Part Number: LAUNCHXL-F28379D
My customer has started with Matlab-based control code for a digital power system based on F28379D. I have their .slx source code that I could send separately along with some screenshots.
The issue is the PWM outputs do not behave as expected at power up. Upon a hot reset (USB power cycle), the phase relation of the PWM outputs is not as expected; and upon a hot reset (CCS start button), the PWMs may start with a positive or a negative edge.
Is there an application note or coding tips that describe how to properly initialize the PWMs so the above does not happen? Alternatively, I may provide source code for analysis and screenshots. Thank you.
François.
