Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
I already update CCS latest version. But I can't see CLB5-CLB8 shown in the register window.
Vince,
What version of C2000Ware are you using? Please update to the latest version to get the most up-to-date software. Additionally, have you checked for updates and installed the updates for SysConfig and c2000?
Ozino
To fix this you can either edit the file named f28388d.xml with and add the lines below after the CLB registers, OR replace the f28388d.xml file with the one I attahced.
The f28388d.xml file is located at:
<CCS INSTALL>\ccs\ccs_base\common\targetdb\devices
This file includes:
<instance href="../Modules/C2000/f2838x_clb_logic_config_regs.xml" xml="f2838x_clb_logic_config_regs.xml" id="Clb5LogicCfgRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003800" endaddr="0x00038FF" size="0x0100" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_control_regs.xml" xml="f2838x_clb_logic_control_regs.xml" id="Clb5LogicCtrlRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003900" endaddr="0x000397F" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_data_exchange_regs.xml" xml="f2838x_clb_data_exchange_regs.xml" id="Clb5DataExchRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003980" endaddr="0x00039FF" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_config_regs.xml" xml="f2838x_clb_logic_config_regs.xml" id="Clb6LogicCfgRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003A00" endaddr="0x0003AFF" size="0x0100" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_control_regs.xml" xml="f2838x_clb_logic_control_regs.xml" id="Clb6LogicCtrlRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003B00" endaddr="0x0003B7F" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_data_exchange_regs.xml" xml="f2838x_clb_data_exchange_regs.xml" id="Clb6DataExchRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003B80" endaddr="0x0003BFF" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_config_regs.xml" xml="f2838x_clb_logic_config_regs.xml" id="Clb7LogicCfgRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003C00" endaddr="0x0003CFF" size="0x0100" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_control_regs.xml" xml="f2838x_clb_logic_control_regs.xml" id="Clb7LogicCtrlRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003D00" endaddr="0x0003D7F" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_data_exchange_regs.xml" xml="f2838x_clb_data_exchange_regs.xml" id="Clb7DataExchRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003D80" endaddr="0x0003DFF" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_config_regs.xml" xml="f2838x_clb_logic_config_regs.xml" id="Clb8LogicCfgRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003E00" endaddr="0x0003EFF" size="0x0100" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_logic_control_regs.xml" xml="f2838x_clb_logic_control_regs.xml" id="Clb8LogicCtrlRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003F00" endaddr="0x0003F7F" size="0x080" accessnumbytes="4" permissions="p" />
<instance href="../Modules/C2000/f2838x_clb_data_exchange_regs.xml" xml="f2838x_clb_data_exchange_regs.xml" id="Clb8DataExchRegs" xmlpath="../Modules/C2000/" baseaddr="0x00003F80" endaddr="0x0003FFF" size="0x080" accessnumbytes="4" permissions="p" />
