CCS/TMS320F28377S: CCS6.1.0
Part Number: TMS320F28377S
Thanks for John 's answer. In order to find the On-Chip flash option in the Tools menu and input the preset F28377s password, how can I enter the active debug session? If the password of F28377s has been activated, when I press F11 to debug, CCS6.1.0 will display an error and can't debug. If I select the retry button, CCS6.1.0 will display the same error and can only select the Cancel button to exit debug. The On-Chip flash option still does not appear in the Tools menu.
  • Hi ,
    You mentioned that you are able to find "On-Chip flash option in the Tools menu" and then in last sentence you said that "The On-Chip flash option still does not appear in the Tools menu.". This is confusing.
    You Ist need to enter the debug session by connecting to target CPU and then you should be able to see the On-Chip Flash option under Tools menu.
    Vivek Singh
