Part Number: TMS320F28335
Hello!
My topology is Phase shift full bridge. I using the up count for EPWM3A/3B for leading leg and EPWM4A/4B for legging lag.
When I changed the TBPHS from 1459 to 15 , EPWM will lose one cycle.
My settings and waveform are shown below.
TBPRD=1500
CMPA=750
EPwm3Regs.DBRED = 60;
EPwm3Regs.DBFED = 60;
EPwm3Regs.AQCTLA.bit.ZRO = AQ_SET;
EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm3Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
EPwm3Regs.AQCTLB.bit.CAU = AQ_SET;
EPWM1 is Master
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;
EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
I know this problem is first cycle after this change, EPWM3 will not go to CTR = 0.
I have tried to change the period (I think TBPRD-1, or I’m wrong?), but this problem is not solved.
What is the best suggestion for solving this problem?
thanks
