tms320f28027 Piccolo Analog Grounding
Hello, I am trying to figure out where to ground the VSSA pin, and the bypass for VCCA.  Assume I have separate ground planes for digital and analog signals, and that they are joined far away (required by application, we have much higher resolution ADC's connected to a related set of analog signals).  Should I ground both the VSSA and the bypass to my analog ground plane?
- Judson
  • Judson,
    Yes, that is what I would do.  VSSA and the bypass for VCCA will benefit from having a cleaner signal path.  Having the connection between the analog and digital grounds far away shouldn't be a concern as long as connection between the two is "large enough".  (I'm no expert on defining "large enough", but I'd make it greater than 0.5mm)
    Thank you,
    Brett Larimore
