CCS/TMS570LS0914: SPI config
Part Number: TMS570LS0914
Hi team
My customer is using TMS570LS0914 with SPI. He wants to config the Clock polarity and clock phase of SPI (set to 01 mode).
But he tested the CLK waveform of spi and found that the CLK signal is high when it is not transmitting, and the waveform is a bit like the 11-mode waveform.
The following is the code and the CLK signal.
/** @file mibspi.c
*   @brief MIBSPI Driver Implementation File
*   @date 07-July-2017
*   @version 04.07.00
* Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    Redistributions in binary form must reproduce the above copyright
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
#include "mibspi.h"
//#include "sys_vim.h"
/* USER CODE BEGIN (1) */
#include "VLV09_ValveOutput2SPI.h"
#include "SYSIntlocks_COMMON.h"
/* USER CODE END */
/** @fn void mibspiInit(void)
*   @brief Initializes the MIBSPI Driver
*   This function initializes the MIBSPI module.
/* SourceId : MIBSPI_SourceId_001 */
/* DesignId : MIBSPI_DesignId_001 */
/* Requirements : HL_SR153 */
uint32 i ;
/* USER CODE BEGIN (2) */
/* USER CODE END */
    /** @b initialize @b MIBSPI1 */
    /** bring MIBSPI out of reset */
    mibspiREG1->GCR0 = 0U;
    mibspiREG1->GCR0 = 1U;
    /** enable MIBSPI1 multibuffered mode and enable buffer RAM */
    mibspiREG1->MIBSPIE = (mibspiREG1->MIBSPIE & 0xFFFFFFFEU) | 1U;
    /** MIBSPI1 master mode and clock configuration */
    mibspiREG1->GCR1 = (mibspiREG1->GCR1 & 0xFFFFFFFCU) | ((uint32)((uint32)1U << 1U)  /* CLOKMOD */
                  | 1U);  /* MASTER */
    /** MIBSPI1 enable pin configuration */
    mibspiREG1->INT0 = (mibspiREG1->INT0 & 0xFEFFFFFFU) | (uint32)((uint32)0U << 24U);  /* ENABLE HIGHZ */
    /** - Delays */
    mibspiREG1->DELAY = (uint32)((uint32)4U << 24U)  /* C2TDELAY */
                      | (uint32)((uint32)5U << 16U)  /* T2CDELAY */
                      | (uint32)((uint32)0U << 8U)   /* T2EDELAY */
                      | (uint32)((uint32)0U << 0U);  /* C2EDELAY */
    /** - Data Format 0 */
    mibspiREG1->FMT0 = (uint32)((uint32)200U << 24U)  /* wdelay */
                     | (uint32)((uint32)0U << 23U)  /* parity Polarity */
                     | (uint32)((uint32)0U << 22U)  /* parity enable */
                     | (uint32)((uint32)0U << 21U)  /* wait on enable */
                     | (uint32)((uint32)0U << 20U)  /* shift direction */
                     | (uint32)((uint32)0U << 17U)  /* clock polarity */
                     | (uint32)((uint32)1U << 16U)  /* clock phase */
                     | (uint32)((uint32)7U << 15U)  /* baudrate prescale */
                     | (uint32)((uint32)16U << 0U); /* data word length */
    /** - Data Format 1 */
    mibspiREG1->FMT1 = (uint32)((uint32)0U << 24U)  /* wdelay */
                     | (uint32)((uint32)0U << 16U)  /* clock phase */
                     | (uint32)((uint32)79U << 8U)  /* baudrate prescale */
    /** - Data Format 2 */
    mibspiREG1->FMT2 = (uint32)((uint32)0U << 24U)  /* wdelay */
    /** - Data Format 3 */
    mibspiREG1->FMT3 = (uint32)((uint32)0U << 24U)  /* wdelay */
    /** - Default Chip Select */
    mibspiREG1->DEF = (uint32)(0xFFU);
    /** - wait for buffer initialization complete before accessing MibSPI registers */
    /*SAFETYMCUSW 28 D MR:NA <APPROVED> "Hardware status bit read check" */
    while ((mibspiREG1->FLG & 0x01000000U) != 0U)
    } /* Wait */
    /** enable MIBSPI RAM Parity */
    mibspiREG1->UERRCTRL = (mibspiREG1->UERRCTRL & 0xFFFFFFF0U) | (0x00000005U);
    /** - initialize transfer groups */
    mibspiREG1->TGCTRL[0U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)0U << 29U)  /* pcurrent reset */
                           | (uint32)((uint32)TRG_ALWAYS << 20U)  /* trigger event */
                           | (uint32)((uint32)TRG_DISABLED << 16U)  /* trigger source */
                           | (uint32)((uint32)0U << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[1U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)8U << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[2U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)(8U+8U) << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[3U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)(8U+8U+4U) << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[4U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)(8U+8U+4U+4U) << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[5U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)(8U+8U+4U+4U+0U) << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[6U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)(8U+8U+4U+4U+0U+0U) << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[7U] = (uint32)((uint32)1U << 30U)  /* oneshot */
                           | (uint32)((uint32)(8U+8U+4U+4U+0U+0U+0U) << 8U);  /* start buffer */
    mibspiREG1->TGCTRL[8U] = (uint32)(8U+8U+4U+4U+0U+0U+0U+0U) << 8U;
    mibspiREG1->LTGPEND = (mibspiREG1->LTGPEND & 0xFFFF00FFU) | (uint32)((uint32)((8U+8U+4U+4U+0U+0U+0U+0U)-1U) << 8U);
    /** - initialize buffer ram */
        i = 0U;
            while (i < (8U))
                if(0==i%2)
                mibspiRAM1->tx[i].control = (uint16)((uint16)4U << 13U)  /* buffer mode */
                                          | (uint16)((uint16)1U << 12U)  /* chip select hold */
                                          | (uint16)((uint16)1U << 10U)  /* enable WDELAY */
                                          | (uint16)((uint16)0U << 11U)  /* lock transmission */
                                          | (uint16)((uint16)0U << 8U)  /* data format */
										  /*SAFETYMCUSW 334 S MR:10.5 <APPROVED> "LDRA Tool issue" */
                                          | ((uint16)(~((uint16)0xFFU ^ (uint16)CS_0)) & (uint16)0x00FFU);  /* chip select */
                else
                                      | (uint16)((uint16)0U << 12U) /* chip select hold */
            i++;
            while (i < (8U+8U))
                if(0==i%2)
                else
            i++;
            while (i < (8U+8U+4U))
            if (0==i%2)
            else
            i++;
            while (i < (8U+8U+4U+4U))
                if(0==i%2)
                else
            i++;
#if (0U > 0U)
#if (0U > 1U)
            while (i < ((8U+8U+4U+4U+0U)-1U))
                                          | (uint16)((uint16)0U << 10U)  /* enable WDELAY */
                                          | ((uint16)(~((uint16)0xFFU ^ (uint16)CS_4)) & (uint16)0x00FFU);  /* chip select */
                i++;
#endif
            i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
            while (i < ((8U+8U+4U+4U+0U+0U)-1U))
                                          | ((uint16)(~((uint16)0xFFU ^ (uint16)CS_5)) & (uint16)0x00FFU);  /* chip select */
                i++;
#endif
            i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
            while (i < ((8U+8U+4U+4U+0U+0U+0U)-1U))
                                          | ((uint16)(~((uint16)0xFFU ^ (uint16)CS_6)) & (uint16)0x00FFU);  /* chip select */
                i++;
#endif
            i++;
#endif
#if (0U > 0U)
#if (0U > 1U)
            while (i < ((8U+8U+4U+4U+0U+0U+0U+0U)-1U))
                                          | ((uint16)(~((uint16)0xFFU ^ (uint16)CS_7)) & (uint16)0x00FFU);  /* chip select */
                i++;
#endif
            i++;
#endif
    /** - set interrupt levels */
    mibspiREG1->LVL = (uint32)((uint32)0U << 9U)  /* TXINT */
                    | (uint32)((uint32)0U << 8U)  /* RXINT */
                    | (uint32)((uint32)0U << 6U)  /* OVRNINT */
                    | (uint32)((uint32)0U << 4U)  /* BITERR */
                    | (uint32)((uint32)0U << 3U)  /* DESYNC */
                    | (uint32)((uint32)0U << 2U)  /* PARERR */
                    | (uint32)((uint32)0U << 1U)  /* TIMEOUT */
                    | (uint32)((uint32)0U << 0U); /* DLENERR */
    /** - clear any pending interrupts */
    mibspiREG1->FLG |= 0xFFFFU;
    /** - enable interrupts */
    mibspiREG1->INT0 = (mibspiREG1->INT0 & 0xFFFF0000U)
    /** @b initialize @b MIBSPI1 @b Port */
    /** - MIBSPI1 Port output values */
    mibspiREG1->PC3 = (uint32)((uint32)0U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)1U << 1U)  /* SCS[1] */
                    | (uint32)((uint32)1U << 2U)  /* SCS[2] */
                    | (uint32)((uint32)1U << 3U)  /* SCS[3] */
                    | (uint32)((uint32)1U << 4U)  /* SCS[4] */
                    | (uint32)((uint32)1U << 5U)  /* SCS[5] */
                    | (uint32)((uint32)0U << 8U)  /* ENA */
                    | (uint32)((uint32)0U << 9U)  /* CLK */
                    | (uint32)((uint32)0U << 10U)  /* SIMO[0] */
                    | (uint32)((uint32)0U << 11U)  /* SOMI[0] */
                    | (uint32)((uint32)0U << 17U)  /* SIMO[1] */
                    | (uint32)((uint32)0U << 25U); /* SOMI[1] */
    /** - MIBSPI1 Port direction */
    mibspiREG1->PC1 = (uint32)((uint32)1U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)1U << 9U)  /* CLK */
                    | (uint32)((uint32)1U << 10U)  /* SIMO[0] */
    /** - MIBSPI1 Port open drain enable */
    mibspiREG1->PC6 = (uint32)((uint32)0U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)0U << 1U)  /* SCS[1] */
                    | (uint32)((uint32)0U << 2U)  /* SCS[2] */
                    | (uint32)((uint32)0U << 3U)  /* SCS[3] */
                    | (uint32)((uint32)0U << 4U)  /* SCS[4] */
                    | (uint32)((uint32)0U << 5U)  /* SCS[5] */
    /** - MIBSPI1 Port pullup / pulldown selection */
    mibspiREG1->PC8 = (uint32)((uint32)1U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)1U << 8U)  /* ENA */
                    | (uint32)((uint32)1U << 11U)  /* SOMI[0] */
                    | (uint32)((uint32)1U << 17U)  /* SIMO[1] */
                    | (uint32)((uint32)1U << 25U); /* SOMI[1] */
    /** - MIBSPI1 Port pullup / pulldown enable*/
    mibspiREG1->PC7 = (uint32)((uint32)0U << 0U)  /* SCS[0] */
    /* MIBSPI1 set all pins to functional */
    mibspiREG1->PC0 = (uint32)((uint32)1U << 0U)  /* SCS[0] */
    /** - Finally start MIBSPI1 */
    mibspiREG1->GCR1 = (mibspiREG1->GCR1 & 0xFEFFFFFFU) | 0x01000000U;
/* USER CODE BEGIN (3) */
/* USER CODE END */
/** @fn void mibspiSetFunctional(mibspiBASE_t *mibspi, uint32 port)
*   @brief Change functional behavior of pins at runtime.
*   @param[in] mibspi   - mibspi module base address
*   @param[in] port  - Value to write to PC0 register
*   Change the value of the PC0 register at runtime, this allows to
*   dynamically change the functionality of the MIBSPI pins between functional
*   and GIO mode.
/* SourceId : MIBSPI_SourceId_002 */
/* DesignId : MIBSPI_DesignId_002 */
/* Requirements : HL_SR154 */
/* USER CODE BEGIN (4) */
/* USER CODE END */
    mibspi->PC0 = port;
/* USER CODE BEGIN (5) */
/* USER CODE END */
/** @fn void mibspiSetData(mibspiBASE_t *mibspi, uint32 group, uint16 * data)
*   @brief Set Buffer Data
*   @param[in] mibspi   - Spi module base address
*   @param[in] group - Transfer group (0..7)
*   @param[in] data  - new data for transfer group
*   This function updates the data for the specified transfer group,
*   the length of the data must match the length of the transfer group.
/* SourceId : MIBSPI_SourceId_003 */
/* DesignId : MIBSPI_DesignId_003 */
/* Requirements : HL_SR155 */
/* USER CODE BEGIN (6) */
/* USER CODE END */
    mibspiRAM_t *ram    = (mibspi == mibspiREG1) ? mibspiRAM1 : ((mibspi == mibspiREG3) ? mibspiRAM3 : mibspiRAM5);
    uint32 start  = (mibspi->TGCTRL[group] >> 8U) & 0xFFU;
    uint32 end    = (group == 7U) ? (((mibspi->LTGPEND & 0x00007F00U) >> 8U) + 1U) : ((mibspi->TGCTRL[group+1U] >> 8U) & 0xFFU);
    if (end == 0U) {end = 128U;}
    while (start < end)
    /*SAFETYMCUSW 45 D MR:21.1 <APPROVED> "Valid non NULL input parameters are only allowed in this driver" */
        ram->tx[start].data = *data;
        /*SAFETYMCUSW 567 S MR:17.1,17.4 <APPROVED> "Pointer increment needed" */
        data++;
        start++;
/* USER CODE BEGIN (7) */
/* USER CODE END */
/** @fn void mibspiGetData(mibspiBASE_t *mibspi, uint32 group, uint16 * data)
*   @brief Retrieves Buffer Data from receive buffer
*   @param[out] data  - pointer to data array
*   @return error flags from data buffer, if there was a receive error on
*           one of the buffers this will be reflected in the return value.
*   This function transfers the data from the specified transfer group receive
*   buffers to the data array,  the length of the data must match the length
*   of the transfer group.
/* SourceId : MIBSPI_SourceId_004 */
/* DesignId : MIBSPI_DesignId_004 */
/* Requirements : HL_SR156 */
uint32 mibspiGetData(mibspiBASE_t *mibspi, uint32 group, uint16 * data)
/* USER CODE BEGIN (8) */
/* USER CODE END */
    uint16 mibspiFlags  = 0U;
	uint32 ret;
    while (start < end)
        mibspiFlags  |= ram->rx[start].flags;
        *data = ram->rx[start].data;
        data++;
        start++;
	ret = ((uint32)mibspiFlags >> 8U) & 0x5FU;
/* USER CODE BEGIN (9) */
/* USER CODE END */
    return ret;
/** @fn void mibspiTransfer(mibspiBASE_t *mibspi, uint32 group)
*   @brief Transmit Transfer Group
*   Initiates a transfer for the specified transfer group.
/* SourceId : MIBSPI_SourceId_005 */
/* DesignId : MIBSPI_DesignId_005 */
/* Requirements : HL_SR157 */
/* USER CODE BEGIN (10) */
/* USER CODE END */
    mibspi->TGCTRL[group] |= 0x80000000U;
/* USER CODE BEGIN (11) */
/* USER CODE END */
/** @fn boolean mibspiIsTransferComplete(mibspiBASE_t *mibspi, uint32 group)
*   @brief Check for Transfer Group Ready
*   @return TRUE is transfer complete, otherwise FALSE.
*   Checks to see if the transfer for the specified transfer group
*   has finished.
/* SourceId : MIBSPI_SourceId_006 */
/* DesignId : MIBSPI_DesignId_006 */
/* Requirements : HL_SR158 */
    boolean status;
/* USER CODE BEGIN (12) */
/* USER CODE END */
    if(((((mibspi->TGINTFLG & 0xFFFF0000U) >> 16U)>> group) & 1U) == 1U)
       mibspi->TGINTFLG = (mibspi->TGINTFLG & 0x0000FFFFU) | ((uint32)((uint32)1U << group) << 16U);
       status = TRUE;
    else
       status = FALSE;
/* USER CODE BEGIN (13) */
/* USER CODE END */
    return (status);
/** @fn void mibspiEnableLoopback(mibspiBASE_t *mibspi, loopBackType_t Loopbacktype)
*   @brief Enable Loopback mode for self test
*   @param[in] mibspi        - Mibspi module base address
*   @param[in] Loopbacktype  - Digital or Analog
*   This function enables the Loopback mode for self test.
/* SourceId : MIBSPI_SourceId_007 */
/* DesignId : MIBSPI_DesignId_009 */
/* Requirements : HL_SR161 */
//void mibspiEnableLoopback(mibspiBASE_t *mibspi, loopBackType_t Loopbacktype)
///* USER CODE BEGIN (14) */
///* USER CODE END */
//    /* Clear Loopback incase enabled already */
//    mibspi->IOLPKTSTCR = 0U;
//    /* Enable Loopback either in Analog or Digital Mode */
//    mibspi->IOLPKTSTCR = (uint32)0x00000A00U
//                       | (uint32)((uint32)Loopbacktype << 1U);
///* USER CODE BEGIN (15) */
/** @fn void mibspiDisableLoopback(mibspiBASE_t *mibspi)
*   This function disable the Loopback mode.
/* SourceId : MIBSPI_SourceId_008 */
/* DesignId : MIBSPI_DesignId_010 */
/* Requirements : HL_SR162 */
//void mibspiDisableLoopback(mibspiBASE_t *mibspi)
///* USER CODE BEGIN (16) */
//    /* Disable Loopback Mode */
//    mibspi->IOLPKTSTCR = 0x00000500U;
///* USER CODE BEGIN (17) */
///** @fn void mibspiPmodeSet(mibspiBASE_t *mibspi, mibspiPmode_t Pmode, mibspiDFMT_t DFMT)
//*   @brief Set the Pmode for the selected Data Format register
//*   @param[in] mibspi   - Mibspi module base address
//*   @param[in] Pmode    - Mibspi Parellel mode
//*                            PMODE_NORMAL
//*                            PMODE_2_DATALINE
//*                            PMODE_4_DATALINE
//*                            PMODE_8_DATALINE
//*   @param[in] DFMT     - Mibspi Data Format register
//*                            DATA_FORMAT0
//*                            DATA_FORMAT1
//*                            DATA_FORMAT2
//*                            DATA_FORMAT3
//*   This function sets the Pmode for the selected Data Format register.
///* SourceId : MIBSPI_SourceId_009 */
///* DesignId : MIBSPI_DesignId_011 */
///* Requirements : HL_SR524 */
//void mibspiPmodeSet(mibspiBASE_t *mibspi, mibspiPmode_t Pmode, mibspiDFMT_t DFMT)
//    uint32 pmctrl_reg;
//    /* Set the Pmode for the selected Data Format register */
//    pmctrl_reg     = (mibspi->PMCTRL & (~(uint32)((uint32)0xFFU << (8U * DFMT))));
//    mibspi->PMCTRL = (pmctrl_reg | (uint32)((uint32)Pmode <<  ((8U * DFMT))));
///** @fn void mibspiEnableGroupNotification(mibspiBASE_t *mibspi, uint32 group, uint32 level)
//*   @brief Enable Transfer Group interrupt
//*   @param[in] mibspi   - Spi module base address
//*   @param[in] group - Transfer group (0..7)
//*   @param[in] level - Interrupt level
//*   This function enables the transfer group finished interrupt.
///* SourceId : MIBSPI_SourceId_010 */
///* DesignId : MIBSPI_DesignId_007 */
///* Requirements : HL_SR159 */
//void mibspiEnableGroupNotification(mibspiBASE_t *mibspi, uint32 group, uint32 level)
///* USER CODE BEGIN (18) */
//    if (level != 0U)
//        mibspi->TGITLVST = (mibspi->TGITLVST & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
//    else
//        mibspi->TGITLVCR = (mibspi->TGITLVCR & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
//    mibspi->TGITENST = (mibspi->TGITENST & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
///* USER CODE BEGIN (19) */
///** @fn void mibspiDisableGroupNotification(mibspiBASE_t *mibspi, uint32 group)
//*   @brief Disable Transfer Group interrupt
//*   This function disables the transfer group finished interrupt.
///* SourceId : MIBSPI_SourceId_011 */
///* DesignId : MIBSPI_DesignId_008 */
///* Requirements : HL_SR160 */
//void mibspiDisableGroupNotification(mibspiBASE_t *mibspi, uint32 group)
///* USER CODE BEGIN (20) */
//    mibspi->TGITENCR = (mibspi->TGITENCR & 0x0000FFFFU) | (uint32)((uint32)((uint32)1U << group) << 16U);
///* USER CODE BEGIN (21) */
/** @fn void mibspi1GetConfigValue(mibspi_config_reg_t *config_reg, config_value_type_t type)
*   @brief Get the initial or current values of the configuration registers
*    @param[in] *config_reg: pointer to the struct to which the initial or current
*                           value of the configuration registers need to be stored
*    @param[in] type:     whether initial or current value of the configuration registers need to be stored
*                        - InitialValue: initial value of the configuration registers will be stored
*                                       in the struct pointed by config_reg
*                        - CurrentValue: initial value of the configuration registers will be stored
*   This function will copy the initial or current value (depending on the parameter 'type')
*   of the configuration registers to the struct pointed by config_reg
/* SourceId : MIBSPI_SourceId_012 */
/* DesignId : MIBSPI_DesignId_012 */
/* Requirements : HL_SR166 */
//void mibspi1GetConfigValue(mibspi_config_reg_t *config_reg, config_value_type_t type)
//    if (type == InitialValue)
//        config_reg->CONFIG_GCR1       = MIBSPI1_GCR1_CONFIGVALUE;
//        config_reg->CONFIG_INT0       = MIBSPI1_INT0_CONFIGVALUE;
//        config_reg->CONFIG_LVL        = MIBSPI1_LVL_CONFIGVALUE;
//        config_reg->CONFIG_PCFUN      = MIBSPI1_PCFUN_CONFIGVALUE;
//        config_reg->CONFIG_PCDIR      = MIBSPI1_PCDIR_CONFIGVALUE;
//        config_reg->CONFIG_PCPDR      = MIBSPI1_PCPDR_CONFIGVALUE;
//        config_reg->CONFIG_PCDIS      = MIBSPI1_PCDIS_CONFIGVALUE;
//        config_reg->CONFIG_PCPSL      = MIBSPI1_PCPSL_CONFIGVALUE;
//        config_reg->CONFIG_DELAY      = MIBSPI1_DELAY_CONFIGVALUE;
//        config_reg->CONFIG_FMT0       = MIBSPI1_FMT0_CONFIGVALUE;
//        config_reg->CONFIG_FMT1       = MIBSPI1_FMT1_CONFIGVALUE;
//        config_reg->CONFIG_FMT2       = MIBSPI1_FMT2_CONFIGVALUE;
//        config_reg->CONFIG_FMT3       = MIBSPI1_FMT3_CONFIGVALUE;
//        config_reg->CONFIG_MIBSPIE    = MIBSPI1_MIBSPIE_CONFIGVALUE;
//        config_reg->CONFIG_LTGPEND    = MIBSPI1_LTGPEND_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[0U] = MIBSPI1_TGCTRL0_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[1U] = MIBSPI1_TGCTRL1_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[2U] = MIBSPI1_TGCTRL2_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[3U] = MIBSPI1_TGCTRL3_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[4U] = MIBSPI1_TGCTRL4_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[5U] = MIBSPI1_TGCTRL5_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[6U] = MIBSPI1_TGCTRL6_CONFIGVALUE;
//        config_reg->CONFIG_TGCTRL[7U] = MIBSPI1_TGCTRL7_CONFIGVALUE;
//        config_reg->CONFIG_UERRCTRL   = MIBSPI1_UERRCTRL_CONFIGVALUE;
//    else
//    /*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "LDRA Tool issue" */
//        config_reg->CONFIG_GCR1       = mibspiREG1->GCR1;
//        config_reg->CONFIG_INT0       = mibspiREG1->INT0;
//        config_reg->CONFIG_LVL        = mibspiREG1->LVL;
//        config_reg->CONFIG_PCFUN      = mibspiREG1->PC0;
//        config_reg->CONFIG_PCDIR      = mibspiREG1->PC1;
//        config_reg->CONFIG_PCPDR      = mibspiREG1->PC6;
//        config_reg->CONFIG_PCDIS      = mibspiREG1->PC7;
//        config_reg->CONFIG_PCPSL      = mibspiREG1->PC8;
//        config_reg->CONFIG_DELAY      = mibspiREG1->DELAY;
//        config_reg->CONFIG_FMT0       = mibspiREG1->FMT0;
//        config_reg->CONFIG_FMT1       = mibspiREG1->FMT1;
//        config_reg->CONFIG_FMT2       = mibspiREG1->FMT2;
//        config_reg->CONFIG_FMT3       = mibspiREG1->FMT3;
//        config_reg->CONFIG_MIBSPIE    = mibspiREG1->MIBSPIE;
//        config_reg->CONFIG_LTGPEND    = mibspiREG1->LTGPEND;
//        config_reg->CONFIG_TGCTRL[0U] = mibspiREG1->TGCTRL[0U];
//        config_reg->CONFIG_TGCTRL[1U] = mibspiREG1->TGCTRL[1U];
//        config_reg->CONFIG_TGCTRL[2U] = mibspiREG1->TGCTRL[2U];
//        config_reg->CONFIG_TGCTRL[3U] = mibspiREG1->TGCTRL[3U];
//        config_reg->CONFIG_TGCTRL[4U] = mibspiREG1->TGCTRL[4U];
//        config_reg->CONFIG_TGCTRL[5U] = mibspiREG1->TGCTRL[5U];
//        config_reg->CONFIG_TGCTRL[6U] = mibspiREG1->TGCTRL[6U];
//        config_reg->CONFIG_TGCTRL[7U] = mibspiREG1->TGCTRL[7U];
//        config_reg->CONFIG_UERRCTRL   = mibspiREG1->UERRCTRL;
extern void FUN_BE13WDOff_Init(void);//turn off the wd for be13 chip
void PRC_MibSPIInit(void)
    mibspiInit();
//    FUN_BE13WDOff_Init();
void PRC_MibSPI1ms(void)
    FUN_FillAVData1ms();
    FUN_FillEVData1ms();
    mibspiSetData(mibspiREG1, 0, &VLV_BE13TransData[0]);
    mibspiTransfer(mibspiREG1,0);
    mibspiSetData(mibspiREG1, 1, &VLV_BE13TransData[8]);
    mibspiTransfer(mibspiREG1,1);
extern void FUN_BE13IVLV_PumMo_Init(void);
void PRC_MibSPI5ms(void)
    FUN_BE13WDOff_Init(); //if initial one time, the transfer have some problems, so do it here
    FUN_BE13IVLV_PumMo_Init();//if initial one time, the transfer have some problems, so do it here
    FUN_SYSSuspendIRQs_V();
    FUN_SetAVDurCntr_5ms();
    FUN_SetDDDCntr_5ms();
    FUN_SYSResumeIRQs_V();
    FUN_FillHSVData5ms();
    FUN_FillUSVData5ms();
    mibspiSetData(mibspiREG1, 2, &VLV_BE13TransData[0]);
    mibspiTransfer(mibspiREG1,2);
    mibspiSetData(mibspiREG1, 3, &VLV_BE13TransData[8]);
    mibspiTransfer(mibspiREG1,3);
Please help.
BR,
SUSA
