I had this customer who uses LaunchXL-F28379D. He encounters many errors and he needs instructions on how to restore factory setting.
I will list below the errors he encounter and it is better if you could help us to explain what is the meaning and cause of the error.
C28xx_CPU1: GEL Output: Memory Map Initialization Complete
C28xx_CPU1: Error initializing flash programming: Interface returned from dll, but flash is not available on this device.
C28xx_CPU1: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
C28xx_CPU1: File Loader: Verification failed: Values at address 0x82000@Program do not match Please verify target memory and memory map.
C28xx_CPU1: GEL: File: C:\Users\Gabriele\workspace_v10\gfd\Debug\gfd.out: a data verification error occurred, file load failed.
I hope you can help us with the errors and a better solution to fix these errors aside to restore factory settings. Thank you very much.
Ray Vincent
