TMS320F28388D: Quote of Software resource for next generation device
Part Number: TMS320F28388D
Other Parts Discussed in Thread: C2000WARE, TMS320F28379D, , CONTROLSUITE
Hello Expert,
Today, I would like you to ask about way of thinking of software compatiblity due to new device(generation change) of C2000 series.
In case of development tool, I understand that user can develop their production without depending on device itself by using CCS and C2000ware.
However, I would like you to confirm how you consider from viewpoint of software(Device Driver/Firmware/Appication).
For instance, user have already released product which is implemented TMS320F28379D.
And, they are considering next product and consider to use TMS320F28388D.
Then, of course they consider how much they can use software resource of TMS320F28379D for TMS320F28388D.
If you have document which is described how TI consider Roadmap from viewpoint of software, could you please share it to us ?
If you do not have, could you please explain your way of thinging by using above example ?
  • Pls take a look at the below migration guide
    https://www.ti.com/lit/an/spracq1/spracq1.pdf
    You can look at Sec:4 for  more details
    <c2000ware>\device_support\f2838x\docs\Driverlib_F2837x_to_F2838x_Migration_Guide.pdf
    Hope this helps..
  • Hello Karthik-san,
    Thank you for your reply.
    I will confirm it and when I have question, I will ask you again.
    I have additional question.
    * "driverlib" appeard from C2000ware (There were no "driverlib" folder in ControlSuite).
    On the other hand, regacy "peripheral header file" also exist.
    When same function exist, which one is better to use ?
    If you have document how to use properly, could you please let me know ?
  • Hello Ryuuichi-san,
    I will get some driverlib expert to help you with this. Thanks.
    C2000Ware supports multiple ways of accessing peripheral registers - direct register access, driver library (DriverLib), and bitfields.
    DriverLib APIs are the preferred way of accessing peripherals for the new generation MCUs.
    Bitfield is supported only in the older generation of MCUs.
    But Bitfield headers are provided for the new generation MCUs for compatibility and easy migration.
    The following figure shows the comparison between driverlib and bitfield.
    ../_images/RegAccess.png
    Refer the following link for more details
    Best Regards
    Siddharth
  • Hello Siddharth-san,
    I roughly understood about difference/benefit b/w driverlib and header file by referring your reply and following programming guide.
    https://www.ti.com/lit/an/spraa85e/spraa85e.pdf
    Thank you !
    Hello Karthik-san,
    According to C2000ware, it seems that you have migration guide for only 2837X to 2838X.
    Following is just example. I would like to know thinking of way for C2000 series totally.
    Q. Do you have any other migration guide for other devices ?
    (I would like to know documentation folder or URL which user can get this information.)
    Q. If you do not have so much migration guide, Could you please tell me the points to notify in software construction to continue using the C2000 series ?
    Is this resolved? Or do you have any more questions?
    Best Regards
    Siddharth
    I do not have question for your answer at this time.
    The reason why I can not close this thread is because I have question for Karthik-san's answer.
    Could you please send me about your feedback for my following question ?
    I don't think there is a migration guide for other devices. Any particular device that you are looking for ?
    Best Regards
    Siddharth
    Thank you for your following up.
    Understood.
    Not specially.
    I just want to confirm which point user should take care to continue to use software resource of C2000 which they used on current product to latest/other C2000.
    (If you don't have especially, when user choose next CPU for future product, we think there is no advantage comparing other CPU.)
    Because, actually, they can understand how user can develop by using C2000, but it seems there is no resource for future product.)
