Other Parts Discussed in Thread: HALCOGEN
About Periodic Software Readback of Static Configuration Registers
Periodic Software Readback of Static Configuration Registers recognizes that checking that the register has not changed from the initial value.
In Can and Gio, initial values can be acquired with HalCoGen canGetConfigValue (), gioGetConfigValue (), but dmaGetConfigValue () is "Do not pass initial value as parameter as there is no DMA initialization API" and there is no initial value.
In this case, what timing register should be used for Static Configuration Registers?
