Part Number: TMS320F280025
we have configured the clock source as INT_OSC2, and main CPU frequency to be 100MHz, but the program will stop in the place below:
after I click resume, it will work correctly.
The system configuration code is as below, could you please tell what's wrong here?
// FILE: f28002x_sysctrl.c
// TITLE: f28002x Device System Control Initialization & Support Functions.
// DESCRIPTION: Example initialization of system resources.
// $TI Release: F28002x Support Library v3.04.00.00 $
// $Release Date: Fri Feb 12 18:58:34 IST 2021 $
// $Copyright:
// Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "f28002x_device.h" // Headerfile Include File
#include "f28002x_examples.h" // Examples Include File
// Functions that will be run from RAM need to be assigned to a different
// section. This section will then be mapped to a load and run address using
// the linker cmd file.
// *IMPORTANT*
// IF RUNNING FROM FLASH, PLEASE COPY OVER THE SECTION ".TI.ramfunc" FROM
// FLASH TO RAM PRIOR TO CALLING InitSysCtrl(). THIS PREVENTS THE MCU FROM
// THROWING AN EXCEPTION WHEN A CALL TO DELAY_US() IS MADE.
#pragma CODE_SECTION(InitFlash, ".TI.ramfunc");
#pragma CODE_SECTION(FlashOff, ".TI.ramfunc");
// The following values are used to validate PLL Frequency using DCC
#define DCC_COUNTER0_TOLERANCE 1
// Macro used for adding delay between 2 consecutive writes to CLKSRCCTL1
// register.
// Delay = 300 NOPs
#define SYSCTRL_CLKSRCCTL1_DELAY asm(" RPT #250 || NOP \n RPT #50 || NOP")
// InitSysCtrl - Initialization of system resources.
void InitSysCtrl(void)
// Disable the watchdog
DisableDog();
// Call Device_cal function when run using debugger
// This function is called as part of the Boot code. The function is called
// in the InitSysCtrl function since during debug time resets, the boot code
// will not be executed and the gel script will reinitialize all the
// registers and the calibrated values will be lost.
EALLOW;
CpuSysRegs.PCLKCR13.bit.ADC_A = 1; // Enable ADC peripheral clock
CpuSysRegs.PCLKCR13.bit.ADC_C = 1;
(*Device_cal)();
CpuSysRegs.PCLKCR13.bit.ADC_A = 0; // Return ADC clock to original state
CpuSysRegs.PCLKCR13.bit.ADC_C = 0;
EDIS;
// Initialize the SYSPLL control to generate a 200Mhz clock
// Defined options to be passed as arguments to this function are defined
// in f2838x_examples.h.
// Note: The internal oscillator CANNOT be used as the PLL source if the
// PLLSYSCLK is configured to frequencies above 194 MHz.
// PLLSYSCLK = (XTAL_OSC) * (IMULT) /(REFDIV) * (ODIV) * (PLLSYSCLKDIV)
InitSysPll(INT_OSC2, IMULT_30, REFDIV_1, ODIV_3, PLLCLK_BY_1, SYSCTL_DCC_BASE0); //ʹ���ڲ�����
// Initialize the peripheral clocks
InitPeripheralClocks();
// InitPeripheralClocks - Initializes the clocks for the peripherals.
// Note: In order to reduce power consumption, turn off the clocks to any
// peripheral that is not specified for your part-number or is not used in the
// application
void InitPeripheralClocks(void)
EALLOW;
CpuSysRegs.PCLKCR0.bit.DMA = 1;
CpuSysRegs.PCLKCR0.bit.CPUTIMER0 = 1;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
CpuSysRegs.PCLKCR0.bit.CPUBGCRC = 1;
CpuSysRegs.PCLKCR2.bit.EPWM1 = 1;
CpuSysRegs.PCLKCR2.bit.EPWM2 = 1;
CpuSysRegs.PCLKCR2.bit.EPWM6 = 1;
CpuSysRegs.PCLKCR10.bit.CAN_A = 1;
CpuSysRegs.PCLKCR14.bit.CMPSS1 = 1;
CpuSysRegs.PCLKCR14.bit.CMPSS2 = 1;
CpuSysRegs.PCLKCR14.bit.CMPSS3 = 1;
CpuSysRegs.PCLKCR14.bit.CMPSS4 = 1;
EDIS;
// DisablePeripheralClocks - Gates-off all peripheral clocks.
void DisablePeripheralClocks(void)
EALLOW;
CpuSysRegs.PCLKCR0.all = 0;
CpuSysRegs.PCLKCR2.all = 0;
CpuSysRegs.PCLKCR3.all = 0;
CpuSysRegs.PCLKCR4.all = 0;
CpuSysRegs.PCLKCR7.all = 0;
CpuSysRegs.PCLKCR8.all = 0;
CpuSysRegs.PCLKCR9.all = 0;
CpuSysRegs.PCLKCR10.all = 0;
CpuSysRegs.PCLKCR13.all = 0;
CpuSysRegs.PCLKCR14.all = 0;
CpuSysRegs.PCLKCR19.all = 0;
CpuSysRegs.PCLKCR20.all = 0;
CpuSysRegs.PCLKCR21.all = 0;
EDIS;
// InitFlash - This function initializes the Flash Control registers.
// *CAUTION*
// This function MUST be executed out of RAM. Executing it out of OTP/Flash
// will yield unpredictable results.
#ifdef __cplusplus
#pragma CODE_SECTION(".TI.ramfunc");
#endif
void InitFlash(void)
EALLOW;
// At reset bank and pump are in sleep. A Flash access will power up the
// bank and pump automatically.
// Power up Flash bank and pump. This also sets the fall back mode of
// flash and pump as active.
Flash0CtrlRegs.FPAC1.bit.PMPPWR = 0x1;
Flash0CtrlRegs.FBFALLBACK.bit.BNKPWR0 = 0x3;
// Disable Cache and prefetch mechanism before changing wait states
Flash0CtrlRegs.FRD_INTF_CTRL.bit.DATA_CACHE_EN = 0;
Flash0CtrlRegs.FRD_INTF_CTRL.bit.PREFETCH_EN = 0;
// Set waitstates according to frequency
// *CAUTION*
// Minimum waitstates required for the flash operating at a given CPU rate
// must be characterized by TI. Refer to the datasheet for the latest
// information.
#if CPU_FRQ_100MHZ
Flash0CtrlRegs.FRDCNTL.bit.RWAIT = 0x4;
#endif
// Enable Cache and prefetch mechanism to improve performance of code
// executed from Flash.
Flash0CtrlRegs.FRD_INTF_CTRL.bit.DATA_CACHE_EN = 1;
Flash0CtrlRegs.FRD_INTF_CTRL.bit.PREFETCH_EN = 1;
// At reset, ECC is enabled. If it is disabled by application software and
// if application again wants to enable ECC.
Flash0EccRegs.ECC_ENABLE.bit.ENABLE = 0xA;
EDIS;
// Force a pipeline flush to ensure that the write to the last register
// configured occurs before returning.
__asm(" RPT #7 || NOP");
// FlashOff - This function powers down the flash
// *CAUTION*
// will yield unpredictable results. Also you must seize the flash pump in
// order to power it down.
#ifdef __cplusplus
#endif
void FlashOff(void)
EALLOW;
// Power down bank
Flash0CtrlRegs.FBFALLBACK.bit.BNKPWR0 = 0;
// Power down pump
Flash0CtrlRegs.FPAC1.bit.PMPPWR = 0;
EDIS;
// ServiceDog - This function resets the watchdog timer.
// Enable this function for using ServiceDog in the application.
void ServiceDog(void)
EALLOW;
WdRegs.WDKEY.bit.WDKEY = 0x0055;
WdRegs.WDKEY.bit.WDKEY = 0x00AA;
EDIS;
// DisableDog - This function disables the watchdog timer.
void DisableDog(void)
volatile Uint16 temp;
// Grab the clock config first so we don't clobber it
EALLOW;
temp = WdRegs.WDCR.all & 0x0007;
WdRegs.WDCR.all = 0x0068 | temp;
EDIS;
// Example: EnableDog:
// This function enables the watchdog timer.
#pragma CODE_SECTION(EnableDog, ".TI.ramfunc");
void EnableDog(void)
EALLOW;
WdRegs.WDCR.all= 0x002E;
EDIS;
// InitPll - This function initializes the PLL registers.
// Note: This function uses the DCC to check that the PLLRAWCLK is running at
// the expected rate. The desirable DCC can be provided as a parameter.
void InitSysPll(Uint16 clock_source, Uint16 imult, Uint32 refdiv, Uint32 odiv,
Uint16 divsel, Uint32 dccbase)
Uint32 timeout,temp_syspllmult, pllLockStatus;
bool status;
if(((clock_source & 0x3) == ClkCfgRegs.CLKSRCCTL1.bit.OSCCLKSRCSEL) &&
(((clock_source & 0x4) >> 2) == ClkCfgRegs.XTALCR.bit.SE) &&
(imult == ClkCfgRegs.SYSPLLMULT.bit.IMULT) &&
(refdiv == ClkCfgRegs.SYSPLLMULT.bit.REFDIV) &&
(odiv == ClkCfgRegs.SYSPLLMULT.bit.ODIV) &&
(divsel == ClkCfgRegs.SYSCLKDIVSEL.bit.PLLSYSCLKDIV))
// Everything is set as required, so just return
return;
EALLOW;
// First modify the PLL multipliers if the multipliers need an update or PLL needs
// to be powered on / enabled
if((imult != ClkCfgRegs.SYSPLLMULT.bit.IMULT) ||
(refdiv != ClkCfgRegs.SYSPLLMULT.bit.REFDIV)||
(odiv != ClkCfgRegs.SYSPLLMULT.bit.ODIV) ||
(1U != ClkCfgRegs.SYSPLLCTL1.bit.PLLEN))
// Bypass PLL and set dividers to /1
ClkCfgRegs.SYSPLLCTL1.bit.PLLCLKEN = 0;
// Delay of at least 120 OSCCLK cycles required post PLL bypass
asm(" RPT #120 || NOP");
// Evaluate PLL multipliers and dividers
temp_syspllmult = ((refdiv << 24U) | (odiv << 16U)| imult);
// Turnoff the PLL
ClkCfgRegs.SYSPLLCTL1.bit.PLLEN = 0;
EDIS;
// Delay of at least 66 OSCCLK cycles
asm(" RPT #66 || NOP");
if(((clock_source & 0x3) != ClkCfgRegs.CLKSRCCTL1.bit.OSCCLKSRCSEL) ||
(((clock_source & 0x4) >> 2) != ClkCfgRegs.XTALCR.bit.SE))
switch (clock_source)
case INT_OSC1:
SysIntOsc1Sel();
break;
case INT_OSC2:
SysIntOsc2Sel();
break;
case XTAL_OSC:
SysXtalOscSel();
break;
case XTAL_OSC_SE:
SysXtalOscSESel();
break;
// Delay of at least 60 OSCCLK cycles
asm(" RPT #60 || NOP");
EALLOW;
// Set dividers to /1 to ensure the fastest PLL configuration
ClkCfgRegs.SYSCLKDIVSEL.bit.PLLSYSCLKDIV = 0;
// Program PLL multipliers
ClkCfgRegs.SYSPLLMULT.all = temp_syspllmult;
// Enable SYSPLL
ClkCfgRegs.SYSPLLCTL1.bit.PLLEN = 1;
// Lock time is 1024 OSCCLK * (REFDIV+1)
timeout = (1024U * (refdiv + 1U));
pllLockStatus = ClkCfgRegs.SYSPLLSTS.bit.LOCKS;
// Wait for the SYSPLL lock
while((pllLockStatus != 1) && (timeout != 0U))
timeout--;
EDIS;
// Check PLL Frequency using DCC
status = IsPLLValid(dccbase, clock_source, INT_PLL_SYSPLL,
imult, odiv , refdiv);
else
// Re-Lock of PLL not needed since the multipliers
// are not updated
status = true;
if(status)
EALLOW;
// Set divider to produce slower output frequency to limit current increase
if(divsel != PLLCLK_BY_126)
ClkCfgRegs.SYSCLKDIVSEL.bit.PLLSYSCLKDIV = divsel + 1;
else
ClkCfgRegs.SYSCLKDIVSEL.bit.PLLSYSCLKDIV = divsel;
// Enable PLLSYSCLK is fed from system PLL clock
ClkCfgRegs.SYSPLLCTL1.bit.PLLCLKEN = 1;
// Small 100 cycle delay
asm(" RPT #100 || NOP");
// Set the divider to user value
EDIS;
else
ESTOP0; // If the frequency is out of range, stop here.
// SysIntOsc1Sel - This function switches to Internal Oscillator 1.
void SysIntOsc1Sel(void)
EALLOW;
ClkCfgRegs.CLKSRCCTL1.bit.OSCCLKSRCSEL = 2; // Clk Src = INTOSC1
EDIS;
// SysIntOsc2Sel - This function switches to Internal oscillator 2.
void SysIntOsc2Sel(void)
EALLOW;
ClkCfgRegs.CLKSRCCTL1.bit.OSCCLKSRCSEL = 0; // Clk Src = INTOSC2
EDIS;
// PollX1Counter - Clear the X1CNT counter and then wait for it to saturate
// four times.
static void
PollX1Counter(void)
Uint16 loopCount = 0;
// Delay for 1 ms while the XTAL powers up
// 2000 loops, 5 cycles per loop + 9 cycles overhead = 10009 cycles
F28x_usDelay(2000);
// Clear and saturate X1CNT 4 times to guarantee operation
do
// Keep clearing the counter until it is no longer saturated
while(ClkCfgRegs.X1CNT.all > 0x1FF)
ClkCfgRegs.X1CNT.bit.CLR = 1;
ClkCfgRegs.X1CNT.bit.CLR = 0;
// Wait for the X1 clock to saturate
while(ClkCfgRegs.X1CNT.all != 0x7FFU)
// Increment the counter
loopCount++;
}while(loopCount < 4);
// SysXtalOscSel - This function switches to External CRYSTAL oscillator.
void SysXtalOscSel(void)
EALLOW;
ClkCfgRegs.XTALCR.bit.OSCOFF = 0; // Turn on XTALOSC
ClkCfgRegs.XTALCR.bit.SE = 0; // Select crystal mode
EDIS;
PollX1Counter();
// Select XTAL as the oscillator source
EALLOW;
ClkCfgRegs.CLKSRCCTL1.bit.OSCCLKSRCSEL = 1;
EDIS;
// If a missing clock failure was detected, try waiting for the X1 counter
// to saturate again. Consider modifying this code to add a 10ms timeout.
while(ClkCfgRegs.MCDCR.bit.MCLKSTS != 0)
EALLOW;
ClkCfgRegs.MCDCR.bit.MCLKCLR = 1;
EDIS;
PollX1Counter();
EALLOW;
EDIS;
// SysXtalOscSESel - This function switches to external oscillator in
// single-ended mode and turns off all other clock sources to minimize power
// consumption. This option may not be available on all device packages
void
SysXtalOscSESel (void)
EALLOW;
ClkCfgRegs.XTALCR.bit.SE = 1; // Select single-ended mode
EDIS;
PollX1Counter();
// Select XTALOSC as the oscillator source
EALLOW;
EDIS;
// If missing clock detected, there is something wrong with the oscillator
// module.
if(ClkCfgRegs.MCDCR.bit.MCLKSTS != 0)
ESTOP0;
// IDLE - Enter IDLE mode
void
IDLE()
EALLOW;
CpuSysRegs.LPMCR.bit.LPM = LPM_IDLE;
EDIS;
asm(" IDLE");
// HALT - Enter HALT mode
void
HALT()
EALLOW;
CpuSysRegs.LPMCR.bit.LPM = LPM_HALT;
EDIS;
asm(" IDLE");
// SysCtl_isPLLValid()
bool
IsPLLValid(Uint32 base, Uint16 oscSource, Uint16 pllclk, Uint16 imult,
Uint16 odiv, Uint16 refdiv)
float fclk1_0ratio;
volatile struct DCC_REGS *DccRegs;
EALLOW;
// Assigning DCC for PLL validation
// Enable Peripheral Clock Domain PCLKCR21 for DCC
if(base == SYSCTL_DCC_BASE0)
DccRegs = &Dcc0Regs;
CpuSysRegs.PCLKCR21.bit.DCC0 = 1;
else if(base == SYSCTL_DCC_BASE1)
DccRegs = &Dcc1Regs;
CpuSysRegs.PCLKCR21.bit.DCC1 = 1;
else
ESTOP0; // Invalid DCC selected
// Clear Error & Done Flag
DccRegs->DCCSTATUS.bit.ERR = 1;
DccRegs->DCCSTATUS.bit.DONE = 1;
// Disable DCC
DccRegs->DCCGCTRL.bit.DCCENA = 0x5;
// Disable Error Signal
DccRegs->DCCGCTRL.bit.ERRENA = 0x5;
// Disable Done Signal
DccRegs->DCCGCTRL.bit.DONEENA = 0x5;
// Configure Clock Source1 to PLL
// Clk Src1 Key 0xA to enable clock source selection
switch(pllclk)
case INT_PLL_SYSPLL:
DccRegs->DCCCLKSRC1.all = 0xA000; // Clk Src1 = SYSPLL
break;
default:
// Code shouldn't reach here
break;
// Configure Clock Source0 to whatever is set as a reference
// clock source for PLL
// Clk Src0 Key 0xA to enable clock source selection
switch(oscSource)
case INT_OSC1:
DccRegs->DCCCLKSRC0.all = 0xA001; // Clk Src0 = INTOSC1
break;
case INT_OSC2:
DccRegs->DCCCLKSRC0.all = 0xA002; // Clk Src0 = INTOSC2
break;
case XTAL_OSC:
case XTAL_OSC_SE:
DccRegs->DCCCLKSRC0.all = 0xA000; // Clk Src0 = XTAL
break;
default:
break;
// Calculating frequency ratio of output clock(f1) vs reference clock(f0)
fclk1_0ratio = (float)imult / ((odiv + 1U) * (refdiv + 1));
// Computing and configuring Counter0 , Counter1 & Valid Seed Values
// with +/-1% tolerance for the desired DCC
ComputeCntrSeedValue(base, fclk1_0ratio, DCC_COUNTER0_TOLERANCE);
// Enable Single Shot Mode
DccRegs->DCCGCTRL.bit.SINGLESHOT = 0xA;
// Enable DCC to start counting
DccRegs->DCCGCTRL.bit.DCCENA = 0xA;
EDIS;
// Wait until Error or Done Flag is generated
while((DccRegs->DCCSTATUS.all & 3) == 0)
// Returns true if DCC completes without error
return((DccRegs->DCCSTATUS.all & 3) == 2);
// ComputeCntSeedValid - Compute Counter seed values based on the frequency ratio of output
// clock vs reference clock & tolerance expected for the desired DCC
void ComputeCntrSeedValue(Uint32 base, float fclk1_0ratio, Uint32 tolerance)
Uint32 window, dccCounterSeed0, dccValidSeed0, dccCounterSeed1, total_error;
if(fclk1_0ratio >= 1U)
// Setting Counter0 & Valid Seed Value with expected tolerance
// Total error is 12
window = (12U * 100U) / tolerance;
dccCounterSeed0 = window - 12U;
dccValidSeed0 = 24U;
else
total_error = (((Uint32)2U / fclk1_0ratio) + (Uint32)10U);
window = ((total_error * 100U)/ tolerance);
dccCounterSeed0 = window - total_error;
dccValidSeed0 = (Uint32)2U * total_error;
// Multiplying Counter-0 window with PLL Integer Multiplier
dccCounterSeed1 = window * fclk1_0ratio;
else
// Configure COUNTER-0, COUNTER-1 & Valid Window
DccRegs->DCCCNTSEED0.bit.COUNTSEED0 = dccCounterSeed0; // Loaded Counter0 Value
DccRegs->DCCVALIDSEED0.bit.VALIDSEED = dccValidSeed0; // Loaded Valid Value
DccRegs->DCCCNTSEED1.bit.COUNTSEED1 = dccCounterSeed1; // Loaded Counter1 Value
// End of File
The customer would like to configure through registers like in F2803x, so the example code which uses HANDLE is not friendly to them.
