Part Number: TMDSCNCD28388D
Other Parts Discussed in Thread: TMDSCNCD28379D, , C2000WARE
I want to operate a MCU as EtherCAT slave by using a realtime capable PC from a third party manufacturer as EtherCAT master. For this application I came across the C2000 controlCARD TMDSCNCD28388D. Alternatively probably the TMDSCNCD28379D with EtherCAT daughter card would be possible.
However, I have not found any information about the minimum possible cycle time of the EtherCAT transmission or the data throughput possible with this. Is an EtherCAT cycle time of 50 µs feasible? Which data throughput results from this?
In addition, the MCU should perform PWM and acquire analog input signals with a cycle time of 50 µs. Is this generally possible?
Furthermore, I have seen that the MCUs can also be programmed via Simulink. Does this also apply to the EtherCAT Slave functionality?
Many thanks in advance!
