Part Number: TMS320F28386D
Dear TI,
Looking on a web page I see 5-SPI interfaces:
But checking the data sheet I see 4-SPI interfaces
Which Information is correct?
Thanks a lot
BR
Marcin
Dear TI,
Thanks a lot
BR
Marcin
Dear Manoj,
Thanks a lot for quick answer. It was very helpful and we have decided to go with this device.
I have only 2 additional questions:
1. Do you have any evaluation boards with this DSP? If not which you can recommend as similar?
2. I plan to use ADC with SPI interface and connect it with DSP via McBSP. Do you have some references/examples/Guidelines for such a configuration?
Thanks a lot
BR
Marcin
Marcin,
F28388D controlCARD evaluation module
You find SPI and McBSP example in C2000Ware.
Manoj
Hi Manoj,
Thanks a lot for your great support. I hope this is my last question:
1. It is possible to configure both McBSPs as SPI and in the same time use 4- high speed SPIs? So in total 6-SPIs in the same time?
Thanks a lot
BR
Marcin
Marcin,
We indeed have 4 SPI + 1 SSI (CM side). So, totally you have 5 SPI (serial peripheral interface).
Additionally, you can use McBSP in SPI mode.
Manoj
