Hi, I am using CCS6, Halcogen v4 and the TMS 0332
I have an input pin that I want to read the period and duty cycle from.
I found a document (no date) titled "1512.NHET PWM generation and Capture using Halcogen.pdf" (attached) that describes exactly what I want to do. However, in Halcogen (v4) there is a note on the Cap 0-7 tab when you hover over the pin "Note HRShare must be enabled for Pin[x] and pin[x+1] using Port Config Tab to use 'capGetSignal' API.
So I am confused whether I can read the period and duty cycle through one pin or not? I don't want to go down a road that won't get what I need.
6153.1512.NHET PWM generation and Capture using HALCoGen.pdf
