In Halcogen (2.0.8.000 23.August.2010 release), the block diagram of the General tab of the device shows up with some overlapping blocks as below.
What might be causing this? Thanks.
Stephanie, when you run HALCoGen under Windows XP you must set the dpi (dots per inch) settings of your display to normal size (96 dpi).You can change the dpi settings in the display properties:
advanced:
Cheers Marcus
