Other Parts Discussed in Thread: MIDAS
I am trying to port the MIDAS OCT demo from the C6678 to the C6472 and I am now stuck at an issue that I cannot seem to fix: a call to RMAN_assignResources fails with status=7 (IRES_ENORESOURCE).
The trace log indicates that the issue stems from a call to EDMA3_RM_open which fails with error 0xffffff62, which apparently translates into EDMA3_RM_E_INVALID_PARAM. The relevant part of the trace log reads:
[+2] EDMA3_getResourceManager> Opening System Resource Manager Handle
[+E] openRMHandle> Enter (scratchId=-1, sem=0x9105828)
[+2] openRMHandle> System RM handle requested
[+7] openRMHandle> Error opening RM handle requested, status 0xffffff62
[+X] openRMHandle> Exit (handle=NULL)
[+7] EDMA3_getResourceManager> Error opening System Resource Manager Handle
One thing I find curious is that scratchId is -1, while I only request scratchId 0 (I don't know if that is normal or not).
Another possible issue might stem from the EDMA3_RM_InstanceInitConfig structure that I am currently using. I have copied this verbatim from EDMA3_C6472_cfg.c and I have no idea if I need to change something in there (I haven't been able to find any documentation on the hex values in that file.) How and when am I supposed to modify this file?
I am building with C6000 compiler v7.4.2, XDCTools 3.24.5.48 and linking with FC 3.23.1.14, CE 3.23.0.07, EDMA3 2.11.6, XDAIS 7.23.0.06 and SYS/BIOS 6.34.3.19. My trace log, SYS/BIOS and EDMA3 configurations are attached.
I would be happy for any ideas or advice on this issue!
* @file edma3_config.c
* @brief EDMA3's InstanceInitConfig
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <xdc/std.h>
#include <ti/sdo/fc/edma3/edma3_config.h>
#include <ti/sdo/edma3/rm/edma3_rm.h>
#define NUM_EDMA3_INSTANCES 1u
EDMA3_RM_InstanceInitConfig C6472_config [NUM_EDMA3_INSTANCES][EDMA3_MAX_REGIONS] =
/* Resources owned by Region 0 */
/* ownPaRAMSets */
/* 31 0 63 32 95 64 127 96 */
{0x00000000u, 0x00000000u, 0xFFFFFFFFu, 0x00000000u,
/* 159 128 191 160 223 192 255 224 */
0x00000000u, 0x00000000u, 0x00000000u, 0x00000000u,
/* 287 256 319 288 351 320 383 352 */
/* 415 384 447 416 479 448 511 480 */
0x00000000u, 0x00000000u, 0x00000000u, 0x00000000u,},
/* ownDmaChannels */
/* 31 0 63 32 */
{0x000000FFu, 0x00000000u},
/* ownQdmaChannels */
/* 31 0 */
{0x00000001u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 0 */
/* resvdPaRAMSets */
{0xFFFFFFFFu, 0xFFFFFFFFu, 0x00000000u, 0x00000000u,
/* resvdDmaChannels */
/* 31 0 63 32 */
{0xFFFF0000u, 0x00000000u},
/* resvdQdmaChannels */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 1 */
/* ownPaRAMSets */
{0x00000000u, 0x00000000u, 0x00000000u, 0xFFFFFFFFu,
/* 31 0 63 32 */
{0x0000FF00u, 0x00000000u},
/* 31 0 */
{0x00000002u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 1 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 2 */
/* ownPaRAMSets */
{0x00000000u, 0x00000000u, 0x00000000u, 0x00000000u,
0xFFFFFFFFu, 0x00000000u, 0x00000000u, 0x00000000u,
/* 31 0 63 32 */
{0x00000000u, 0x000000FFu},
/* 31 0 */
{0x00000004u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 2 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 3 */
/* ownPaRAMSets */
0x00000000u, 0xFFFFFFFFu, 0x00000000u, 0x00000000u,
/* 31 0 63 32 */
{0x00000000u, 0x0000FF00u},
/* 31 0 */
{0x00000008u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 3 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 4 */
/* ownPaRAMSets */
/* 31 0 63 32 */
{0x00000000u, 0x00FF0000u},
/* 31 0 */
{0x00000008u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 4 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 5 */
/* ownPaRAMSets */
/* 31 0 63 32 */
{0x00000000u, 0xFF000000u},
/* 31 0 */
{0x00000008u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 5 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 6 */
/* ownPaRAMSets */
/* 31 0 63 32 */
{0x00000000u, 0x00000000u},
/* 31 0 */
{0x00000000u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 6 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
/* Resources owned by Region 7 */
/* ownPaRAMSets */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* ownTccs */
/* 31 0 63 32 */
/* Resources reserved by Region 7 */
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
#if 0
// Todo: this is copied verbatim from the C66 implementation.
// Find out wth these bitmasks do and ensure they are valid.
// This structure is automagically accessed by the XDC configuration
// script.
//EDMA3_InstanceInitConfig C6678_config =
EDMA3_InstanceInitConfig C6472_config =
/* ownPaRAMSets */
{0xFFFFFFFF, 0xFFFFFFFFu, 0xFFFFFFFFu, 0xFFFFFFFFu,
/* 31 0 63 32 */
{0xFFFFFFFF, 0xFFFFFFFFu},
/* 31 0 */
{0x00000001u},
/* ownTccs */
/* 31 0 63 32 */
{0xFFFFFFFFu, 0xFFFFFFFFu},
/* 31 0 63 32 */
/* 31 0 */
{0x00000000u},
/* resvdTccs */
/* 31 0 63 32 */
#endif
