Other Parts Discussed in Thread: TMS570LS0432, HALCOGEN, CODECOMPOSER
Is there a comprehensive technical guide for using the HET subsystem? What is the instruction set?
I am using a TMS570LS0432, HALCoGen, FreeRTOS and CodeComposer Studio 8.1.1.
OK, my post was premature. I see in the reference manual the information that I was asking for.
I am attempting to create a second UART using HET.
But I still have a question about HALCoGen, in HET, HET1 Global Timing Configuration there is the group box: NHET Driver Settings. Some post said that I should check the Enable Advanced Config Mode/Disable Blackox Driver. I have been unable to find that post again. Can you please explain this? I have also implemented a PWM using HET and am suing HET for GPIO ports. Will there be a conflict between the existing HET functions and the UART function?
