Part Number: TMS320F280025-Q1
Hi Experts,
I would like to avoid unwanted pulse output by ePWM just after the PWM configuration is done.
Please let me clarify with you which one is correct procedure for the setting A) or B).
A) GPIO configuration -> PWM configuration by following the procedure 1 to 4 described in 17.4.3.2 Time-Base Clock Synchronization.(TRM)
B) PWM configuration by following the procedure 1 to 4 described in 17.4.3.2 Time-Base Clock Synchronization -> GPIO configuration.
Our C2000ware example follows A).
According to the e2e : https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/334305
It seems that B) is recommended.
Could you please check it.
If B) is correct, is there any wait time necessary after the procedure 1 to 4 is done.
For example, it has to wait for a PWM timer period, etc.
Hitoshi
