEPCTL_Freesoft_Unaffected_Halt); QEP_set_posn_count_reset_mode(obj->qepHandle[qep], QEPCTL_Pcrm_Max_Reset); QEP_set_strobe_event_init(obj->qepHandle[qep], QEPCTL_Sei_Nothing); QEP_set_index_event_init(obj->qepHandle[qep], QEPCTL_Iei_Nothing); QEP_set_index_event_latch(obj->qepHandle[qep], QEPCTL_Iel_Rising_Edge); QEP_set_soft_init(obj->qepHandle[qep], QEPCTL_Swi_Nothing); QEP_disable_unit_timer(obj->qepHandle[qep]); QEP_disable_watchdog(obj->qepHandle[qep]); // setup the QPOSCTL register QEP_disable_posn_compare(obj->qepHandle[qep]); // setup the QCAPCTL register QEP_disable_capture(obj->qepHandle[qep]); // renable the position counter QEP_enable_counter(obj->qepHandle[qep]); return; } #endif void HAL_setupSpiA(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; #ifdef DRV8353_SPI SPI_reset(obj->spiAHandle); SPI_setMode(obj->spiAHandle,SPI_Mode_Master); SPI_setClkPolarity(obj->spiAHandle,SPI_ClkPolarity_OutputRisingEdge_InputFallingEdge); SPI_enableTx(obj->spiAHandle); SPI_enableTxFifoEnh(obj->spiAHandle); SPI_enableTxFifo(obj->spiAHandle); SPI_setTxDelay(obj->spiAHandle,0x0010); SPI_setBaudRate(obj->spiAHandle,(SPI_BaudRate_e)(0x0010)); SPI_setCharLength(obj->spiAHandle,SPI_CharLength_16_Bits); SPI_setSuspend(obj->spiAHandle,SPI_TxSuspend_free); SPI_enable(obj->spiAHandle); #endif #ifdef DRV8301_SPI SPI_reset(obj->spiAHandle); SPI_setClkPolarity(obj->spiAHandle,SPI_ClkPolarity_OutputRisingEdge_InputFallingEdge); SPI_disableLoopBack(obj->spiAHandle); SPI_setCharLength(obj->spiAHandle,SPI_CharLength_16_Bits); SPI_setMode(obj->spiAHandle,SPI_Mode_Slave); SPI_setClkPhase(obj->spiAHandle,SPI_ClkPhase_Delayed); SPI_enableTx(obj->spiAHandle); SPI_enableChannels(obj->spiAHandle); SPI_enableTxFifoEnh(obj->spiAHandle); SPI_enableTxFifo(obj->spiAHandle); SPI_setTxDelay(obj->spiAHandle,0); SPI_clearTxFifoInt(obj->spiAHandle); SPI_enableRxFifo(obj->spiAHandle); //not needed for slave mode SPI_setBaudRate(obj->spiAHandle,(SPI_BaudRate_e)(0x000d)); SPI_setSuspend(obj->spiAHandle,SPI_TxSuspend_free); SPI_enable(obj->spiAHandle); #endif return; } // end of HAL_setupSpiA() function void HAL_setupSpiB(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; SPI_reset(obj->spiBHandle); SPI_setMode(obj->spiBHandle,SPI_Mode_Master); SPI_setClkPolarity(obj->spiBHandle,SPI_ClkPolarity_OutputRisingEdge_InputFallingEdge); SPI_enableTx(obj->spiBHandle); SPI_enableTxFifoEnh(obj->spiBHandle); SPI_enableTxFifo(obj->spiBHandle); SPI_setTxDelay(obj->spiBHandle,0x0018); SPI_setBaudRate(obj->spiBHandle,(SPI_BaudRate_e)(0x000d)); SPI_setCharLength(obj->spiBHandle,SPI_CharLength_16_Bits); SPI_setSuspend(obj->spiBHandle,SPI_TxSuspend_free); SPI_enable(obj->spiBHandle); return; } // end of HAL_setupSpiB() function void HAL_setupPwmDacs(HAL_Handle handle) { HAL_Obj *obj = (HAL_Obj *)handle; uint16_t halfPeriod_cycles = 512; // 3000->10kHz, 1500->20kHz, 1000-> 30kHz, 500->60kHz uint_least8_t cnt; for(cnt=0;cnt<3;cnt++) { // initialize the Time-Base Control Register (TBCTL) PWMDAC_setCounterMode(obj->pwmDacHandle[cnt],PWM_CounterMode_UpDown); PWMDAC_disableCounterLoad(obj->pwmDacHandle[cnt]); PWMDAC_setPeriodLoad(obj->pwmDacHandle[cnt],PWM_PeriodLoad_Immediate); PWMDAC_setSyncMode(obj->pwmDacHandle[cnt],PWM_SyncMode_EPWMxSYNC); PWMDAC_setHighSpeedClkDiv(obj->pwmDacHandle[cnt],PWM_HspClkDiv_by_1); PWMDAC_setClkDiv(obj->pwmDacHandle[cnt],PWM_ClkDiv_by_1); PWMDAC_setPhaseDir(obj->pwmDacHandle[cnt],PWM_PhaseDir_CountUp); PWMDAC_setRunMode(obj->pwmDacHandle[cnt],PWM_RunMode_FreeRun); // initialize the Timer-Based Phase Register (TBPHS) PWMDAC_setPhase(obj->pwmDacHandle[cnt],0); // setup the Time-Base Counter Register (TBCTR) PWMDAC_setCount(obj->pwmDacHandle[cnt],0); // Initialize the Time-Base Period Register (TBPRD) // set to zero initially PWMDAC_setPeriod(obj->pwmDacHandle[cnt],0); // initialize the Counter-Compare Control Register (CMPCTL) PWMDAC_setLoadMode_CmpA(obj->pwmDacHandle[cnt],PWM_LoadMode_Zero); PWMDAC_setLoadMode_CmpB(obj->pwmDacHandle[cnt],PWM_LoadMode_Zero); PWMDAC_setShadowMode_CmpA(obj->pwmDacHandle[cnt],PWM_ShadowMode_Shadow); PWMDAC_setShadowMode_CmpB(obj->pwmDacHandle[cnt],PWM_ShadowMode_Shadow); // Initialize the Action-Qualifier Output A Register (AQCTLA) PWMDAC_setActionQual_CntUp_CmpA_PwmA(obj->pwmDacHandle[cnt],PWM_ActionQual_Clear); PWMDAC_setActionQual_CntDown_CmpA_PwmA(obj->pwmDacHandle[cnt],PWM_ActionQual_Set); // account for EPWM6B if(cnt == 0) { PWMDAC_setActionQual_CntUp_CmpB_PwmB(obj->pwmDacHandle[cnt],PWM_ActionQual_Clear); PWMDAC_setActionQual_CntDown_CmpB_PwmB(obj->pwmDacHandle[cnt],PWM_ActionQual_Set); } // Initialize the Dead-Band Control Register (DBCTL) PWMDAC_disableDeadBand(obj->pwmDacHandle[cnt]); // Initialize the PWM-Chopper Control Register (PCCTL) PWMDAC_disableChopping(obj->pwmDacHandle[cnt]); // Initialize the Trip-Zone Control Register (TZSEL) PWMDAC_disableTripZones(obj->pwmDacHandle[cnt]); // Initialize the Trip-Zone Control Register (TZCTL) PWMDAC_setTripZoneState_TZA(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp); PWMDAC_setTripZoneState_TZB(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp); PWMDAC_setTripZoneState_DCAEVT1(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp); PWMDAC_setTripZoneState_DCAEVT2(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp); PWMDAC_setTripZoneState_DCBEVT1(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp); } // since the PWM is configured as an up/down counter, the period register is set to one-half // of the desired PWM period PWMDAC_setPeriod(obj->pwmDacHandle[PWMDAC_Number_1],halfPeriod_cycles); // Set period for both DAC1 and DAC2 PWMDAC_setPeriod(obj->pwmDacHandle[PWMDAC_Number_2],halfPeriod_cycles); PWMDAC_setPeriod(obj->pwmDacHandle[PWMDAC_Number_3],halfPeriod_cycles); return; } // end of HAL_setupPwmDacs() function void HAL_setupTimers(HAL_Handle handle,const float_t systemFreq_MHz) { HAL_Obj *obj = (HAL_Obj *)handle; uint32_t timerPeriod_0p5ms = (uint32_t)(systemFreq_MHz * (float_t)500.0) - 1; uint32_t timerPeriod_10ms = (uint32_t)(systemFreq_MHz * (float_t)10000.0) - 1; // use timer 0 for frequency diagnostics TIMER_setDecimationFactor(obj->timerHandle[0],0); TIMER_setEmulationMode(obj->timerHandle[0],TIMER_EmulationMode_RunFree); TIMER_setPeriod(obj->timerHandle[0],timerPeriod_0p5ms); TIMER_setPreScaler(obj->timerHandle[0],0); // use timer 1 for CPU usage diagnostics TIMER_setDecimationFactor(obj->timerHandle[1],0); TIMER_setEmulationMode(obj->timerHandle[1],TIMER_EmulationMode_RunFree); TIMER_setPeriod(obj->timerHandle[1],timerPeriod_10ms); TIMER_setPreScaler(obj->timerHandle[1],0); // use timer 2 for CPU time diagnostics TIMER_setDecimationFactor(obj->timerHandle[2],0); TIMER_setEmulationMode(obj->timerHandle[2],TIMER_EmulationMode_RunFree); TIMER_setPeriod(obj->timerHandle[2],0xFFFFFFFF); TIMER_setPreScaler(obj->timerHandle[2],0); return; } // end of HAL_setupTimers() function #ifdef DRV8353_SPI void HAL_writeDrvData(HAL_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars) { HAL_Obj *obj = (HAL_Obj *)handle; DRV8353_writeData(obj->drv8353Handle,Spi_8353_Vars); return; } // end of HAL_writeDrvData() function void HAL_readDrvData(HAL_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars) { HAL_Obj *obj = (HAL_Obj *)handle; DRV8353_readData(obj->drv8353Handle,Spi_8353_Vars); return; } // end of HAL_readDrvData() function void HAL_setupDrvSpi(HAL_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars) { HAL_Obj *obj = (HAL_Obj *)handle; DRV8353_setupSpi(obj->drv8353Handle,Spi_8353_Vars); return; } // end of HAL_setupDrvSpi() function #endif #ifdef DRV8301_SPI void HAL_writeDrvData(HAL_Handle handle, DRV_SPI_8301_Vars_t *Spi_8301_Vars) { HAL_Obj *obj = (HAL_Obj *)handle; DRV8301_writeData(obj->drv8301Handle,Spi_8301_Vars); return; } // end of HAL_writeDrvData() function void HAL_readDrvData(HAL_Handle handle, DRV_SPI_8301_Vars_t *Spi_8301_Vars) { HAL_Obj *obj = (HAL_Obj *)handle; DRV8301_readData(obj->drv8301Handle,Spi_8301_Vars); return; } // end of HAL_readDrvData() function void HAL_setupDrvSpi(HAL_Handle handle, DRV_SPI_8301_Vars_t *Spi_8301_Vars) { HAL_Obj *obj = (HAL_Obj *)handle; DRV8301_setupSpi(obj->drv8301Handle,Spi_8301_Vars); return; } // end of HAL_setupDrvSpi() function #endif void HAL_setDacParameters(HAL_Handle handle, HAL_DacData_t *pDacData) { HAL_Obj *obj = (HAL_Obj *)handle; pDacData->PeriodMax = PWMDAC_getPeriod(obj->pwmDacHandle[PWMDAC_Number_1]); pDacData->offset[0] = _IQ(0.5); pDacData->offset[1] = _IQ(0.5); pDacData->offset[2] = _IQ(0.5); pDacData->offset[3] = _IQ(0.0); pDacData->gain[0] = _IQ(1.0); pDacData->gain[1] = _IQ(1.0); pDacData->gain[2] = _IQ(1.0); pDacData->gain[3] = _IQ(1.0); return; } //end of HAL_setDacParameters() function // end of file
/* --COPYRIGHT--,BSD * Copyright (c) 2015, Texas Instruments Incorporated * All rights reserved. *xxx * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ //! \file drivers/drvic/drv8305/src/32b/f28x/f2806x/drv8353.c //! \brief Contains the various functions related to the DRV8353 object //! //! (C) Copyright 2015, Texas Instruments, Inc. // MW_INSTALL_DIR // ${PROJECT_LOC}\..\..\..\..\..\..\..\..\..\.. // // ************************************************************************** // the includes #include <math.h> // ************************************************************************** // drivers #include "sw/drivers/drvic/drv8353/src/32b/f28x/f2802x/drv8353.h" // ************************************************************************** // modules // ************************************************************************** // platforms // ************************************************************************** // the defines // ************************************************************************** // the globals // ************************************************************************** // the function prototypes DRV8353_Handle DRV8353_init(void *pMemory,const size_t numBytes) { DRV8353_Handle handle; if(numBytes < sizeof(DRV8353_Obj)) return((DRV8353_Handle)NULL); // assign the handle handle = (DRV8353_Handle)pMemory; DRV8353_resetRxTimeout(handle); DRV8353_resetEnableTimeout(handle); return(handle); } // end of DRV8353_init() function void DRV8353_enable(DRV8353_Handle handle) { DRV8353_Obj *obj = (DRV8353_Obj *)handle; static volatile uint16_t enableWaitTimeOut; uint16_t n = 0; // Enable the DRV8353 GPIO_setHigh(obj->gpioHandle,obj->gpioNumber); enableWaitTimeOut = 0; #ifdef DRV8353_SPI //if(gDeviceVariant) //{ // Make sure the FAULT bit is not set during startup while(((DRV8353_readSpi(handle, Address_Status_0) & DRV8353_STATUS00_FAULT_BITS) != 0) && (enableWaitTimeOut < 1000)) { if (++enableWaitTimeOut > 999) { obj->enableTimeOut = true; } } //} //else #endif { while(enableWaitTimeOut < 1000) { if (++enableWaitTimeOut > 999) { obj->enableTimeOut = true; } } } // Wait for the DRV8353 to go through start up sequence for(n=0;n<0xffff;n++) asm(" NOP"); return; } // end of DRV8353_enable() function #ifdef DRV8353_SPI DRV8353_CTRL03_PeakSourCurHS_e DRV8353_getPeakSourCurHS(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_3); // mask the bits data &= DRV8353_CTRL03_IDRIVEP_HS_BITS; return((DRV8353_CTRL03_PeakSourCurHS_e)data); } // end of DRV8353_getPeakSourCurHS function DRV8353_CTRL03_PeakSinkCurHS_e DRV8353_getPeakSinkCurHS(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_3); // mask the bits data &= DRV8353_CTRL03_IDRIVEN_HS_BITS; return((DRV8353_CTRL03_PeakSinkCurHS_e)data); } // end of DRV8353_getPeakSinkCurHS function DRV8353_CTRL04_PeakTime_e DRV8353_getPeakSourTime(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_4); // mask the bits data &= DRV8353_CTRL04_TDRIVE_BITS; return((DRV8353_CTRL04_PeakTime_e)data); } // end of DRV8353_getPeakSourTime function DRV8353_CTRL04_PeakSourCurLS_e DRV8353_getPeakSourCurLS(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_4); // mask the bits data &= DRV8353_CTRL04_IDRIVEP_LS_BITS; return((DRV8353_CTRL04_PeakSourCurLS_e)data); } // end of DRV8353_getPeakSourCurLS function DRV8353_CTRL04_PeakSinkCurLS_e DRV8353_getPeakSinkCurLS(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_4); // mask the bits data &= DRV8353_CTRL04_IDRIVEN_LS_BITS; return((DRV8353_CTRL04_PeakSinkCurLS_e)data); } // end of DRV8353_getPeakSinkCurLS function #endif /* DRV8353_CTRL04_PeakSinkTime_e DRV8353_getPeakSinkTime(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_4); // mask the bits data &= DRV8353_CTRL04_TDRIVE_BITS; return((DRV8353_CTRL04_PeakSinkTime_e)data); } // end of DRV8353_getPeakSinkTime function */ #ifdef DRV8353_SPI DRV8353_CTRL05_OcpDeg_e DRV8353_getVDSDeglitch(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_5); // mask the bits data &= DRV8353_CTRL05_OCP_DEG_BITS; return((DRV8353_CTRL05_OcpDeg_e)data); } // end of DRV8353_getVDSDeglitch function /* DRV8305_CTRL07_VDSBlanking_e DRV8353_getVDSBlanking(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_7); // mask the bits data &= DRV8305_CTRL07_TBLANK_BITS; return((DRV8305_CTRL07_VDSBlanking_e)data); } // end of DRV8305_getVDSBlanking function */ DRV8353_CTRL05_DeadTime_e DRV8353_getDeadTime(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_5); // mask the bits data &= DRV8353_CTRL05_DEAD_TIME_BITS; return((DRV8353_CTRL05_DeadTime_e)data); } // end of DRV8353_getDeadTime function DRV8353_CTRL02_PwmMode_e DRV8353_getPwmMode(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8353_readSpi(handle,Address_Control_2); // mask the bits data &= DRV8353_CTRL02_PWM_MODE_BITS; return((DRV8353_CTRL02_PwmMode_e)data); } // end of DRV8353_getPwmMode function /* DRV8305_CTRL07_CommOption_e DRV8353_getCommOption(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_7); // mask the bits data &= DRV8305_CTRL07_COMM_OPT_BITS; return((DRV8305_CTRL07_CommOption_e)data); } // end of DRV8305_getCommOption function DRV8305_CTRL09_WatchDelay_e DRV8353_getWatchDelay(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_9); // mask the bits data &= DRV8305_CTRL09_WD_DLY_BITS; return((DRV8305_CTRL09_WatchDelay_e)data); } // end of DRV8305_getWatchDelay function DRV8305_CTRL0A_CSGain1_e DRV8353_getCSGain1(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // mask the bits data &= DRV8305_CTRL0A_GAIN_CS1_BITS; return((DRV8305_CTRL0A_CSGain1_e)data); } // end of DRV8305_getCSGain1 function DRV8305_CTRL0A_CSGain2_e DRV8353_getCSGain2(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // mask the bits data &= DRV8305_CTRL0A_GAIN_CS2_BITS; return((DRV8305_CTRL0A_CSGain2_e)data); } // end of DRV8305_getCSGain2 function DRV8305_CTRL0A_CSGain3_e DRV8353_getCSGain3(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // mask the bits data &= DRV8305_CTRL0A_GAIN_CS3_BITS; return((DRV8305_CTRL0A_CSGain3_e)data); } // end of DRV8305_getCSGain3 function DRV8305_CTRL0A_CSBlank_e DRV8353_getCSBlank(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // mask the bits data &= DRV8305_CTRL0A_CS_BLANK_BITS; return((DRV8305_CTRL0A_CSBlank_e)data); } // end of DRV8305_getCSBlank function DRV8305_CTRL0A_DcCalMode_e DRV8353_getDcCalMode(DRV8353_Handle handle,const DRV8305_ShuntAmpNumber_e ampNumber) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // mask the bits if(ampNumber == ShuntAmpNumber_1) { data &= DRV8305_CTRL0A_DC_CAL_CH1_BITS; } else if(ampNumber == ShuntAmpNumber_2) { data &= DRV8305_CTRL0A_DC_CAL_CH2_BITS; } else if(ampNumber == ShuntAmpNumber_3) { data &= DRV8305_CTRL0A_DC_CAL_CH3_BITS; } return((DRV8305_CTRL0A_DcCalMode_e)data); } // end of DRV8305_getDcCalMode() function DRV8305_CTRL0B_VregUvLevel_e DRV8353_getVregUvLevel(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_B); // mask the bits data &= DRV8305_CTRL0B_VREG_UV_LEVEL_BITS; return((DRV8305_CTRL0B_VregUvLevel_e)data); } // end of DRV8305_getVregUvLevel function DRV8305_CTRL0B_SleepDelay_e DRV8353_getSleepDelay(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_B); // mask the bits data &= DRV8305_CTRL0B_SLP_DLY_BITS; return((DRV8305_CTRL0B_SleepDelay_e)data); } // end of DRV8305_getSleepDelay function DRV8305_CTRL0B_VrefScaling_e DRV8353_getVrefScaling(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_B); // mask the bits data &= DRV8305_CTRL0B_VREF_SCALING_BITS; return((DRV8305_CTRL0B_VrefScaling_e)data); } // end of DRV8305_getVrefScaling function DRV8305_CTRL0C_VDSMode_e DRV8353_getVDSMode(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_C); // mask the bits data &= DRV8305_CTRL0C_VDS_MODE_BITS; return((DRV8305_CTRL0C_VDSMode_e)data); } // end of DRV8305_getVDSMode function DRV8305_CTRL0C_VDSLevel_e DRV8353_getVDSLevel(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_C); // mask the bits data &= DRV8305_CTRL0C_VDS_LEVEL_BITS; return((DRV8305_CTRL0C_VDSLevel_e)data); } // end of DRV8305_getVDSLevel function */ void DRV8353_setSpiHandle(DRV8353_Handle handle,SPI_Handle spiHandle) { DRV8353_Obj *obj = (DRV8353_Obj *)handle; // initialize the serial peripheral interface object obj->spiHandle = spiHandle; return; } // end of DRV8353_setSpiHandle() function #endif void DRV8353_setGpioHandle(DRV8353_Handle handle,GPIO_Handle gpioHandle) { DRV8353_Obj *obj = (DRV8353_Obj *)handle; // initialize the gpio interface object obj->gpioHandle = gpioHandle; return; } // end of DRV8353_setGpioHandle() function void DRV8353_setGpioNumber(DRV8353_Handle handle,GPIO_Number_e gpioNumber) { DRV8353_Obj *obj = (DRV8353_Obj *)handle; // initialize the gpio interface object obj->gpioNumber = gpioNumber; return; } // end of DRV8353_setGpioNumber() function /* void DRV8305_setPeakSourCurHS(DRV8353_Handle handle,const DRV8305_CTRL05_PeakSourCurHS_e level) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_5); // clear the bits data &= (~DRV8305_CTRL05_IDRIVEP_HS_BITS); // set the bits data |= level; // write the data DRV8305_writeSpi(handle,Address_Control_5,data); return; } // end of DRV8305_setPeakSourCurHS() function void DRV8305_setPeakSinkCurHS(DRV8353_Handle handle,const DRV8305_CTRL05_PeakSinkCurHS_e level) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_5); // clear the bits data &= (~DRV8305_CTRL05_IDRIVEN_HS_BITS); // set the bits data |= level; // write the data DRV8305_writeSpi(handle,Address_Control_5,data); return; } // end of DRV8305_setPeakSinkCurHS() function void DRV8305_setPeakSourTime(DRV8353_Handle handle,const DRV8305_CTRL05_PeakSourTime_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_5); // clear the bits data &= (~DRV8305_CTRL05_TDRIVEN_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_5,data); return; } // end of DRV8305_setPeakSourTime() function void DRV8305_setPeakSinkCurLS(DRV8353_Handle handle,const DRV8305_CTRL06_PeakSinkCurLS_e level) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_6); // clear the bits data &= (~DRV8305_CTRL06_IDRIVEP_LS_BITS); // set the bits data |= level; // write the data DRV8305_writeSpi(handle,Address_Control_6,data); return; } // end of DRV8305_setPeakSinkCurLS() function void DRV8305_setPeakSinkTime(DRV8353_Handle handle,const DRV8305_CTRL06_PeakSinkTime_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_6); // clear the bits data &= (~DRV8305_CTRL06_TDRIVEP_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_6,data); return; } // end of DRV8305_setPeakSinkTime() function void DRV8305_setVDSDeglitch(DRV8353_Handle handle,const DRV8305_CTRL07_VDSDeglitch_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_7); // clear the bits data &= (~DRV8305_CTRL07_TVDS_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_7,data); return; } // end of DRV8305_setVDSDeglitch() function void DRV8305_setVDSBlanking(DRV8353_Handle handle,const DRV8305_CTRL07_VDSBlanking_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_7); // clear the bits data &= (~DRV8305_CTRL07_TBLANK_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_7,data); return; } // end of DRV8305_setVDSBlanking() function void DRV8305_setDeadTime(DRV8353_Handle handle,const DRV8305_CTRL07_DeadTime_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_7); // clear the bits data &= (~DRV8305_CTRL07_DEAD_TIME_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_7,data); return; } // end of DRV8305_setDeadTime() function void DRV8305_setPwmMode(DRV8353_Handle handle,const DRV8305_CTRL07_PwmMode_e mode) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_7); // clear the bits data &= (~DRV8305_CTRL07_PWM_MODE_BITS); // set the bits data |= mode; // write the data DRV8305_writeSpi(handle,Address_Control_7,data); return; } // end of DRV8305_setPwmMode() function void DRV8305_setCommOption(DRV8353_Handle handle,const DRV8305_CTRL07_CommOption_e mode) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_7); // clear the bits data &= (~DRV8305_CTRL07_COMM_OPT_BITS); // set the bits data |= mode; // write the data DRV8305_writeSpi(handle,Address_Control_7,data); return; } // end of DRV8305_setCommOption() function void DRV8305_setWatchDelay(DRV8353_Handle handle,const DRV8305_CTRL09_WatchDelay_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_9); // clear the bits data &= (~DRV8305_CTRL09_WD_DLY_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_9,data); return; } // end of DRV8305_setWatchDelay() function void DRV8305_setCSGain1(DRV8353_Handle handle,const DRV8305_CTRL0A_CSGain1_e gain) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // clear the bits data &= (~DRV8305_CTRL0A_GAIN_CS1_BITS); // set the bits data |= gain; // write the data DRV8305_writeSpi(handle,Address_Control_A,data); return; } // end of DRV8305_setCSGain1() function void DRV8305_setCSGain2(DRV8353_Handle handle,const DRV8305_CTRL0A_CSGain2_e gain) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // clear the bits data &= (~DRV8305_CTRL0A_GAIN_CS2_BITS); // set the bits data |= gain; // write the data DRV8305_writeSpi(handle,Address_Control_A,data); return; } // end of DRV8305_setCSGain2() function void DRV8305_setCSGain3(DRV8353_Handle handle,const DRV8305_CTRL0A_CSGain3_e gain) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // clear the bits data &= (~DRV8305_CTRL0A_GAIN_CS3_BITS); // set the bits data |= gain; // write the data DRV8305_writeSpi(handle,Address_Control_A,data); return; } // end of DRV8305_setCSGain3() function void DRV8305_setCSBlank(DRV8353_Handle handle,const DRV8305_CTRL0A_CSBlank_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // clear the bits data &= (~DRV8305_CTRL0A_CS_BLANK_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_A,data); return; } // end of DRV8305_setCSBlank() function void DRV8305_setDcCalMode(DRV8353_Handle handle,const DRV8305_ShuntAmpNumber_e ampNumber,const DRV8305_CTRL0A_DcCalMode_e mode) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_A); // clear the bits if(ampNumber == ShuntAmpNumber_1) { data &= (~DRV8305_CTRL0A_DC_CAL_CH1_BITS); } else if(ampNumber == ShuntAmpNumber_2) { data &= (~DRV8305_CTRL0A_DC_CAL_CH2_BITS); } else if(ampNumber == ShuntAmpNumber_3) { data &= (~DRV8305_CTRL0A_DC_CAL_CH3_BITS); } // set the bits data |= mode; // write the data DRV8305_writeSpi(handle,Address_Control_A,data); return; } // end of DRV8305_setDcCalMode() function void DRV8305_setVregUvLevel(DRV8353_Handle handle,const DRV8305_CTRL0B_VregUvLevel_e level) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_B); // clear the bits data &= (~DRV8305_CTRL0B_VREG_UV_LEVEL_BITS); // set the bits data |= level; // write the data DRV8305_writeSpi(handle,Address_Control_B,data); return; } // end of DRV8305_setVregUvLevel() function void DRV8305_setSleepDelay(DRV8353_Handle handle,const DRV8305_CTRL0B_SleepDelay_e time) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_B); // clear the bits data &= (~DRV8305_CTRL0B_SLP_DLY_BITS); // set the bits data |= time; // write the data DRV8305_writeSpi(handle,Address_Control_B,data); return; } // end of DRV8305_setSleepDelay() function void DRV8305_setVrefScaling(DRV8353_Handle handle,const DRV8305_CTRL0B_VrefScaling_e mode) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_B); // clear the bits data &= (~DRV8305_CTRL0B_VREF_SCALING_BITS); // set the bits data |= mode; // write the data DRV8305_writeSpi(handle,Address_Control_B,data); return; } // end of DRV8305_setVrefScaling() function void DRV8305_setVDSMode(DRV8353_Handle handle,const DRV8305_CTRL0C_VDSMode_e mode) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_C); // clear the bits data &= (~DRV8305_CTRL0C_VDS_MODE_BITS); // set the bits data |= mode; // write the data DRV8305_writeSpi(handle,Address_Control_C,data); return; } // end of DRV8305_setVDSMode() function void DRV8305_setVDSLevel(DRV8353_Handle handle,const DRV8305_CTRL0C_VDSLevel_e level) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_C); // clear the bits data &= (~DRV8305_CTRL0C_VDS_LEVEL_BITS); // set the bits data |= level; // write the data DRV8305_writeSpi(handle,Address_Control_C,data); return; } // end of DRV8305_setVDSLevel() function bool DRV8305_isFault(DRV8353_Handle handle) { DRV8305_Word_t readWord; bool status=false; // read the data readWord = DRV8305_readSpi(handle,Address_Status_1); if(readWord & DRV8305_STATUS01_FAULT_BITS) { status = true; } return(status); } // end of DRV8305_isFault() function void DRV8305_reset(DRV8353_Handle handle) { uint16_t data; // read data data = DRV8305_readSpi(handle,Address_Control_9); // set the bits data |= DRV8305_CTRL09_CLR_FLTS_BITS; // write the data DRV8305_writeSpi(handle,Address_Control_9,data); return; } // end of DRV8305_reset() function */ #ifdef DRV8353_SPI void DRV8353_setupSpi(DRV8353_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars) { DRV8353_Address_e drvRegAddr; uint16_t drvDataNew; // Set Default Values // Manual Read/Write Spi_8353_Vars->ManReadAddr = 0; Spi_8353_Vars->ManReadData = 0; Spi_8353_Vars->ManReadCmd = false; Spi_8353_Vars->ManWriteAddr = 0; Spi_8353_Vars->ManWriteData = 0; Spi_8353_Vars->ManWriteCmd = false; // Read/Write Spi_8353_Vars->ReadCmd = false; Spi_8353_Vars->WriteCmd = true; // Read registers for default values // Read Status Register 0 drvRegAddr = Address_Status_0; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Stat_Reg_00.VDS_LC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_LC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_HC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_HC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_LB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_LB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_HB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_HB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_LA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_LA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_HA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_HA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.OTSD = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_OTSD_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.UVLO = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_UVLO_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.GDF = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_GDF_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_OCP = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_OCP_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.FAULT = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_FAULT_BITS)?1:0; // Read Status Register 1 drvRegAddr = Address_Status_1; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Stat_Reg_01.VGS_LC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_LC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_HC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_HC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_LB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_LB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_HB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_HB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_LA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_LA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_HA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_HA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.GDUV = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_GDUV_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.OTW = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_OTW_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.SC_OC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_SC_OC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.SB_OC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_SB_OC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.SA_OC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_SA_OC_BITS)?1:0; // Read Control Register 2 drvRegAddr = Address_Control_2; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_02.CLR_FLT = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_CLR_FLT_BITS); Spi_8353_Vars->Ctrl_Reg_02.BRAKE = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_BRAKE_BITS); Spi_8353_Vars->Ctrl_Reg_02.COAST = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_COAST_BITS); Spi_8353_Vars->Ctrl_Reg_02.PWM1_DIR = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_PWM1_DIR_BITS); Spi_8353_Vars->Ctrl_Reg_02.PWM1_COM = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_PWM1_COM_BITS); Spi_8353_Vars->Ctrl_Reg_02.PWM_MODE = (DRV8353_CTRL02_PwmMode_e)(drvDataNew & (uint16_t)DRV8353_CTRL02_PWM_MODE_BITS); Spi_8353_Vars->Ctrl_Reg_02.OTW_REP = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_OTW_REP_BITS); Spi_8353_Vars->Ctrl_Reg_02.DIS_GDF = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_DIS_GDF_BITS); Spi_8353_Vars->Ctrl_Reg_02.DIS_CPUV = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_DIS_CPUV_BITS); Spi_8353_Vars->Ctrl_Reg_02.OCP_ACT = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_OCP_ACT)?1:0; // Read Control Register 3 drvRegAddr = Address_Control_3; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_03.IDRIVEN_HS = (DRV8353_CTRL03_PeakSinkCurHS_e)(drvDataNew & (uint16_t)DRV8353_CTRL03_IDRIVEN_HS_BITS); Spi_8353_Vars->Ctrl_Reg_03.IDRIVEP_HS = (DRV8353_CTRL03_PeakSourCurHS_e)(drvDataNew & (uint16_t)DRV8353_CTRL03_IDRIVEP_HS_BITS); Spi_8353_Vars->Ctrl_Reg_03.LOCK = (DRV8353_CTRL03_Lock_e)(drvDataNew & (uint16_t)DRV8353_CTRL03_LOCK_BITS); // Read Control Register 4 drvRegAddr = Address_Control_4; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_04.IDRIVEN_LS = (DRV8353_CTRL04_PeakSinkCurLS_e)(drvDataNew & (uint16_t)DRV8353_CTRL04_IDRIVEN_LS_BITS); Spi_8353_Vars->Ctrl_Reg_04.IDRIVEP_LS = (DRV8353_CTRL04_PeakSourCurLS_e)(drvDataNew & (uint16_t)DRV8353_CTRL04_IDRIVEP_LS_BITS); Spi_8353_Vars->Ctrl_Reg_04.TDRIVE = (DRV8353_CTRL04_PeakTime_e)(drvDataNew & (uint16_t)DRV8353_CTRL04_TDRIVE_BITS); Spi_8353_Vars->Ctrl_Reg_04.CBC = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL04_CBC_BITS)?1:0; // Read Control Register 5 drvRegAddr = Address_Control_5; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_05.VDS_LVL = (DRV8353_CTRL05_VDSLVL_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_VDS_LVL_BITS); Spi_8353_Vars->Ctrl_Reg_05.OCP_DEG = (DRV8353_CTRL05_OcpDeg_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_OCP_DEG_BITS); Spi_8353_Vars->Ctrl_Reg_05.OCP_MODE = (DRV8353_CTRL05_OcpMode_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_OCP_MODE_BITS); Spi_8353_Vars->Ctrl_Reg_05.DEAD_TIME = (DRV8353_CTRL05_DeadTime_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_DEAD_TIME_BITS); Spi_8353_Vars->Ctrl_Reg_05.TRETRY = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL05_TRETRY_BITS); // Read Control Register 6 drvRegAddr = Address_Control_6; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_06.SEN_LVL = (DRV8353_CTRL06_SENLevel_e)(drvDataNew & (uint16_t)DRV8353_CTRL06_SEN_LVL_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_C = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_CAL_C_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_B = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_CAL_B_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_A = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_CAL_A_BITS); Spi_8353_Vars->Ctrl_Reg_06.DIS_SEN = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_DIS_SEN_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_GAIN = (DRV8353_CTRL06_CSAGain_e)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_GAIN_BITS); Spi_8353_Vars->Ctrl_Reg_06.LS_REF = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_LS_REF_BITS); Spi_8353_Vars->Ctrl_Reg_06.VREF_DIV = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_VREF_DIV_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_FET = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_FET_BITS); // Read Control Register 7 drvRegAddr = Address_Control_7; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_07.CAL_MODE = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_CAL_MODE_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_1 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED1_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_2 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED2_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_3 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED3_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_4 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED4_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_5 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED5_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_6 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED6_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_7 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED7_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_8 = (bool)(drvDataNew & (uint16_t)DRV8335_CTRL07_RESERVED8_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_9 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED9_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_10 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED10_BITS); return; } // end of DRV8353_setupSpi() function uint16_t DRV8353_readSpi(DRV8353_Handle handle,const DRV8353_Address_e regAddr) { DRV8353_Obj *obj = (DRV8353_Obj *)handle; uint16_t ctrlWord; uint16_t n; const uint16_t data = 0; volatile uint16_t readWord; static volatile uint16_t WaitTimeOut = 0; volatile SPI_FifoStatus_e RxFifoCnt = SPI_FifoStatus_Empty; // build the control word ctrlWord = (uint16_t)DRV8353_buildCtrlWord(CtrlMode_Read,regAddr,data); // reset the Rx fifo pointer to zero SPI_resetRxFifo(obj->spiHandle); SPI_enableRxFifo(obj->spiHandle); GPIO_setLow(obj->gpioHandle, GPIO_Number_19); // wait for registers to update for(n=0;n<0x06;n++) asm(" NOP"); // write the command SPI_write(obj->spiHandle,ctrlWord); // dummy write to return the reply from the 8301 SPI_write(obj->spiHandle,0x0000); // wait for the response to populate the RX fifo, else a wait timeout will occur while((RxFifoCnt < SPI_FifoStatus_2_Words) && (WaitTimeOut < 0xffff)) { RxFifoCnt = SPI_getRxFifoStatus(obj->spiHandle); if(++WaitTimeOut > 0xfffe) { obj->RxTimeOut = true; //WaitTimeOut = 0; } } GPIO_setHigh(obj->gpioHandle, GPIO_Number_19); // Read the word readWord = SPI_read(obj->spiHandle); //readWord = SPI_read(obj->spiHandle); return(readWord & DRV8353_DATA_MASK); } // end of DRV8353_readSpi() function //TODO: void DRV8353_writeSpi(DRV8353_Handle handle,const DRV8353_Address_e regAddr,const uint16_t data) { DRV8353_Obj *obj = (DRV8353_Obj *)handle; uint16_t ctrlWord; uint16_t n; // build the control word ctrlWord = (uint16_t)DRV8353_buildCtrlWord(CtrlMode_Write,regAddr,data); // reset the Rx fifo pointer to zero SPI_resetRxFifo(obj->spiHandle); SPI_enableRxFifo(obj->spiHandle); GPIO_setLow(obj->gpioHandle, GPIO_Number_19); // wait for GPIO for(n=0;n<0x06;n++) asm(" NOP"); // write the command SPI_write(obj->spiHandle,ctrlWord); // wait for registers to update for(n=0;n<0xF0;n++) asm(" NOP"); GPIO_setHigh(obj->gpioHandle, GPIO_Number_19); return; } // end of DRV8353_writeSpi() function // TODO: void DRV8353_writeData(DRV8353_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars) { DRV8353_Address_e drvRegAddr = Address_Status_0; uint16_t drvDataNew = 0; /*Spi_8353_Vars->Ctrl_Reg_04.IDRIVEN_LS = 3; Spi_8353_Vars->Ctrl_Reg_04.IDRIVEP_LS = 3 << 4; Spi_8353_Vars->Ctrl_Reg_03.IDRIVEN_HS = 3; Spi_8353_Vars->Ctrl_Reg_03.IDRIVEP_HS = 3 << 4;*/ //Spi_8353_Vars->Ctrl_Reg_06.CSA_GAIN = if(Spi_8353_Vars->WriteCmd) { // Spi_8353_Vars->Ctrl_Reg_04.IDRIVEN_LS = ISink_LS_0p100_A; // Spi_8353_Vars->Ctrl_Reg_04.IDRIVEP_LS = ISour_LS_0p050_A; // Spi_8353_Vars->Ctrl_Reg_03.IDRIVEN_HS = ISink_HS_0p100_A; // Spi_8353_Vars->Ctrl_Reg_03.IDRIVEP_HS = ISour_HS_0p050_A; Spi_8353_Vars->Ctrl_Reg_06.CSA_GAIN = Gain_10VpV; //Spi_8353_Vars->Ctrl_Reg_05.DEAD_TIME = DeadTime_50_ns; // Write Control Register 2 drvRegAddr = Address_Control_2; drvDataNew = (Spi_8353_Vars->Ctrl_Reg_02.CLR_FLT << 0) | \ (Spi_8353_Vars->Ctrl_Reg_02.BRAKE << 1) | \ (Spi_8353_Vars->Ctrl_Reg_02.COAST <<2) | \ (Spi_8353_Vars->Ctrl_Reg_02.PWM1_DIR << 3) | \ (Spi_8353_Vars->Ctrl_Reg_02.PWM1_COM << 4) | \ (Spi_8353_Vars->Ctrl_Reg_02.PWM_MODE) | \ (Spi_8353_Vars->Ctrl_Reg_02.OTW_REP << 7) | \ (Spi_8353_Vars->Ctrl_Reg_02.DIS_GDF << 8) | \ (Spi_8353_Vars->Ctrl_Reg_02.DIS_CPUV <<9) | \ (Spi_8353_Vars->Ctrl_Reg_02.OCP_ACT << 10); DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); // Write Control Register 3 drvRegAddr = Address_Control_3; drvDataNew = (Spi_8353_Vars->Ctrl_Reg_03.IDRIVEN_HS) | \ (Spi_8353_Vars->Ctrl_Reg_03.IDRIVEP_HS) | \ (Spi_8353_Vars->Ctrl_Reg_03.LOCK); DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); // Write Control Register 4 drvRegAddr = Address_Control_4; drvDataNew = (Spi_8353_Vars->Ctrl_Reg_04.IDRIVEN_LS) | \ (Spi_8353_Vars->Ctrl_Reg_04.IDRIVEP_LS) | \ (Spi_8353_Vars->Ctrl_Reg_04.TDRIVE) | \ (Spi_8353_Vars->Ctrl_Reg_04.CBC << 10); DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); // Write Control Register 5 drvRegAddr = Address_Control_5; drvDataNew = (Spi_8353_Vars->Ctrl_Reg_05.VDS_LVL) | \ (Spi_8353_Vars->Ctrl_Reg_05.OCP_DEG) | \ (Spi_8353_Vars->Ctrl_Reg_05.OCP_MODE) | \ (Spi_8353_Vars->Ctrl_Reg_05.DEAD_TIME) | \ (Spi_8353_Vars->Ctrl_Reg_05.TRETRY << 10); DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); // Write Control Register 6 drvRegAddr = Address_Control_6; drvDataNew = (Spi_8353_Vars->Ctrl_Reg_06.SEN_LVL) | \ (Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_C << 2) | \ (Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_B << 3) | \ (Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_A << 4) | \ (Spi_8353_Vars->Ctrl_Reg_06.DIS_SEN << 5) | \ (Spi_8353_Vars->Ctrl_Reg_06.CSA_GAIN) | \ (Spi_8353_Vars->Ctrl_Reg_06.LS_REF << 8) | \ (Spi_8353_Vars->Ctrl_Reg_06.VREF_DIV << 9) | \ (Spi_8353_Vars->Ctrl_Reg_06.CSA_FET << 10); DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); // Write Control Register 7 drvRegAddr = Address_Control_7; drvDataNew = (Spi_8353_Vars->Ctrl_Reg_07.CAL_MODE) << 0 | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_1 << 1) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_2 << 2) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_3 << 3) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_4 << 4) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_5 << 5) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_6 << 6) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_7 << 7) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_8 << 8) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_9 << 9) | \ (Spi_8353_Vars->Ctrl_Reg_07.RESERVED_10 << 10) ; DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); Spi_8353_Vars->WriteCmd = false; } // Manual write to the DRV8353 if(Spi_8353_Vars->ManWriteCmd) { // Custom Write drvRegAddr = (DRV8353_Address_e)(Spi_8353_Vars->ManWriteAddr << 11); drvDataNew = Spi_8353_Vars->ManWriteData; DRV8353_writeSpi(handle,drvRegAddr,drvDataNew); drvDataNew = 0; Spi_8353_Vars->ManWriteCmd = false; } return; } // end of DRV8353_writeData() function void DRV8353_readData(DRV8353_Handle handle, DRV_SPI_8353_Vars_t *Spi_8353_Vars) { DRV8353_Address_e drvRegAddr; uint16_t drvDataNew; if(Spi_8353_Vars->ReadCmd) { // Read registers for default values // Read Status Register 0 drvRegAddr = Address_Status_0; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Stat_Reg_00.VDS_LC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_LC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_HC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_HC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_LB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_LB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_HB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_HB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_LA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_LA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_HA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_HA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.OTSD = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_OTSD_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.UVLO = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_UVLO_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.GDF = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_GDF_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.VDS_OCP = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_VDS_OCP_BITS)?1:0; Spi_8353_Vars->Stat_Reg_00.FAULT = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS00_FAULT_BITS)?1:0; // Read Status Register 1 drvRegAddr = Address_Status_1; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Stat_Reg_01.VGS_LC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_LC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_HC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_HC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_LB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_LB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_HB = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_HB_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_LA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_LA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.VGS_HA = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_VGS_HA_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.GDUV = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_GDUV_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.OTW = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_OTW_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.SC_OC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_SC_OC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.SB_OC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_SB_OC_BITS)?1:0; Spi_8353_Vars->Stat_Reg_01.SA_OC = (bool)(drvDataNew & (uint16_t)DRV8353_STATUS01_SA_OC_BITS)?1:0; // Read Control Register 2 drvRegAddr = Address_Control_2; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_02.CLR_FLT = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_CLR_FLT_BITS); Spi_8353_Vars->Ctrl_Reg_02.BRAKE = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_BRAKE_BITS); Spi_8353_Vars->Ctrl_Reg_02.COAST = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_COAST_BITS); Spi_8353_Vars->Ctrl_Reg_02.PWM1_DIR = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_PWM1_DIR_BITS); Spi_8353_Vars->Ctrl_Reg_02.PWM1_COM = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_PWM1_COM_BITS); Spi_8353_Vars->Ctrl_Reg_02.PWM_MODE = (DRV8353_CTRL02_PwmMode_e)(drvDataNew & (uint16_t)DRV8353_CTRL02_PWM_MODE_BITS); Spi_8353_Vars->Ctrl_Reg_02.OTW_REP = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_OTW_REP_BITS); Spi_8353_Vars->Ctrl_Reg_02.DIS_GDF = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_DIS_GDF_BITS); Spi_8353_Vars->Ctrl_Reg_02.DIS_CPUV = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_DIS_CPUV_BITS); Spi_8353_Vars->Ctrl_Reg_02.OCP_ACT = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL02_OCP_ACT)?1:0; // Read Control Register 3 drvRegAddr = Address_Control_3; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_03.IDRIVEN_HS = (DRV8353_CTRL03_PeakSinkCurHS_e)(drvDataNew & (uint16_t)DRV8353_CTRL03_IDRIVEN_HS_BITS); Spi_8353_Vars->Ctrl_Reg_03.IDRIVEP_HS = (DRV8353_CTRL03_PeakSourCurHS_e)(drvDataNew & (uint16_t)DRV8353_CTRL03_IDRIVEP_HS_BITS); Spi_8353_Vars->Ctrl_Reg_03.LOCK = (DRV8353_CTRL03_Lock_e)(drvDataNew & (uint16_t)DRV8353_CTRL03_LOCK_BITS); // Read Control Register 4 drvRegAddr = Address_Control_4; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_04.IDRIVEN_LS = (DRV8353_CTRL04_PeakSinkCurLS_e)(drvDataNew & (uint16_t)DRV8353_CTRL04_IDRIVEN_LS_BITS); Spi_8353_Vars->Ctrl_Reg_04.IDRIVEP_LS = (DRV8353_CTRL04_PeakSourCurLS_e)(drvDataNew & (uint16_t)DRV8353_CTRL04_IDRIVEP_LS_BITS); Spi_8353_Vars->Ctrl_Reg_04.TDRIVE = (DRV8353_CTRL04_PeakTime_e)(drvDataNew & (uint16_t)DRV8353_CTRL04_TDRIVE_BITS); Spi_8353_Vars->Ctrl_Reg_04.CBC = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL04_CBC_BITS)?1:0; // Read Control Register 5 drvRegAddr = Address_Control_5; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_05.VDS_LVL = (DRV8353_CTRL05_VDSLVL_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_VDS_LVL_BITS); Spi_8353_Vars->Ctrl_Reg_05.OCP_DEG = (DRV8353_CTRL05_OcpDeg_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_OCP_DEG_BITS); Spi_8353_Vars->Ctrl_Reg_05.OCP_MODE = (DRV8353_CTRL05_OcpMode_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_OCP_MODE_BITS); Spi_8353_Vars->Ctrl_Reg_05.DEAD_TIME = (DRV8353_CTRL05_DeadTime_e)(drvDataNew & (uint16_t)DRV8353_CTRL05_DEAD_TIME_BITS); Spi_8353_Vars->Ctrl_Reg_05.TRETRY = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL05_TRETRY_BITS); // Read Control Register 6 drvRegAddr = Address_Control_6; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_06.SEN_LVL = (DRV8353_CTRL06_SENLevel_e)(drvDataNew & (uint16_t)DRV8353_CTRL06_SEN_LVL_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_C = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_CAL_C_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_B = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_CAL_B_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_CAL_A = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_CAL_A_BITS); Spi_8353_Vars->Ctrl_Reg_06.DIS_SEN = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_DIS_SEN_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_GAIN = (DRV8353_CTRL06_CSAGain_e)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_GAIN_BITS); Spi_8353_Vars->Ctrl_Reg_06.LS_REF = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_LS_REF_BITS); Spi_8353_Vars->Ctrl_Reg_06.VREF_DIV = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_VREF_DIV_BITS); Spi_8353_Vars->Ctrl_Reg_06.CSA_FET = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL06_CSA_FET_BITS); // Read Control Register 7 drvRegAddr = Address_Control_7; drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->Ctrl_Reg_07.CAL_MODE = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_CAL_MODE_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_1 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED1_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_2 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED2_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_3 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED3_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_4 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED4_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_5 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED5_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_6 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED6_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_7 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED7_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_8 = (bool)(drvDataNew & (uint16_t)DRV8335_CTRL07_RESERVED8_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_9 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED9_BITS); Spi_8353_Vars->Ctrl_Reg_07.RESERVED_10 = (bool)(drvDataNew & (uint16_t)DRV8353_CTRL07_RESERVED10_BITS); Spi_8353_Vars->ReadCmd = false; } // Manual read from the DRV8353 if(Spi_8353_Vars->ManReadCmd) { // Custom Read drvRegAddr = (DRV8353_Address_e)(Spi_8353_Vars->ManReadAddr << 11); drvDataNew = DRV8353_readSpi(handle,drvRegAddr); Spi_8353_Vars->ManReadData = drvDataNew; Spi_8353_Vars->ManReadCmd = false; } return; } // end of DRV8353_readData() function #endif // end of file
