Hi expert,
I think "linker.cmd" is something generated by .cfg file for SYSBIOS so it should not be modified manually. Then a problem comes, where in .cfg file could we change the reset vetor position? For most cases it should not be change for flash entry I think. But what if we need a modification?
Sheldon
Hi Sheldon,
This is controlled in the .cfg for the CortexM devices. For example, in the .cfg you can have the following
var Hwi = xdc.useModule('ti.sysbios.family.arm.m3.Hwi'); Hwi.resetVectorAddress = 0x20000000;
Todd
