Part Number: TMS320F28388D
Hi expert,
Issue description:
In F28388D’s CM core, we have bootloader at flash entry and a SYSBIOS based application in some other flash sector.
Bootloader’s instruction to jump to start of APP will crash the program. (stick in somewhere, APP not running)
Test steps:
1. We take customer board as “Board A” and TI F28388D control card as “Board B”
2. We take application code with SYSBIOS as “Code A” without SYSBIOS as “Code B”
We have below test results. I marked the code jump to APP failed (judged by APP not function, seems stuck somewhere) as “Bad” in below table.
Do the “test” |
Code A |
Code B |
Board A |
Bad |
Good |
Board B |
Good |
Good |
In the Bad conditions, if we connect the debugger then do a “restart”, Board A and Code A combination will work fine.
Could you help us with how to debug this? It seems both realted to hardware used here and if the code is using a SYSBIOS.
Sheldon
