Part Number: C2000-GANG
Dear team,
My customer is using C2000-GANG.
After downloading C2000-GANG-1V046-Setup.zip from TI's official website, he opened the C2000-GANG software and connected the device to the laptop via USB. The following dialog box pops up:
The firmware version in the offline burner is displayed as 01.01.01.00, and the C2000-GANG software version downloaded from the official website is: 01.00.04.06. After clicking "OK", the firmware in the offline burner is flashed to 01.00.04.06.
After executing Copy file to Image, the program cannot be saved, as shown below
The self-test report :
=== C2000-GANG Self test results ( Thursday, November 19, 2020, 09:14:12 ) ===
Adapter SN ------: 19110075
Hardware --------: C2K : 01.04
Access key ------: C2000 - Gang Programmer
Silicon Number --: CE36 B46F 2E00 0C00
API Firmware ----: C2K-Gang AC28: 01.00.04.06
BOOT Firmware ---: G430BOOT B430: 01.00.02.00
GUI Software ----: C2000-Gang-GUI G28x: 01.00.04.06
DLL Software ----: C2000-Gang-DLL D280: 01.00.04.06
================ Test results =============
No. name parameter limits result status
1: Data Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
2: Data Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK <<
3: Data Bus (D-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK <<
4: Data Bus (D-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK <<
5: Data Bus (D-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK <<
6: Data Bus (D-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK <<
7: Data Bus (D-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK <<
8: Data Bus (D-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK <<
9: Data Bus (D-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK <<
10: Data Bus (D-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK <<
11: Data-2 Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
12: Data-2 Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK <<
13: Data-2 Bus (D2-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK <<
14: Data-2 Bus (D2-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK <<
15: Data-2 Bus (D2-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK <<
16: Data-2 Bus (D2-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK <<
17: Data-2 Bus (D2-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK <<
18: Data-2 Bus (D2-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK <<
19: Data-2 Bus (D2-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK <<
20: Data-2 Bus (D2-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK <<
21: Vcc Target-1 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.02 V ... >> OK <<
22: Vcc Target-2 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
23: Vcc Target-3 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
24: Vcc Target-4 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
25: Vcc Target-5 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
26: Vcc Target-6 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
27: Vcc Target-7 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
28: Vcc Target-8 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK <<
29: Translators VT (OFF) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK <<
30: Translators VT (ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 3.21 V ... >> OK <<
31: Vpp Voltage-in 10.00 V ( 8.00 to 12.00) Result: 10.19 V ... >> OK <<
32: Vpp Voltage 7.00 V ( 6.50 to 7.30) Result: 6.90 V ... >> OK <<
33: Internal Vcc-3.3V 3.30 V ( 3.20 to 3.40) Result: 3.31 V ... >> OK <<
34: Vcc Target-1 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.13 V ... >> ERROR <<
35: Vcc Target-2 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
36: Vcc Target-3 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
37: Vcc Target-4 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
38: Vcc Target-5 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
39: Vcc Target-6 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
40: Vcc Target-7 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
41: Vcc Target-8 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.12 V ... >> ERROR <<
42: Vcc discharge (50ms)Target-1 3.30 V ( 0.30 to 1.50) Result: 0.17 V ... >> ERROR <<
43: Vcc discharge (50ms)Target-2 3.30 V ( 0.30 to 1.50) Result: 0.17 V ... >> ERROR <<
44: Vcc discharge (50ms)Target-3 3.30 V ( 0.30 to 1.50) Result: 0.17 V ... >> ERROR <<
45: Vcc discharge (50ms)Target-4 3.30 V ( 0.30 to 1.50) Result: 0.17 V ... >> ERROR <<
46: Vcc discharge (50ms)Target-5 3.30 V ( 0.30 to 1.50) Result: 0.17 V ... >> ERROR <<
47: Vcc discharge (50ms)Target-6 3.30 V ( 0.30 to 1.50) Result: 0.16 V ... >> ERROR <<
48: Vcc discharge (50ms)Target-7 3.30 V ( 0.30 to 1.50) Result: 0.16 V ... >> ERROR <<
49: Vcc discharge (50ms)Target-8 3.30 V ( 0.30 to 1.50) Result: 0.17 V ... >> ERROR <<
50: Vcc Target-1 ( #1 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.17 V ... >> ERROR <<
51: Vcc Target-2 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
52: Vcc Target-3 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
53: Vcc Target-4 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
54: Vcc Target-5 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
55: Vcc Target-6 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
56: Vcc Target-7 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
57: Vcc Target-8 ( #1 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
58: Vcc Target-1 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
59: Vcc Target-2 ( #2 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.17 V ... >> ERROR <<
60: Vcc Target-3 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
61: Vcc Target-4 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
62: Vcc Target-5 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
63: Vcc Target-6 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
64: Vcc Target-7 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
65: Vcc Target-8 ( #2 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
66: Vcc Target-1 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
67: Vcc Target-2 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
68: Vcc Target-3 ( #3 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.17 V ... >> ERROR <<
69: Vcc Target-4 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
70: Vcc Target-5 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
71: Vcc Target-6 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
72: Vcc Target-7 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
73: Vcc Target-8 ( #3 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
74: Vcc Target-1 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
75: Vcc Target-2 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
76: Vcc Target-3 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
77: Vcc Target-4 ( #4 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.17 V ... >> ERROR <<
78: Vcc Target-5 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
79: Vcc Target-6 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
80: Vcc Target-7 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
81: Vcc Target-8 ( #4 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
82: Vcc Target-1 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
83: Vcc Target-2 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
84: Vcc Target-3 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
85: Vcc Target-4 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
86: Vcc Target-5 ( #5 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.17 V ... >> ERROR <<
87: Vcc Target-6 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
88: Vcc Target-7 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
89: Vcc Target-8 ( #5 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
90: Vcc Target-1 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
91: Vcc Target-2 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
92: Vcc Target-3 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
93: Vcc Target-4 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
94: Vcc Target-5 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
95: Vcc Target-6 ( #6 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.16 V ... >> ERROR <<
96: Vcc Target-7 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
97: Vcc Target-8 ( #6 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
98: Vcc Target-1 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
99: Vcc Target-2 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
100: Vcc Target-3 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
101: Vcc Target-4 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
102: Vcc Target-5 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
103: Vcc Target-6 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
104: Vcc Target-7 ( #7 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.16 V ... >> ERROR <<
105: Vcc Target-8 ( #7 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
106: Vcc Target-1 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
107: Vcc Target-2 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
108: Vcc Target-3 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
109: Vcc Target-4 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
110: Vcc Target-5 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
111: Vcc Target-6 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK <<
112: Vcc Target-7 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK <<
113: Vcc Target-8 ( #8 ON ) 3.30 V ( 3.10 to 3.50) Result: 0.17 V ... >> ERROR <<
114: SD Power OFF 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
115: SD Power ON 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
116: SD Discharge - delay 2ms 0x0010 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
117: SD Discharge - delay 50ms 0x0010 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
118: BSL RX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
119: BSL RX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
120: BSL RX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
121: BSL RX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
122: BSL RX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
123: BSL RX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
124: BSL RX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
125: BSL RX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
126: BSL TX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
127: BSL TX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
128: BSL TX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
129: BSL TX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
130: BSL TX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
131: BSL TX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
132: BSL TX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
133: BSL TX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
134: TDI bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
135: TDI bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
136: TDI bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
137: TDI bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
138: TDI bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
139: TDI bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
140: TDI bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
141: TDI bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
142: TDIO Tx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
143: TDIO Tx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
144: TDIO Tx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
145: TDIO Tx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
146: TDIO Tx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
147: TDIO Tx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
148: TDIO Tx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
149: TDIO Tx-bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
150: TDIO Tx-Rx (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
151: TDIO Tx-Rx (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
152: TDIO Tx-Rx (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
153: TDIO Tx-Rx (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
154: TDIO Tx-Rx (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
155: TDIO Tx-Rx (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
156: TDIO Tx-Rx (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
157: TDIO Tx-Rx (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
158: TDIO Rx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
159: TDIO Rx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
160: TDIO Rx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
161: TDIO Rx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
162: TDIO Rx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
163: TDIO Rx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
164: TDIO Rx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
165: TDIO Rx-bus (#84 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
166: TMS bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK <<
167: TMS bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
168: TMS bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
169: TMS bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
170: TMS bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
171: TMS bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
172: TMS bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
173: TMS bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
174: TMS bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
175: TMS bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
176: RST bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK <<
177: RST bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK <<
178: RST bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
179: RST bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
180: RST bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
181: RST bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
182: RST bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
183: RST bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
184: RST bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
185: RST bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
186: Keys buffer (All pull-up) 0x001F (0x001F - 0x001F) Result: 0x1F ... >> OK <<
187: Access to LCD RAM (0xAA) 0x00AA (0x00AA - 0x00AA) Result: 0xAA ... >> OK <<
188: Access to LCD RAM (0x99) 0x0099 (0x0099 - 0x0099) Result: 0x99 ... >> OK <<
189: Image Flash Access (get ID) 0x0002 (0x0001 - 0x0002) Result: 0x00 ... >> ERROR <<
190: TDI Fuse keys (#1 ON) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK <<
191: TDI Fuse keys (#2 ON) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK <<
192: TDI Fuse keys (#3 ON) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK <<
193: TDI Fuse keys (#4 ON) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK <<
194: TDI Fuse keys (#5 ON) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK <<
195: TDI Fuse keys (#6 ON) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK <<
196: TDI Fuse keys (#7 ON) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK <<
197: TDI Fuse keys (#8 ON) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK <<
198: TEST Fuse keys (#1 ON) 1.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
199: TEST Fuse keys (#2 ON) 2.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
200: TEST Fuse keys (#3 ON) 3.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
201: TEST Fuse keys (#4 ON) 4.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
202: TEST Fuse keys (#5 ON) 5.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
203: TEST Fuse keys (#6 ON) 6.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
204: TEST Fuse keys (#7 ON) 7.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
205: TEST Fuse keys (#8 ON) 8.00 ( 2.80 to 3.50) Result: 0.00 ... >> ERROR <<
============== Finished =================================
* Test failed!! 33 error(s).
Please help.
