CCS/TMS320F28069: About HRPWM and SFO_TI_Build_V6b building errors
Part Number: TMS320F28069
Hi
I followed reference manual and tried to add HRPWM function in my project.
I also added "SFO_TI_Build_V6b.lib" to my project. But I got errors after building project.
Can someone point out what procedure  I missed?
Below is error description on con sole.
error #16008-D: file "../Code/lib/SFO_TI_Build_V6b.lib<SFO_V6b.obj>" specifies
   ISA revision "C2800", which is not compatible with ISA revision "C28FPU32"
   specified in a previous file or on the command line
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<fs_add.
   obj>" specifies ISA revision "C28FPU32", which is not compatible with ISA
   revision "C2700" specified in a previous file or on the command line
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<fs_mpy.
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<fs_toi.
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<u_tofs.
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<memcpy_
   ff.obj>" specifies ISA revision "C28FPU32", which is not compatible with ISA
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<boot.ob
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<args_ma
   in.obj>" specifies ISA revision "C28FPU32", which is not compatible with ISA
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<exit.ob
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<_lock.o
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<exp.obj
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<errno.o
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<ldexp.o
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<log.obj
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<frexp.o
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<pow.obj
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<i_div.o
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<_log.ob
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<sqrt.ob
   "C:/ti/ccs540/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_fpu32.lib<strncpy
warning #10063-D: entry-point symbol other than "_c_int00" specified:
   "code_start"
