Part Number: TMS320F28075
Hi team,
Customer would like to used one shared pull-up resistors for 2~5 unsed GPIO. Any protential problem from your side? What is the recommended value?
Brian
Hi team,
Brian
Brian,
if the customer is trying to save components please remember that there are three acceptable practices for unused GPIOs:
So they have the option to not connect any external pull-up or pull-down resistor. If they use an external Pull-up resistor, a larger value should be OK(10K or even a little larger), as long as they configure it as an input. This is only to keep the pin from drifting to a mid-rail voltage.
Cody
Hi Cody,
Understand they would have 3 options. But pull-up resistor is part of their design guidance.
If they would like to share pull-up resistors, is it acceptable and what is the recommended value?
Brian
Brian,
sharing a Pull-up should be OK for GPIOs 2-5. Please use a value around 10-20K.
Cody
