Part Number: TMS320F28388D
Hi Everyone,
I have a problem when try to connect the the DSP "TMS320F28388D" with the XDS200 USB JTAG Emulator over JTAG.
Sometimes it is working on the first attempt but often i get this error:
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.1.00046)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1135 @ 0x16A4E) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.1.00046)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
The error occures when i press the startbutton.
When I terminate the debugsession and restart it after 2,3 or 4 attempts it is working.
Once i have running DSP the connection is stable.
Can someone help me? What can i do to fix this error?
Best regards
Jan Hummel
