MSP432P401R Baud rate problem
I'm trying to make my MSP communicate at 9600 bauds.
This is the code I use :
              // Configure HF pins pins
        PJ->SEL0 |= BIT2 | BIT3;                // set 2-UART pin as secondary function
        // Configure UART
        EUSCI_A0->CTLW0 |= EUSCI_A_CTLW0_SWRST; // Put eUSCI in reset
        EUSCI_A0->CTLW0 = EUSCI_A_CTLW0_SWRST |
                CS_CTL0_DCORSEL_3 | // DCO 12
                EUSCI_A_CTLW0_SSEL__SMCLK;
        // Baud Rate calculation
        // 12000000/(16*9600) = 78.125
        // Fractional portion = 0.125
        // User's Guide Table 21-4: UCBRSx = 0x10
        // UCBRFx = int ( (78.125-78)*16) = 2
        EUSCI_A0->BRW = 78;                     // 12000000/16/9600
        EUSCI_A0->MCTLW = (2 << EUSCI_A_MCTLW_BRF_OFS) |
                EUSCI_A_MCTLW_OS16;
        EUSCI_A0->CTLW0 &= ~EUSCI_A_CTLW0_SWRST; // Initialize eUSCI
I have several questions.
* First, in the datasheet it is indicated that the calculation must be done this way : N = Fbrclk/BR. However, in the example code it is done this way : N = Fbrclk/(16*BR).
Why?
** When I try this code, the length of one bit is 400µs instead of 100µs at 9600 baud. When I try to do as the datasheet indicates (N = Fbrclk/BR), the length of one bit is much more longer...
Thank you
