hello.
i hav build a model in simulink real time workshop using ert.tlc, ccslink_ert.tlc,both buils perfactly upto downloaded code .out file,
but when i use it in external mode its giving error of data map file:
Could not execute target data map file 'model_ccslink\model_targ_data_map' or it does not exist. Stop the target, delete the shakeel executable, rebuild the code, and try again. Note that execution of external mode requires the build directory to be present."
i connected my computer to ezdspF2812 kit using printer cable.i m running my model in computer to get the input signal applied at adcin0 pin of the kit .but the kit is not getting connected using matlab
Matlab R2007a
CCS v3.1
dsp KIT ezdsp F2812; connected using printer cable with computre
