//########################################################################### // // FILE: Example_2806xSpi_FFDLB.c // // TITLE: SPI Digital Loop Back Example // //! \addtogroup f2806x_example_list //! <h1>SPI Digital Loop Back(spi_loopback)</h1> //! //! This program uses the internal loop back test mode of the peripheral. //! Other then boot mode pin configuration, no other hardware configuration //! is required. Interrupts are not used. //! //! A stream of data is sent and then compared to the received stream. //! The sent data looks like this: \n //! 0000 0001 0002 0003 0004 0005 0006 0007 .... FFFE FFFF \n //! This pattern is repeated forever. //! //! \b Watch \b Variables \n //! - \b sdata , sent data //! - \b rdata , received data // ////########################################################################### // $TI Release: F2806x Support Library v2.04.00.00 $ // $Release Date: Mon May 27 06:46:38 CDT 2019 $ // $Copyright: // Copyright (C) 2009-2019 Texas Instruments Incorporated - http://www.ti.com/ // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. // $ //############################################################################# // // Included Files // #include "DSP28x_Project.h" // Device Headerfile and Examples Include File // // Function Prototypes // void spi_xmit(Uint16 a); void spi_fifo_init(void); void spi_init(void); void error(void); // // Main // void main(void) { Uint16 sdata; // send data Uint16 rdata; // received data // // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the F2806x_SysCtrl.c file. // InitSysCtrl(); // // Step 2. Initalize GPIO: // This example function is found in the F2806x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // //InitGpio(); // Skipped for this example // // Setup only the GP I/O only for SPI-A functionality // This function is found in F2806x_Spi.c // InitSpiaGpio(); // // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts // DINT; // // Initialize PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the F2806x_PieCtrl.c file. // InitPieCtrl(); // // Disable CPU interrupts and clear all CPU interrupt flags // IER = 0x0000; IFR = 0x0000; // // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in F2806x_DefaultIsr.c. // This function is found in F2806x_PieVect.c. // InitPieVectTable(); // // Step 4. Initialize all the Device Peripherals: // This function is found in F2806x_InitPeripherals.c // //InitPeripherals(); // Not required for this example spi_fifo_init(); // Initialize the Spi FIFO spi_init(); // init SPI // // Step 5. User specific code: // Interrupts are not used in this example. // sdata = 0x0000; for(;;) { // // Transmit data // spi_xmit(sdata); // // Wait until data is received // while(SpiaRegs.SPIFFRX.bit.RXFFST !=1) { } // // Check against sent data // rdata = SpiaRegs.SPIRXBUF; if(rdata != sdata) { error(); } sdata++; } } // // error - Step 7. Insert all local Interrupt Service Routines (ISRs) // and functions here // void error(void) { __asm(" ESTOP0"); // Test failed!! Stop! for (;;); } // // spi_init - // void spi_init() { SpiaRegs.SPICCR.all =0x000F; // Reset on, rising edge, 16-bit char bits // // Enable master mode, normal phase, enable talk, and SPI int disabled. // SpiaRegs.SPICTL.all =0x0006; SpiaRegs.SPIBRR =0x007F; SpiaRegs.SPICCR.all =0x009F; // Relinquish SPI from Reset SpiaRegs.SPIPRI.bit.FREE = 1; // Set so breakpoints don't disturb xmission } // // spi_xmit - // void spi_xmit(Uint16 a) { SpiaRegs.SPITXBUF=a; } // // spi_fifo_init - // void spi_fifo_init(void) { // // Initialize SPI FIFO registers // SpiaRegs.SPIFFTX.all=0xE040; SpiaRegs.SPIFFRX.all=0x2044; SpiaRegs.SPIFFCT.all=0x0; } // // End of File //
The above code is from ti example code for SPI, though data is received correctly in rdata but I probe the pin (GPIO18), there is no clock pulse. I also tried to turn off loopback but there is no clock pulse on the pin.
Any help is highly appreciated. Thanks.
