C2000 Team,
In the F28004x errata SPRZ439F, there is an advisory "PLL May Not Lock on the First Lock Attempt." Do we have any additional information on occurrence rate and occurrence conditions (e.g., supply voltage slew rate, temperature, etc.)? Any other information on this errata not already in the errata sheet?
Another question on this: since the watchdog timer is clocked directly from INTOSC1, is it correct that if the PLL fails to start the WD will still be running (assuming software hasn't disabled it) and will reset the device?
Thank you,
David
