Hi sir/madam
I have some confusion in what is the differnce between TMS320F280049C control card launch pad
can you please explain me
thank you
Hi sir/madam
thank you
The silicon residing on both the boards are one and the same.
For launch pad there are a set of booster packs that it can interface to or it can be used to experiment stand alone with few GPIO's available handy.
Here is a quick link for finding the available pre-existing booster packs for a given launch pad
Control cards on the other hand needs a dock to use the existing I/O's if used stand alone. Its used in a lot of TI reference designs (for ex TIDM 1000) or if you intend to use this in one of your designs like a TI reference design that's possible too.
Hope this helps.
Hi thanks for the reply
we using TMS320F280049C control card,we need to toggle a LED,using code composer studio software,can you please provide steps to blink led on control card.
thank you
You find the examples for the same from C2000ware
...\c2000\C2000Ware_3_02_00_00\driverlib\f28004x\examples\led
Hi,we want to initialize ADC,what are the files we need to add in ccs,can you please provide information for ADC initialization(TMS320F280049C) in this baord,
thank you
Please go through the training and C2000ware as I suggested, so you can find all the information and examples
C:\ti\c2000\C2000Ware_3_02_00_00\driverlib\f28004x\examples\adc
If this/above replies answer your question, please close this thread by clicking verified answer and open a new thread for any other queries you might have.
thanks for the reply,
while building my ADC project i get below errors can you please help me to reduce tha tproblems
this is my ADC code
// FILE: adc.c
// TITLE: C28x ADC driver.
// $TI Release: F28004x Support Library v1.10.00.00 $
// $Release Date: Tue May 26 17:06:03 IST 2020 $
// $Copyright:
// Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "f28004x_adc.h"
// Defines for locations of ADC calibration functions in OTP for use in
// ADC_setVREF(). Not intended for use by application code.
#define ADC_OFFSET_TRIM_OTP 0x70594U
// ADC_setVREF
void
ADC_setVREF(uint32_t base, ADC_ReferenceMode refMode,
ADC_ReferenceVoltage refVoltage)
uint16_t *offset;
uint16_t moduleShiftVal;
uint16_t offsetShiftVal;
// Check the arguments.
ASSERT(ADC_isBaseValid(base));
// Assign a shift amount corresponding to which ADC module is being
// configured.
switch(base)
case ADCA_BASE:
moduleShiftVal = 0U;
break;
case ADCB_BASE:
moduleShiftVal = 1U;
break;
case ADCC_BASE:
moduleShiftVal = 2U;
break;
default:
// Invalid base address!!
break;
// Offset trim for internal VREF 3.3V is unique and stored in upper byte.
if((refMode == ADC_REFERENCE_INTERNAL) &&
(refVoltage == ADC_REFERENCE_3_3V))
offsetShiftVal = 8U;
else
offsetShiftVal = 0U;
// Set up pointer to offset trim in OTP.
offset = (uint16_t *)(ADC_OFFSET_TRIM_OTP + ((uint32_t)6U *
(uint32_t)moduleShiftVal));
// Get offset trim from OTP and write it to the register.
EALLOW;
HWREGH(base + ADC_O_OFFTRIM) = (*offset >> offsetShiftVal) & 0xFFU;
// Configure the reference mode (internal or external).
if(refMode == ADC_REFERENCE_INTERNAL)
HWREGH(ANALOGSUBSYS_BASE + ASYSCTL_O_ANAREFCTL) &=
~(ASYSCTL_ANAREFCTL_ANAREFASEL << moduleShiftVal);
else
HWREGH(ANALOGSUBSYS_BASE + ASYSCTL_O_ANAREFCTL) |=
ASYSCTL_ANAREFCTL_ANAREFASEL << moduleShiftVal;
// Configure the reference voltage (3.3V or 2.5V).
if(refVoltage == ADC_REFERENCE_3_3V)
~(ASYSCTL_ANAREFCTL_ANAREFA2P5SEL << moduleShiftVal);
else
ASYSCTL_ANAREFCTL_ANAREFA2P5SEL << moduleShiftVal;
EDIS;
// ADC_setPPBTripLimits
void
ADC_setPPBTripLimits(uint32_t base, ADC_PPBNumber ppbNumber,
int32_t tripHiLimit, int32_t tripLoLimit)
uint32_t ppbHiOffset;
uint32_t ppbLoOffset;
ASSERT((tripHiLimit <= 65535) && (tripHiLimit >= -65536));
ASSERT((tripLoLimit <= 65535) && (tripLoLimit >= -65536));
// Get the offset to the appropriate trip limit registers.
ppbHiOffset = (ADC_PPBxTRIPHI_STEP * (uint32_t)ppbNumber) +
ADC_O_PPB1TRIPHI;
ppbLoOffset = (ADC_PPBxTRIPLO_STEP * (uint32_t)ppbNumber) +
ADC_O_PPB1TRIPLO;
EALLOW;
// Set the trip high limit.
HWREG(base + ppbHiOffset) =
(HWREG(base + ppbHiOffset) & ~ADC_PPBTRIP_MASK) |
((uint32_t)tripHiLimit & ADC_PPBTRIP_MASK);
// Set the trip low limit.
HWREG(base + ppbLoOffset) =
(HWREG(base + ppbLoOffset) & ~ADC_PPBTRIP_MASK) |
((uint32_t)tripLoLimit & ADC_PPBTRIP_MASK);
EDIS;
Please check your include paths using any standard example that you can pull from C2000ware.
Since you have created a new thread for this issue and got addressed. Can you pls close this thread ?
