TMS320F28335: F28335
Part Number: TMS320F28335
I am using using Matlab Simulink with f28335 control card.
My question is about the sampling time. I noted that when I used 1e-5 "Fixed-step size , the card not respect this fixed step in some cases .
To check this i tried to generate a square wave with a frequency of 1e-4 through the I / O gates.
 Here is the result I found:
1- When the program is small (a few instruction lines), the card can generate the correct signal (period = 1e-4) ,ie ( program of test alon)
2- When the program is contains multiple instructions (~ 1000, ie program of test + other programs), the card  generated a false signal (period = 1e-3)
I need to use sampling time 0f 1e-5 , how can I do that?
Thank you in advance
