i use F28388D controlCARD evaluation module
i want use ethercat example (f2838x_cm_pdi_hal_test_app, f2838x_cpu1_allocate_ecat_to_cm) with SYCON.net
i read documents(EtherCAT_Slave_Controller_User_Guide), this example use only twincat3
but i have hilscher's Ethercat PC Card(Master), that use SYCON.net
if i use that, i have some problems.
1. when i run ethercat example(f2838x_cm_pdi_hal_test_app, f2838x_cpu1_allocate_ecat_to_cm) , fail LED is flashing
checking break point, ESC_loadedCheckEEPROM() is fail.
and when this point blind, another all the points involved in EEPROM is fail
i cant understand that failure
do i other work before run example? or other problems ?
2. when i use SYCON.net, i can't find Device Description File(DDF) (.xml)
if i use SYCON.net, i have to find 28338D DDF file(.xml)
but i cant find
where is that file ?
