Part Number: TMS320F280025
For F28002x, in f28002x_clbxbar.h CLB Xbar register name is given as 'ClbXbarRegs' whereas for other processors it is 'CLBXbarRegs'. Is this intentional or will it be changed in the future updates?
Hi Irene,
Not sure why there is a difference, will check it out and respond to you at the earliest. I think the header files are updated using a script , will look into it and see why there is a difference.
Best Regards
Siddharth
Hi Irene,
As Siddharth mentioned, the headers are script generated from the spec. The TRM had defined the names with CLBXbarRegs for f28004x and ClbXbarRegs for f28002x. We will make sure the naming is consistent for the future devices.
As a workaround for you can add a macro which defines CLBXbarRegs as ClbXbarRegs.
Veena
