Part Number: TMS320F280049C
I'm seeking guidance on what options exist for creating a user interface, and suggestions from more experienced individuals on what solution may work best for my needs.
The controller will adjust sinusoidal voltage signals at the output of a system. The signals will be pre-defined to modulate magnitude, frequency, phase.
The user must be able to call pre-defined routines from some sort of menu or directory (GUI or command line). The routine runs to completion and the user may select another routine to run. Ideally the interface could also support a second control mode allowing the user to adjust parameters in real time.
I've started looking at GUI composer as well as the various communication peripherals included on the device. It's a lot to take in and I'd appreciate help identifying the best options.
